need help removing lower intake manifold - Honda Accord Forum : V6 Performance Accord Forums
Old April 2nd, 2014, 03:21 PM   #1
can anyone let me know if its necessary to pull the heads in order to remove the lower portion of the intake manifold on a 1998 Honda accord v6 engine.
bonifide78 is offline   Reply With Quote Quick reply to this message
Old April 2nd, 2014, 04:41 PM   #2
DiceX's Avatar
Don't need to remove heads, you need to remove one side first I think it is the one towards the firewall first. Read thread CL-S intake manifold swap, it gives info on there. what r you trying to do
Old April 2nd, 2014, 07:30 PM   #3
accord325's Avatar
Haynes manual is a life saver and is only like $30. Runner sit on the heads, so you just have to remove the Upper IM to get to them.
Old April 3rd, 2014, 07:54 AM   #4
The front one is cracked and needs replacing. I undid the bolts/nuts holding both sides down but was unable to get them off. I'll try removing firewall side first and see what happens.
Thanks for the responses fellas.
Old April 3rd, 2014, 11:17 AM   #5
DiceX's Avatar
Best of luck, let us know how it goes
Old April 7th, 2014, 01:33 PM   #6
Got them out, but still having a idling problem. Check engine light came on, code says to replace idle control valve which I did a couple weeks ago. Still got some figuring out to do. Any tips would be appreciated.
