Stock wheel weight? - Honda Accord Forum : V6 Performance Accord Forums
Old April 29th, 2004, 12:10 AM   #1
Stock wheel weight?
I couldnt really get a number on this.
Does anyone know the weight of a stock wheel?
with or without tires is fine.. just tell me if its with or w/o
thanks
accord2002 is offline   Reply With Quote Quick reply to this message
Old April 29th, 2004, 06:16 AM   #2
HONDA_99's Avatar
for 205/65/15: rim-18lbs, tire-17lbs
Old April 29th, 2004, 09:52 AM   #3
thanks
Old April 29th, 2004, 05:45 PM   #4
Something Something Darkside
Doom's Avatar
Moved to FAQ forum!
V6P Senior Moderator
Old April 29th, 2004, 06:44 PM   #5
J30A1 => J30A5 => K24Z3
TH23's Avatar
Nice, I didn't know my stock wheels and tires were so light . I was guessing that the combo weighed more like 40lbs. I know the stock 16" wheel/tire weighs about 43lbs, so the coupe must have quite a bit more rolling resistance than the sedan huh?
Old April 29th, 2004, 09:08 PM   #6
Doom's Avatar
What about coupe wheels?
Old April 30th, 2004, 01:23 AM   #7
TH23's Avatar
The 16" coupe wheels weigh about 42-43lbs with tire.
Old May 14th, 2004, 01:39 PM   #8
Banned
Lxcord's Avatar
What is the widest tire, the stock 15 inch alloy rim of the sedan can take ????? THe stock one for reference is P/205 series tires.
Old May 14th, 2004, 01:40 PM   #9
Banned
Lxcord's Avatar
BUMP !
Old May 14th, 2004, 07:20 PM   #10
Lumpy's Avatar
I think a 225/45 would be the widest, but dont know for sure!!!
Lumpy is offline   Reply With Quote Quick reply to this message
Old July 10th, 2004, 01:58 AM   #11
TH23's Avatar
I'm assuming the alloys since steel wheels are heavier than alloy wheels of the same size.
Old July 24th, 2004, 11:07 PM   #12
hehe, sorry i deleted my first post cause i figured that had to be alloy.
Anyways, I went to look at some 2002 sedan V6 15" alloy wheels and those are still about 40 lbs tire, rim, air. I brought my own scale and that is no lighter than 15" steel wheels. Are the later ones heavier than the the 98-99?
outersquare is offline   Reply With Quote Quick reply to this message
Old July 25th, 2004, 03:15 AM   #13
TH23's Avatar
I don't know The spokes on the '01-'02 alloy rims are a bit thicker so maybe they are heavier? Maybe you should look into some Mazda Millenia rims instead? Those bad boys are only 30lbs with tire
Old July 31st, 2004, 08:54 PM   #14
actually according to here;
http://www.1010tires.com/wheel.asp?w...l=Honda+Accord
The steel rim weighs 18 lbs. I went to look at a seller for 15" 2002 EX wheels and tire+rim it still was about 40 lbs despite the fact the tires were almost bald.
I guess none of the honda OEM rims are light.
