1999 AV6 Analysis - Honda Accord Forum : V6 Performance Accord Forums
Old April 13th, 2004, 12:27 AM   #1
1999 AV6 Analysis
This thread is about the analysis of my 99 AV6 with my Auterra Dyno-Scan. This is the site for it http://www.auterraweb.com/index.html and this is what I am using it on http://www.v6performance.net/forums/...threadid=20711 .
As time goes on I will post up info I collect from using this including Dynamometer tests.
First Analysis
Speed test (highway):
80 MPH gauge reading = 75 MPH OBD II reading
85 MPH gauge reading = 80 MPH OBD II reading
90 MPH gauge reading = 84 MPH OBD II reading
80 and 85 MPH are only off by 5 MPH from the actual reading but 90 MPH is off by 6. The OBD II scanner gets the speed info right from the ECU so as long as the tires are at the right pressure (OEM size rims/tires) you will get very accurate readings. I havenít had time to do any other speed tests so I am not sure how off the gauges are at lower speeds.
More to come soon .
Old April 13th, 2004, 12:35 AM   #2
Senior Moderhater
abram2001's Avatar
we know this already chris
Old April 13th, 2004, 12:44 AM   #3
Yeah I know that we all know the gauges are off. But we don't really know the exact numbers at certain speeds .
Old April 23rd, 2004, 03:22 AM   #4
J30A1 => J30A5 => K24Z3
TH23's Avatar
Have you done any dyno runs with your scanner yet? I can't wait to see your results.
Old April 23rd, 2004, 03:25 AM   #5
Not yet, I might do some this coming week .
Old April 23rd, 2004, 03:36 AM   #6
TH23's Avatar
Cool I really wish I could afford a PDA and OBD-II scanner, it sounds like it's pretty fun to use.
Old April 30th, 2004, 01:51 AM   #7
V6 -> I4 -> I6
HwaNi.J30A-C's Avatar
cool information. You thinking getting HUD[heads up display] from Defi would help this problem?
Those are electronic speed readers.. i believe.
Old April 30th, 2004, 02:00 AM   #8
It's possible. The gauge cluster is what is off most of the time, not the speed sensor. But the speed sensor can be off if you have a tire and wheel combo that are not the same diameter as stock and/or low tire tread.
Old May 12th, 2004, 03:26 PM   #9
Banned
Lxcord's Avatar
Can you do a top speed run to like 130 MPH, and then report back to us?
Old June 1st, 2004, 07:15 PM   #10
I did this last week but forgot to post it .
Using my GPS I got this from it on the same stretch of highway:
Accuracy between 6.4-7.7 feet
65 MPH gauge reading - 62.8 MPH GPS
70 MPH gauge reading - 66.3 MPH GPS (+5 MPH from 65 = +3.5 MPH GPS)
75 MPH gauge reading - 71.4 MPH GPS (+5 MPH from 70 = +5.1 MPH GPS)
80 MPH gauge reading - 76.4 MPH GPS (+5 MPH from 75 = +5 MPH GPS)
85 MPH gauge reading - 81.2 MPH GPS (+5 MPH from 80 = +4.8 MPH GPS)
90 MPH gauge reading - 85.2 MPH GPS (+5 MPH from 85 = +4 MPH GPS)
All GPS speeds are an average over a few minutes of driving for each speed reading. Most of the time it only was only a different of +/- .3 MPH. The accuracy between the gauge and actual speed peak at 80 MPH but then start dropping after that. This drop also shows up in the OBD II readings. I'll have a bit more on this soon.
Sorry, don't feel like doing that right now .
Old June 3rd, 2004, 09:45 PM   #11
Banned
Lxcord's Avatar
Plum you sir are a Wussy
Old June 4th, 2004, 12:02 AM   #12
You go buy one and do it yourself then . And I have maxed out my car before (it was a long time ago), check my sig link above.
Old June 19th, 2004, 09:22 PM   #13
hey chris,
just outa curiosity, could you do the same thing at lower speeds?
ie 30-35-40-45 up to 70ish?
i was doin a road trip today w/ my gps, and i found my 65-80 ranger is closer to accurate, than my 30-55 range
davejax904 is offline   Reply With Quote Quick reply to this message
Old June 20th, 2004, 12:18 AM   #14
Originally posted by davejax904 on June 19th, 2004 at 11:22 PM
hey chris,
I might do it at lower speeds sometime this week. Stay tuned .
Old July 14th, 2004, 11:24 AM   #15
hey is it safe to assume the same for all years. or is the difference varied with the new igntion?
Old July 14th, 2004, 01:32 PM   #16
6th gen and 7th gen AV6 or just all model year 6th gen AV6's?
At this point I think all 6th gen AV6 gauges suffer from the same inaccuracies.
Old July 14th, 2004, 01:34 PM   #17
6th gens.
i know all manufactorers do this deliberately, i read somewhere that its required by law for them to make speedos show optimistic readings.
Old December 9th, 2004, 04:38 AM   #18
This thread completely slipped my mind until yesterday, sorry . So I went out last night to a deserted area and did some low speed testing. Only did 5-50 MPH, forgot 55 and 60 MPH .
GPS Accuracy - between 6.2-8.9 feet
5 MPH gauge reading - 6.7 MPH GPS
10 MPH gauge reading - 9.1 MPH GPS (+5 MPH from 5 = +2.4 MPH GPS)
15 MPH gauge reading - 13.9 MPH GPS (+5 MPH from 10 = +4.8 MPH GPS)
20 MPH gauge reading - 18.6 MPH GPS (+5 MPH from 15 = +4.7 MPH GPS)
25 MPH gauge reading - 23.8 MPH GPS (+5 MPH from 20 = +5.2 MPH GPS)
30 MPH gauge reading - 28.1 MPH GPS (+5 MPH from 25 = +4.3 MPH GPS)
35 MPH gauge reading - 33.6 MPH GPS (+5 MPH from 30 = +5.5 MPH GPS)
40 MPH gauge reading - 37.8 MPH GPS (+5 MPH from 35 = +4.2 MPH GPS)
45 MPH gauge reading - 42.6 MPH GPS (+5 MPH from 40 = +4.8 MPH GPS)
50 MPH gauge reading - 47.4 MPH GPS (+5 MPH from 45 = +4.8 MPH GPS)
Again, all GPS speeds are an average over a few minutes of driving for each speed reading. Most of the time it only was only a different of +/- .4 MPH for each reading. Low speed testing isn't easy to do since cruise control won't work under 25 MPH. It would be great to have someone make up a list like this with there GPS reading so we can compare them .
More info soon. But this time, a lot sooner than 5 months .
Old December 18th, 2004, 11:10 PM   #19
Founder of PsychoLemon CC
DeadDoc's Avatar
Send a message via ICQ to DeadDoc Send a message via AIM to DeadDoc Send a message via MSN to DeadDoc Send a message via Yahoo to DeadDoc
Now what is CAN? Bc I see you can get it with or without CAN? What cars use that?
DeadDoc is offline   Reply With Quote Quick reply to this message
Old December 19th, 2004, 12:44 AM   #20
CAN is a new type of diagnostic communication. Right now it's on select 2003, 2004 and 2005 car models. By 2008, all cars sold in the US must use CAN. I suggest buying the one with CAN so that you're set for the future.
http://www.auterraweb.com/aboutcan.html
What's messed up is that they aren't selling the CAN adapter separately. Do they expect customers that already bought the first kit to buy another $289 kit just for CAN support ?
Old May 3rd, 2005, 10:25 AM   #21
*Looks at calendar* haha
I've had all of the collected data since January, just haven't found the time to look through all of it. I'll try to make some extra time for this soon though.
Old May 3rd, 2005, 10:35 AM   #22
THLA 2009 Bombsquad
Dtownz Thrillah's Avatar
you stink
Old May 5th, 2005, 10:35 AM   #23
Destroyer of Tires
Doctor_X's Avatar
I want to see one of those top speed readings.
