Mounting Hella Trumpet Horns?? How do I do it? - Honda Accord Forum : V6 Performance Accord Forums
Old April 30th, 2003, 10:46 PM   #1
DV8
Hella Functional
DV8's Avatar
Anyone have directions how?
Function > Form "A show car may not be a race car, but a race car is always a show car."
Old May 2nd, 2003, 09:29 AM   #2
PitchBlk, aka BigLou 7
Loulax07's Avatar
i'd like to know how too
i think i know how to tap them in, just need some help
if we STILL had our old threads, someone replied to my question bout this, but cant find it now
Old May 2nd, 2003, 12:33 PM   #3
DV8
Hella Functional
DV8's Avatar
I just got some info from peter aka Illusion from SHO
You should get the horns, a compressor, some air tubing, a little wiring, and a relay. To hook them up. Find a home for the horns. Mine are on the on the drivers side of the radiator firing down. I just zip tied them to the post there. The compressor If bolted to the bar where the air box used to be since I have a CAI, if you don't have one just find a nice place to bolt it down. Run the tubing from the compressor to the horn. Last take the relay, connect one coil to the ground and the other coil to the stock horn honk wire(If I remeber it's a green wire, and there's only one, the stock horns are grounded through their base if I remember right). Then take one pole and connect it to the + on the battery and then the other pole to the + on the compressor. Ground the other lead on the compressor and you're all set. Be forwarned they are freaking loud. Even with the horn pointing down it makes me sick to my stomach if I stand in front of the car and honk it. I'll post some pics on my site either tomorrow or saturday so you can see what the heck I'm talking about.
hope that helps a little.
Old May 5th, 2003, 08:37 AM   #4
Loulax07's Avatar
DV8- did u install these yet?
Old May 5th, 2003, 10:16 AM   #5
DV8
Hella Functional
DV8's Avatar
not yet, i should be getting these today.
hopefully, i can have time to work on them some time this week.
Old May 9th, 2003, 05:24 PM   #6
Loulax07's Avatar
horns installed
i used the above DIY to install em
only installed one tho
need more clear tubing........
Old May 20th, 2003, 08:26 PM   #7
how much did u guys purchase these for and where?
white_akord00 is offline   Reply With Quote Quick reply to this message
Old May 20th, 2003, 08:28 PM   #8
Loulax07's Avatar
i think they were like 27
autobarn
Old May 20th, 2003, 08:48 PM   #9
ok theres two diff kind of hella's on that site. i heard the trumpet looking ones aren't that good and the other ones are better. they are the ones that are two flat things look like those big piaa fog lights for suvs, and they are for like $67....
Old June 3rd, 2003, 09:47 PM   #10
DV8
Hella Functional
DV8's Avatar
I got mine from here http://www.susquehanna.com/susq/hella/85105.htm
I just installed mine yesterday. It was pretty straight forward. It took me about 2 hours because I had to learn it while doing it.
Overall it is a pretty good mod for 30 bucks. It's A LOT louder, and has a higher tone. Omg, i scared the **** outta my friend by pulling up behind him and riding hte horn
Old June 3rd, 2003, 10:03 PM   #11
these are the ones http://catalog.com/susq/hella/85115.htm
morpheus6d9 is offline   Reply With Quote Quick reply to this message
Old June 3rd, 2003, 10:37 PM   #12
DV8
Hella Functional
DV8's Avatar
i have both, and i like the trumpets better
