maintence - Honda Accord Forum : V6 Performance Accord Forums
Old April 29th, 2006, 04:31 AM   #1
maintence
My car is about to hit 60K...I need suggestion!!!
Should I bring it to the dealer and let them take acre of the 60k maintence...OR
should i just go ahead and do it myself..basically what is needed to be done when it hit 60K????any suggestion or help would be great!...I would love to save as much a money as I can..please help!!!!!!
kc1023 is offline   Reply With Quote Quick reply to this message
Old April 30th, 2006, 04:05 PM   #2
JB4 e92
clean2draccord's Avatar
If you can do an oil change and basic check-up on some components listed, you should be able to avoid the trip to Honda.
Originally Posted by clean2draccord
6th Gen Scheduled Maintenance found here:
http://www.v6performance.net/forums/...ad.php?t=41999
From http://www.ahm-ownerlink.com/
Normal: The "normal" schedule is fine for most drivers, even if they occasionally drive in severe conditions.
60,000 miles/4 yrs Scheduled Maintenance
- Replace engine oil, filter and drain plug washer with Genuine Honda Parts.
- Inspect and rotate tires.
- Inspect wiper blades.
- Check/adjust fluid levels.
- Road test.
- Replace air filter with Genuine Honda Parts.
- Inspect belts, hoses, fuel lines and exhaust system.
- Inspect front and rear brake assemblies.
- Inspect steering system, suspension components, alignment and parking brake.
