FAQ: Bulb Replacement List - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
Old May 18th, 2003, 12:10 AM   #1
Post FAQ: Bulb Replacement List
This was Originally posted by Pmantis24, I figured this was good info to bring to the new site b4 they closed down the old one, i added some comments about some bulbs sizes on the way bottom of the page, Here it is:
Here's something to help those looking for the part# for replacing their bulbs.
This applies to all 6th gen models ('98-'02)
Low beam headlamp
Part number = 9006
High beam headlamp
Part number = 9005
Parking light (reflector strip)
Part number = 168/194
Front turn signal
Part number = 1157A
Rear turn signal
Part number = 2057
For 2-door model only
Part number = 7440
For 4-door model only
Tail light
Part number = 168
Part number = 3057
Part number = 7443
Stop light
Part number = 3057
Part number = 7443
High mount stop light
Part number = 7440
License plate
Back up light
Part number = 7440
Rear sidemarker
Ash tray
Part number = 74
Map light
Dome light
Part number = DE3175
Step/Courtesy light
Trunk/Cargo area
Factory Fog Light
Part number = H11
Posted by Viper
There are also the gauge bulbs. They Are Size 168/194 & Size 74 for the tiny peanut bulbs that light up the warning lights.
I changed the Taillight & Stop light Bulb size #’s for the coupe cause someone on the old site said that it wasn’t 2057, it was 3057, if he was wrong sorry……I’m not sure so I just put what he said it was……..Peace
SimpleMan95 likes this.
Old May 20th, 2003, 12:53 AM   #2
Mods i think this should be a sticky, as it was on the old site.........Thanx
Old May 20th, 2003, 01:22 PM   #3
^bump^ make a sticky!
Hai_c83 is offline   Reply With Quote Quick reply to this message
Old May 20th, 2003, 03:26 PM   #4
Old Member
Du3ce's Avatar
dang i was looking for this, make it a sticky in the DIY forum
Old May 20th, 2003, 03:27 PM   #5
Sticky Please
Darth Vader is offline   Reply With Quote Quick reply to this message
Old May 20th, 2003, 05:25 PM   #6
I think you are missing the OEM 98-00 fog light replacement bulb which are H3. The H11 are 01-02. I believe.
02accordSE is offline   Reply With Quote Quick reply to this message
Old May 29th, 2003, 11:05 AM   #7
GODDAAAMN I LOVE THIS FORUM!!! Oh... you too b rockav66
EnvyJK is offline   Reply With Quote Quick reply to this message
Old May 29th, 2003, 10:35 PM   #8
Send a message via ICQ to Redline Send a message via AIM to Redline
Btw, on the reflector strip bulbs and door courtesy lights, I think 194 and 168 are differant, seeing as one has 1 contact and the other has two. Correct me if i'm wrong, but they dont fit in the same holsters?
Redline is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2003, 10:09 AM   #9
does anybody know where to get 7443 or 7440 in a led? and 194 to the best of my knowledge is the same thing as a 168, i thought they looked diff but people always tell me they are the same, but they fit in the same socket
Midnight Heretic is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2003, 11:52 AM   #10
superbrightleds.com
Old June 3rd, 2003, 12:10 PM   #11
Originally posted by 02accordSE on June 3rd, 2003 at 06:52 PM
superbrightleds.com
Yeah, that site is awesome.
Old June 3rd, 2003, 01:36 PM   #12
DEF sticky no dought
Old June 5th, 2003, 01:33 AM   #13
hmm...
i might have missed it but what are the light specs for the panel lights i.e. clock, A/C button lights, dial lights, temp. screen lights. basically all the lights in center panel.
Are they also 194/168 bulbs or ?
i3lue33 is offline   Reply With Quote Quick reply to this message
Old June 5th, 2003, 03:07 AM   #14
Very useful, thanks b rockav66 .
Old June 13th, 2003, 08:28 PM   #15
does anybody know the part number for the rear center stop light for the coupe's spoiler/wing???????
Old June 14th, 2003, 04:10 AM   #16
Old Member
Du3ce's Avatar
Originally posted by i3lue33 on June 5th, 2003 at 01:33 AM
hmm...
nope i thin theyre 5mm 99accord.com sells them
2007 Accord EX-L V6
Old August 27th, 2003, 11:34 AM   #17
sittin low
AcCoRd16's Avatar
194 Aren't bright at all. The 168 are alot better theyr'e 5 watts. and the 194 are only 3.3 watts i believe.
AcCoRd16 is offline   Reply With Quote Quick reply to this message
Old September 18th, 2003, 09:33 AM   #18
Enter the fist.
Krustum's Avatar
Send a message via AIM to Krustum
Argh, cant find my manual.......
My passenger side rear brake light went dead. (Thats the one that lights when I step on my brake pedal.) And I need to go guy a replacement bulb today.. at Pep Boys or something.
So would that mean I need bulb #3057?
(I have a 6th Gen AV6 Coupe)
Krustum is offline   Reply With Quote Quick reply to this message
Old September 18th, 2003, 09:57 AM   #19
QuizWORX's Avatar
Originally posted by i3lue33 on June 5th, 2003 at 12:33 AM
hmm...
yah where are the specs for this???
Injen Intake, Injen Heat Shield, Hayden Transmission Oil Cooler, Denso Iridium Sparkplugs, APEXi WS Cat-back exhaust (single), SPE Helix Throttle Body Spacer, Hyper Ground System, Hyper Voltage System.
Cross-drilled, Eibach Pro-kit Springs, 5Zigen 5ZR 225/40 R18 2pc, Pirelli P-Zero Nero 225/40 R18
Levoc pedal, Razo shift knob, 2002 Accord Head Rest, H.I.D. 10k Headlight, Rosen R6500 Double-DIN DVD/CD/MP3/TV/AM-FM Stereo, NAV Ready
Honda OEM Body kit, Honda OEM Spoiler
QuizWORX is offline   Reply With Quote Quick reply to this message
Old November 28th, 2003, 04:18 PM   #20
HELP a starving student out. i am looking for some polarg to replace all my stock bulbs. where is the cheapest place to get them on line? i am buying a lot and it is costing me about $100
6 sets of 194
2 sets of dome lights
2 bulbs of 7440
2 bulbs of 2057
any help is greatly appreciated. TIA
FriedTofu is offline   Reply With Quote Quick reply to this message
Old December 10th, 2003, 09:49 AM   #21
wat was the old site address, my harddrive crash and i forgot the site, anybody can help?
vt4lifecuf is offline   Reply With Quote Quick reply to this message
Old December 10th, 2003, 12:25 PM   #22
http://www.sounddomain.com/shop/vehicle_lighting
I buy from them.
98vtech is offline   Reply With Quote Quick reply to this message
Old August 15th, 2004, 04:55 PM   #23
can we please make this a sticky? im tired of searching this down everytime i need it
smolderingwreck is offline   Reply With Quote Quick reply to this message
Old August 15th, 2004, 05:08 PM   #24
and does anyone know the codes for the vanity mirror lights and the glove box light?
Old August 15th, 2004, 06:01 PM   #25
All those bulbs are usually 168's. They are widely used for applications where a small bulb is needed.
PMantis24 is offline   Reply With Quote Quick reply to this message
Old August 16th, 2004, 12:40 AM   #26
well i looked at the vanity mirror bulb and it was like a miniature 3175 - but no code on bulb
Old September 14th, 2004, 07:40 PM   #27
dammit i said make it a sticky its not hard to understand
Old September 14th, 2004, 07:59 PM   #28
Werd
Old September 14th, 2004, 08:16 PM   #29
14.58 =Quickest Gen7 auto
03LXV6Guy's Avatar
Originally Posted by vt4lifecuf
Werd
Do you realize this thread is 6th gen info?
Old September 14th, 2004, 08:26 PM   #30
I'll do it but thats not how you ask for something .
