Can anyone get cam specs from honda/acura? - Honda Accord Forum : V6 Performance Accord Forums
Old April 30th, 2003, 05:45 PM   #1
Guys, we have been trying to figure out which cam is better, the type-S cams or the 03 accord cams [J30A4]
We already have the lift numbers, but thats it. If ANYONE can get us duration numbers, especailly at .050 tappet lift, and lobe seperation that would be extremely helpfull!
Old May 1st, 2003, 10:04 AM   #2
Senior Member
Yes, somebody please try and pull some strings to get this info......Hey Tom, is there anywhere I could take the cams to get this information figured out?
2000 Honda Accord LX V6 Coupe,
The L stands for Lite!
Mods:
1. AEM SR
2. Thermal R&D Exhaust w/pre- muffler cut out
3. Denso Iridium IK16
4. Hayden 677 Tranny Cooler
5. UR Pullies
6. Magnefine Tranny Filter
7. TB Coolant Bypass
8. Nex SR coilovers
Soon To Come:
either a CL-S or 7th gen
Fastest 0-60 Time: 6.93 on 4/11/03
ssjpatrick is offline   Reply With Quote Quick reply to this message
Old May 1st, 2003, 01:52 PM   #3
Yeah pat, if you take a cam to a good machine shop they can get the specs off it for you. I forgot you are ordering the J30A4 cams, and toby [Ei-ccord] already has some type-S cams. SWEET! You guys just got recruited to figure this out!
Old June 5th, 2003, 05:42 AM   #4
Senior Member
Tom, unfortuantely I'm in Europe right now, I didn't get a chance to take the cams to a machine shop before I left.....I'll do it when I get back though....I really want to get this porject on the roll....
Old July 17th, 2003, 05:58 AM   #5
update please
AzN Retribution is offline   Reply With Quote Quick reply to this message
Old July 21st, 2003, 04:46 PM   #6
I don't think patrick is back from europe yet. If he is, hes too busy to do anything yet. I have yet to have someone offer to get their type-S cams checked at a machine shop.....
Old July 22nd, 2003, 09:43 AM   #7
Well, I at least have the duration numbers for the stock J30A1 cams. In non-vtec we have 194/200 @.050
In VTEC mode its 215/[email protected]
Old September 20th, 2003, 08:49 PM   #8
I couldn't find this anywhere else so I'll post it here. These are cam lobe height (top to other side) in millimeters.
Code:
Engine: Primary, VTEC,   Secondary, Exhaust
J30A1:  34.615,  36.210, 31.188,    36.076 (1997-1999 3.0CL 1998-2002 Accord V6)
J30A4:  35.041,  36.445, 35.284,    36.326 (2003-? Accord V6)
J32A1:  34.615,  36.272, 31.188,    36.076 (1999 3.2TL)
J32A1:  34.737,  36.445, 34.919,    36.326 (2000-2003 3.2TL 2001-2003 3.2CL)
J32A2:  34.737,  36.445, 34.919,    36.389 (2002-2003 3.2TL Type S 2001-2003 3.2CL Type S)
J32A3:  35.041,  36.445, 35.284,    36.326 (2004-? 3.2TL)
J35A1:  35.832,  N/A,    31.066,    35.763 (1999-2001 Odyssey)
J35A3:  34.737,  36.445, 34.919,    36.326 (2001-2002 MDX)
J35A4:  34.737,  36.445, 34.919,    36.326 (2002-? Odyssey 2003-? Pilot)
J35A5:  35.041,  36.445, 35.284,    36.326 (2003-? MDX)
I thought there was more of a difference than just the exhaust between 2000+ Type S and non-Type S cams. It also looks like the 1999 TL has crappy cams. I'm not sure I want to try a 1999 TL PCM swap anymore. Below are the official Honda part numbers.
1997-1999 Acura 3.0CL, 1998-2002 Accord V6
14100-P8A-A00 FR CAMSHAFT
14200-P8A-A00 RR CAMSHAFT
1999 3.2TL
14100-P8E-A00 FR CAMSHAFT
14200-P8E-A00 RR CAMSHAFT
2000-2003 3.2TL, 2001-2003 3.2CL, 2001-2002 MDX, 2003-? PILOT
14100-P8E-L00 FR CAMSHAFT
14200-P8E-L00 RR CAMSHAFT
2001-2003 3.2CL Type S, 2002-2003 3.2TL Type S
14100-PGE-A00 FR CAMSHAFT
14200-PGE-A00 RR CAMSHAFT
1999-2001 Odyssey
14100-P8F-A00 FR CAMSHAFT
14200-P8F-A00 RR CAMSHAFT
2002-? Odyssey
14100-P8F-A01 FR CAMSHAFT
14200-P8F-A01 RR CAMSHAFT
2003-? Accord V6, 2004-? 3.2TL
14100-RCA-A00 FR CAMSHAFT
14200-RCA-A00 RR CAMSHAFT
2003+ MDX
14100-RCA-A10 FR CAMSHAFT
14200-RCA-A10 RR CAMSHAFT
99%StockAV6 is offline   Reply With Quote Quick reply to this message
Old September 21st, 2003, 11:59 AM   #9
Senior Member
VTEC_V6's Avatar
Send a message via AIM to VTEC_V6 Send a message via Yahoo to VTEC_V6
Are these lift numbers? And doesn't the J30A4 use a 3 rocker arm VTEC system? Does anyone know if this will work?
VTEC_V6 is offline   Reply With Quote Quick reply to this message
Old September 25th, 2003, 02:03 PM   #10
So the 99 TL not only uses the accords 4sp auto but also its cams, poor TL
The 03 MDX uses the same cams as the 03 accords, which by lift numbers alone seem to be the best cams, BUT we still don't have duration numbers. Lift is great and all, but duration is whats important.
VTEC-V6, you'll notice ALL cams have less duration in non-VTEC mode on one side compared to the other. This is to induce swirl and improve combustion efficancy and emissions
Old June 26th, 2006, 01:43 AM   #11
so wich is better
the J30A4 or the J32A2 camshafts for my J30A1 Accord?
My accord is a 99 Accord Coupe V6 do i need another modification plus the camshafts?
bernardo is offline   Reply With Quote Quick reply to this message
Old June 26th, 2006, 06:15 AM   #12
didnt someone finally come to the conclusion that the j30a4 wont fit, the j30a2 you can get them, but you have to get them machined. someone on here has one left that is machined, i dont know about 98-99 but you might only need the one. one of the mods has them
mike_d is offline   Reply With Quote Quick reply to this message
Old June 26th, 2006, 06:46 AM   #13
GT35R Turbo'd 3.5L AV6
logonzojls's Avatar
The 03+ AV6 Cams won't fit the 98-02 AV6 or the CL. The 03+ AV6 cams are a few Millimeters longer, so as stated above unless machined they won't fit.
logonzojls is offline   Reply With Quote Quick reply to this message
Old June 26th, 2006, 11:24 AM   #14
So where can i find the J32A2 camshafts
and where can i get them machined?
and all this really worth it?
Old June 26th, 2006, 05:36 PM   #15
the total cost with installation is like 700 or 800 dollars i think, maybe 600..thats what i payed if im remembering correctly. its good to get your timing belt and water pump changed to if you have high miles, honda suggests 105k for the v6. you get better low end with good valve adjustment and you wil prolly want to tune it somehow. if you end up supercharging, the gains were not that significant as per someone else experience, i think it was like 5hp increase on supercharged apps. or something like that. but for n/a go for it if you got the money to spend. you can do a search on here for a place to buy them, all the info that i have stated except for the price that i payed was found by searching through the forum. sorry i cant recall the place to buy them. try honda or acura places, bu they will be cheaper online, you can find the part numbers on here somewere.
oh the prices i said were not including machining or timing belt and waterpump.
hope that helps and if i was incorrect about something and someone catches it correct me but i think it was accurate
Old December 14th, 2009, 09:24 PM   #16
Dani01c's Avatar
so, which ones are better for a 2001 J30a1? CL-S or TL-S??
Dani01c is offline   Reply With Quote Quick reply to this message
Old February 25th, 2010, 08:14 AM   #17
hate doing motor mounts
Supasnipa360's Avatar
^they are the same
Supasnipa360 is offline   Reply With Quote Quick reply to this message
Old June 30th, 2013, 07:10 PM   #18
Lumpy's Avatar
Anyone ever come up w/ the lift & duration #s for the j32a2?
Lumpy is offline   Reply With Quote Quick reply to this message
