DIY: PCV Valve Check & Replacement - Honda Accord Forum : V6 Performance Accord Forums
Old June 25th, 2004, 03:21 PM   #1
Senior Moderhater
abram2001's Avatar
Hey, its been a while since I wrote up a installation DIY for you guys. Anyway, here it goes.
Total Time: 93 seconds
Fram Part Number: FV309
Purolator Part Number: PV1039
Tools Needed:
- Pliers
- 10M Socket & Ratchet
- Screwdriver (only to remove plastic engine covers)
Comments:
- The installation was the most easiest thing I have ever done to the accord v6, and I recommend everyone who has not changed this yet to do so asap. I had only 26,000 miles on my car and I noticed the pcv valve was pretty clogged. These are very affordable, only around 4 dollars to change. And immediatley after the installation, I noticed I had a MUCH smoother idle.
Check & Replacement:
Step 1:
-While your engine is cold remove all your plastic engine covers. Remove the 2 10m bolts from the rear plastic that holds the spark coil-pack connetors. Now disconnect the 3 connectors from the spark plug coil-packs (remember which wire goes where). Once you have the bolts, and connectors removed, yank the plastic shroud out of the way.
Step 2:
-Disconnect the pcv from the rear head by pulling on it (its underneath the IAT sensor). It will come out very easy.
Step 3:
- Shake the old pcv to see if it rattles, if it rattles good.. then your pcv valve is ok. If it doesnt really make a nice rattle, then chances are it is clogged. Just go get a new one, and replace in reverse order.
here is a picture of the New (left) and Old (right) pcv valve
~Abe
Old June 25th, 2004, 10:12 PM   #2
Something Something Darkside
Doom's Avatar
Good stuff. Copied to FAQ section.
V6P Senior Moderator
Old June 29th, 2004, 05:21 PM   #3
oh snap, is that easy.
i wonder Honda charges to do it to the off warranty cars for.
carzy stuff. great job Killer
arrrgggghhh
git r done
Old July 1st, 2004, 05:14 AM   #4
EX-Featured Ride Coord.
DaBenz7898's Avatar
Send a message via AIM to DaBenz7898 Send a message via MSN to DaBenz7898
okay, i'm guessing that a clogged pvc valve is a bad thing......but what are the disadvantages if your running a clogged pvc valve? i haven't changed mine since i bought my car brand new, and i have 80k miles on it!!!!!
DaBenz7898
Pics, mods, and latest updates:
** Click
** Click
DaBenz7898 is offline   Reply With Quote Quick reply to this message
Old July 2nd, 2004, 07:39 PM   #5
id like to know how can u tell if ur egr needs to be replaced?
Viper is offline   Reply With Quote Quick reply to this message
Old February 5th, 2005, 03:54 PM   #6
original member!
Nittanys1's Avatar
your kidding right?!?!?! you should have it changed like NOW......having a clogged PVC will hurt you gas mileage.
ask.com:
"A clogged PVC valve or hose can cause a rich mixture, while an air leak may create a lean condition."
Old February 5th, 2005, 05:42 PM   #7
Hmm....I never changed that either! hahaha....
where is it located on I4's?
hondaboi is offline   Reply With Quote Quick reply to this message
Old February 5th, 2005, 05:45 PM   #8
original member!
Nittanys1's Avatar
its right on top of the valve cover, right above the words....
Old February 5th, 2005, 05:46 PM   #9
hmm...ill go and check it when I get home...does that thing just pop out? or do I need tools to remove it to check?
Old February 5th, 2005, 06:00 PM   #10
original member!
Nittanys1's Avatar
yeah comes right out
Old June 26th, 2005, 09:30 PM   #11
Thanks for the good write up abram2001. I just checked mine. The instructions were great, but I think it takes more like 5 minutes, not 93 seconds. I didn't need a screw driver, the cover just comes right off after being unbolted. I have 72,000 miles on my '98 but the PCV still rattled, so I put it back in. Mileage is also the same now (well, a little better actually since I put in the throttle body spacer and performance headers) as when it was new, so I dunno why it isn't clogged, but it doesn't seem to be.
Muteki is offline   Reply With Quote Quick reply to this message
Old March 4th, 2006, 01:41 PM   #12
did u guys have liek orange brown oil around the old pvc valve?
madaccord is offline   Reply With Quote Quick reply to this message
Old March 5th, 2006, 10:45 PM   #13
the Lost Sol
KhanhCord's Avatar
so i can go anywhere to buy 1 and its a honda universal part ?
Old March 6th, 2006, 09:08 PM   #14
i got mines at Kraegen, $3.99, smoother idle, mines is made by Fram
Old April 29th, 2015, 12:35 PM   #15
How to I unclog cpv clogage? I replaced it, but engine light still comes on, can't pass smog. I replaced EGR valve already as well, but I may have to clean out the clogage. How do I do this? It's 2001 Honda Accord
Jentha3 is offline   Reply With Quote Quick reply to this message
