How to install headers - Honda Accord Forum : V6 Performance Accord Forums
Old April 24th, 2004, 08:46 PM   #1
Something Something Darkside
Doom's Avatar
Poster by AccordNewbie
Installation
Tools:
Breaker Bar
Extensions
Vise Grip
Torque Wrench
Sockets
17mm Wrench
Header to Exhaust Manifold Gasket
Torque Specs:
Exhaust Manifold to Header bolts: 23 lb
O2 sensor: 33 lb (didn't know how to disconnect from car so I just unscrewed it from the a-pipe directly)
A-Pipe flange to header bolts: 40 lb
Hanger bolts: 28 lb
A-Pipe flange to Cat Converter: 25 lb
Well, since I had to figure the whole thing out myself, I think it would only be right to share the knowledge. It's actually a very easy installation once you do it once. You don't actually need to jack up and jack down the car like the instructions say. I'm pretty tall, 6'2, so I just leaned over and installed the parts. I installed it with my girlfriend and it was pretty easy, it took about 3 hours because one bolt took me forever to get off because of the wrong socket size, heh. You can either use air tools or if you're pretty strong you can just use a breaker bar. However, an easier way is to position the breaker bar so that you and your friend can pull on it at once. It'll seem like you cracked the bolt or something but that's the right sound. They're bolted on really tight. I personally bought gaskets from Acura for my Accord and they were about 9 dollars for both front and rear headers. The old ones look worn out but you can reuse them if you please. Well, I can go through the entire installation process so here goes. You'll need a breaker bar, an assortment of sockets (14mm and 17mm are the main ones), I had probably five different extensions (one long one and one short one for the breaker bar (3/8 inch). I also used a Vise Grip to hold the bolts when installing the new bolts on. Alright, this is the easier installation method.
1. Disconnect negative cable on battery. Jack up car on jack stands. Take off the A-pipe underneath the car. There are 3 bolts connecting each flange of the a-pipe to the headers and the catalytic converter. But first you want to unbolt the hanger that holds the a-pipe so that you can pull it out easier. Also, you'll need to start the car a little in order to take off the oxygen sensor because it contracts when heated. After everything is cooled, then go back under, with your friend holding the a-pipe, take off all of the bolts and slowly slide the a-pipe out from under the engine.
2. Take off the bolts on the headers by using extensions and a breaker bar. Fairly easy to reach if you just stretch a little. Just feel for the bolts first and then take them off. You'll have to take out the rear header from under the car. After that is done, keep all the bolts from the headers.
3. Put the Comptech headers onto the (Front one has the Carb number, Comptech had sent me two front headers when they sent me mine, it sucked) exhaust manifold and put the bolts back on. Do not tighten them yet because you'll need the flexibility later.
4. After both headers are in place (you can rebolt the headers from the top), take the new a-pipe and bolt the three new bolts onto each flange. Use some anti seize compound on the gasket that's between the a-pipe flange and the catalytic converter to hold it there in place. Also, before doing this (sorry about the order of the instructions), make sure you put anti-seize compound on the threads and only the threads of the O2 sensor, make sure you be extra careful about this because the anti-seize compound can damage the sensor. Bolt the hanger from the old a-pipe onto the car first so that you won't have to carry the a-pipe. Connect all the bolts. I found it easiest to have my gf stand on over the car and use the vise grip to hold the top bolt while I tightened it from the bottom (for the front header). For the rear header, I found it easiest to use a 17mm wrench to hold the bolt while I tightened the bolts (have your friend hold the bolt while tightening, requires some maneuvering, but not hard at all). After everything is connected, reconnect the battery cable and turn on the car. Leave the car on idle for a 3-5 minutes and then take it out for a test drive. Check for leaks but if you installed the bolts to factory specs, than you should be fine. You might smell a funny smell while driving it at first but I believe this to be the anti-seize compound burning off the gasket and maybe some of the threading on the 02 sensor. After that, have fun. If you have any more questions, I'll be around. Good luck. Sorry I don't have pics. I was too anxious to finish.
V6P Senior Moderator
Old April 24th, 2004, 08:46 PM   #2
Doom's Avatar
Posted by Nzo13
Headers should come with all the parts that you need including new gaskets and seals. All you need is a wrench and ratchet set, preferrably a torque wrench. Park the car and make sure the engine and its exhaust manifold is cold not hot. And spray every existing bolt with WD-40 and let it sit for atleast 5 minutes so it is easier to unbolt them and so you don't break or snap any of the bolts. Make sure not to over tighten when installing the header causing a loose thread. This is why you should have a torque wrench. Remember that when the engine heats up, it will expand, so it will tighten and seal itself even more. If not, it's always best to use new gaskets when taking off any engine parts like this to prevent leaks, cause the lead/aluminum coating on gaskets can peel off. On the other hand, I noticed that your car is a 2000, so I would think that it will be fairly new and should be fine to re-use the existing gaskets on your car, just be careful when you peel off the parts from each other. You will know by how it looks and if you should replace it or not anyway. Then after it's all done. Start and have someone else rev the motor and listen and feel for leaks while it is cold. then go for a test drive with the windows closed and listen. That is one best way to listen for leaks is actually driving with thw windows and of course everything else off. If no signs of leaks, you are ready for business! Good luck!
Old April 25th, 2004, 01:32 AM   #3
v6p gangster
PFizzle's Avatar
how did you get the cat. bolts loose cause that was the only problem i had when i wanted to install my headers....
SHIFT_future
FEEL THE SKYLINE | DRIVE JAPAN 日本
Old April 25th, 2004, 10:38 AM   #4
Doom's Avatar
Try bolt loosener spray. It's very very very difficult to unscrew exhaust bolts unless you have air tools.
Old September 17th, 2005, 02:38 PM   #5
yeah, i couldnt get the cat bolts off. I sprayed it with penetrating oil. Is their a big difference between that and bolt loosener spray?
Also how big of an extension do you need to get the rear headers off?
swears is offline   Reply With Quote Quick reply to this message
Old September 17th, 2005, 11:00 PM   #6
Doom's Avatar
Honestly mine was done with air tools. You can PM the original posters and see what they used.
Old September 19th, 2005, 10:29 AM   #7
Chi
What me? Worry?
Chi's Avatar
Cat bolts let them soak in WD40 for a bit, then for that top bolt use a 12" Inch extension to break it off. The rear header Bolts I used a 24" extension which worked great. The trick is to have your car high enough so you have room to use a breaker down there I foudn it easier to use hand tools down there compared to air tools. (more room w/o hoses everywhere)
Chi is offline   Reply With Quote Quick reply to this message
Old September 19th, 2005, 10:32 AM   #8
V6P Lover
v62kaccord's Avatar
Send a message via AIM to v62kaccord
all you need is wd-40, some long extensions and GREAT strength... that's how i opened my bolts lol
v62kaccord is offline   Reply With Quote Quick reply to this message
Old September 19th, 2005, 10:45 AM   #9
metallikatz3's Avatar
Send a message via AIM to metallikatz3
yeah..i couldnt get my cat bolts off either so i just cut the nuts off then pounded the studs out and replaced them with stainless nuts, bolts, and washers. that was a lot easier than taking them off cuz mine were so rusted there wasnt any size socket that would fit the nuts anymore
metallikatz3 is offline   Reply With Quote Quick reply to this message
Old September 19th, 2005, 02:03 PM   #10
nice work guys...dam i can't even do an oil change , do headers really help LOW end torque? a mechanic said i just need a UR crank pulley upgrade and not to waste money on headers...i don't race or anything but i just want low end back with my crappy magnaflow cat...
Old September 19th, 2005, 04:09 PM   #11
Doom's Avatar
He is right that pullies will help the low range.
Old September 20th, 2005, 11:45 AM   #12
I'm pretty sure they help throughout the whole rpm range. Thats why I bought them.
I'll let you know when I install mine, I just need to get some WD-40, Extensions and a breaker bar. Im working on the strength part
Old March 19th, 2008, 03:51 PM   #13
Doom's Avatar
Another good headers install thread
http://www.v6performance.net/forums/...ad.php?t=68969
Old September 21st, 2008, 05:08 PM   #14
Accord_V6_400m's Avatar
Posting this info in most of the DIY headers install threads, to make the information more available when searching
All 3 gaskets for the Comptech headers are the same. They use 2.1" ID/2.5" OD gaskets which means you'll have to find gaskets within this range. The one that i found to work is the Honda Accord V6 pre-catback gasket, use three of these and your set.
Part # 18393-SH3-S00
http://www.hondaautomotiveparts.com/...E+%28V6%29
#15 in pic
Old September 22nd, 2008, 09:35 PM   #15
4.0L
VietNinjaJ30A1's Avatar
=/...I think my #23 is rattling. Any ideas how to shut it up?
Old September 22nd, 2008, 11:17 PM   #16
Emblem molding tape, check for missing bolts/nuts thats pretty much it, or you can just take it off
Old September 23rd, 2008, 04:22 AM   #17
4.0L
All the factory bolts are there and tight. You mean just double-side tape it to the underside of the floorboards?
Old September 23rd, 2008, 11:33 AM   #18
Yeah, but are you sure it couldnt be something else, try taking it off completely and see what happens.
Old September 23rd, 2008, 04:38 PM   #19
4.0L
I'd probably have to take the cat converter down...which is now completely welded in place in the exhaust line.
I'm like 95% positive that it's the heat shield rattling. I'll see if I can take it off by just wiggling it.
Old September 23rd, 2008, 06:23 PM   #20
hmmm what next?
shonda1989's Avatar
go to a shop and have them cut the shield off and weld the top one to the body that will make the rattling go away.
Old September 27th, 2008, 10:31 PM   #21
Awesome write-ups. I'm hopefully tackling this down soon.
La0niNja7816 is offline   Reply With Quote Quick reply to this message
Old July 7th, 2013, 02:39 PM   #22
Can someone help me out and confirm what the torque spec would be for connecting the A-pipe flange to the exhaust manifold flange for a stock 1998 Honda Accord EX-V6 sedan?
I see 40 (ft-lb) noted above in the first post (which I assume is same flange connection despite mention of header???), but I have not come across a clear answer either on this forum in the Hanes repair manual. I dropped the entire exhaust (as 1 piece) to replace the gas tank, and with new gaskets, I torqued the A-pipe to exhaust manifold bolts to only 20 ft-lb to temporarily hold, but not overcrush the gaskets, with intent to look up correct values and re-torque. Honda dealership were not too interested in reseaching the right values for me. Any comments appreciated.
rohrc is offline   Reply With Quote Quick reply to this message
