How to install a radio on 98-02 accords. - Honda Accord Forum : V6 Performance Accord Forums
Old July 22nd, 2003, 09:37 PM   #1
Senior Moderhater
abram2001's Avatar
Just right click this and save as onto your computer
Good Luck
Right Click Here for Instructions
Old July 22nd, 2003, 10:02 PM   #2
good find
Old July 22nd, 2003, 10:04 PM   #3
Senior Moderhater
abram2001's Avatar
maybe the mods will make this a sticky
Old July 22nd, 2003, 10:04 PM   #4
___
borinka99's Avatar
yea, and get the wiring harness, it makes things 100x easier, you can uninstall and install your radio in a minute if you have the harness attached to it
borinka99 is offline   Reply With Quote Quick reply to this message
Old July 22nd, 2003, 10:15 PM   #5
Very nice instructions for the n00bs . Though I wonder why the document says 1999-2001 Accord.
Anyways this should be a "sticky"
Great find abram2001
Old July 22nd, 2003, 10:16 PM   #6
Old Member
Du3ce's Avatar
a little too late for me
Old July 22nd, 2003, 10:40 PM   #7
*SPLAT*
Old July 22nd, 2003, 10:42 PM   #8
Senior Moderhater
abram2001's Avatar
Originally posted by illusion on July 23rd, 2003 at 12:40 AM
*SPLAT*
thanks illusion for sticking it to me, I mean sticking this for me
Old July 23rd, 2003, 06:33 AM   #9
booooootiful find man...
Old July 27th, 2003, 12:02 AM   #10
you da man...
Hai_c83 is offline   Reply With Quote Quick reply to this message
Old September 18th, 2003, 10:45 PM   #11
Something Something Darkside
Doom's Avatar
About the wiring harness. If I have an aftermarket radio and got another one do I need a new harness? I don't know jack about audio. What about Alpine to Alpine?
Old October 3rd, 2003, 09:55 PM   #12
ok! i have two questions
1st -- how the heck do you keep the from losing the botton two screws that old the radio in!? they're not really magnetic, and i almost lost one. my fingers are too big and it's VErY risky to have the screws sit on the tip of the screwdriver. i hope someone knows what i'm talking about.
2nd -- i read that with the stereo tehre should be a 10amp fuse (for alpine). i JUST thought of this, the fuse is in the fuse box, right? the last time i installed an alpine i didn't put a fuse in there.
question #1 is way more important though, thanks
djradam is offline   Reply With Quote Quick reply to this message
Old October 3rd, 2003, 10:31 PM   #13
Senior Moderhater
abram2001's Avatar
For question #1 just get a magnetic tip scredriver, they are really affordable these days, or if you lose it just get a telescoping magnet. Those are a life saver. Or just stick some adhesive or gum on the top of the screw, and pray it will hold
Old October 29th, 2003, 02:23 PM   #14
Just an FYI, in case anyone is reading the comments:
I had purchased a stereo mounting kit for my 2K Accord, but when I pulled the original stereo out, I noticed that the brackets that hold it on are universal for 6th gen Accords. That means that LXs (with the storage bin below the radio) use the same brackets. So instead of purchasing a mounting kit, one can order the storage bin box from a Honda dealer (or get the part # and order from the net, I had it once but not anymore), and use the brackets to mount directly to your new stereo (note: you do NOT need the cage at this point). Then bolt the brackets back onto the dash. Very factory look, and you dont have to worry about the cage.
And the storage bin wasnt much more expensive than the mounting kit.
-Chris
chrisexv6 is offline   Reply With Quote Quick reply to this message
Old October 29th, 2003, 07:54 PM   #15
i second doom's post. i have a kenwood deck with a wiring harness, & if i want to change to pioneer or alpine will the harness still work?
SwTbeB4Lyfe43 is offline   Reply With Quote Quick reply to this message
Old October 29th, 2003, 08:16 PM   #16
You can just chop the wires in half, or just buy a new harness adapter. I usually cut mine off for the first two changes, after that I feel its too hacked and buy a new one.
Just make sure you keep track of the wire colors from the harness adapter and make sure you solder them to the correct leads on the new Alpine harness. Luckily, the few leads that you can do the most damage with by reversing (switch +12V, constant +12V, and ground) are all the same colors across any kind of harness, so you only really risk reversing speaker leads which isnt so bad.
-Chris
Old October 30th, 2003, 10:19 AM   #17
Great idea on the LX storage bin Chris
V-Tectonic is offline   Reply With Quote Quick reply to this message
Old October 30th, 2003, 11:59 AM   #18
I should work fine. It just depends how much wire is left on the adapter harness. I solder my connections, so every new stereo only get's about 1/4" of wire cut off, so there's be plenty of wire for 20 or so stereos. I would just un solder them but I'm usually to lazy and opt to just lop off the soldered part. It just depends how much wire you use each time. The wire colors are universal colored at least for the major harness makers(metra, scosche) so if you forget the colors just look them up online somewhere.
here's the typical wire colors
Old October 30th, 2003, 04:19 PM   #19
has anyone tried using that pdf file to install on a 2002? does it work? it says only 98-01
Old October 30th, 2003, 06:44 PM   #20
at the time it was created 2002 wasn't out yet. 2001 and 2002 are IDENTICAL.
Old October 30th, 2003, 10:57 PM   #21
coo thanks. just dont wanna get a brand new spankin deck n not know how to install it!
Old December 5th, 2003, 01:12 PM   #22
member since forever
VTECK999's Avatar
how different is removing an already installed aftermarket radio? Does the dash piece need to still be removed? If not, how is it taken out?
VTECK999 is offline   Reply With Quote Quick reply to this message
Old December 14th, 2003, 07:49 PM   #23
i'd like to kno too. i'm still thinkin about whether to change from kenwood to pioneer
Old January 18th, 2004, 11:19 PM   #24
If an aftermarket cd player was installed using a cage, then radio removal keys will allow you to take out the deck. You just need to take off the face, take out the trim piece, slide the keys in and pull.
Old April 8th, 2004, 09:55 PM   #25
Drop Dead Gorgeous
Aztro's Avatar
Send a message via AIM to Aztro
I have an EX model, so I can use functions on my steering wheel. If I changed the CD receiver those functions on my wheel would not work correct?
Aztro is offline   Reply With Quote Quick reply to this message
Old April 8th, 2004, 10:45 PM   #26
http://www.v6performance.net/forums/...der=descending
Look for PAC SWI-X specifically, although simpley searching for steering wheel remotes gives quite a few hits.
Old April 9th, 2004, 08:34 AM   #27
Drop Dead Gorgeous
Aztro's Avatar
THanks.
Old May 16th, 2004, 05:18 PM   #28
CG1 Driver
Send a message via AIM to ATran Send a message via MSN to ATran
where can i get a storage bin with the lid? ive been looking forever and i give up! thanks
ATran is offline   Reply With Quote Quick reply to this message
Old May 17th, 2004, 09:32 PM   #29
Founder of PsychoLemon CC
DeadDoc's Avatar
Send a message via ICQ to DeadDoc Send a message via AIM to DeadDoc Send a message via MSN to DeadDoc Send a message via Yahoo to DeadDoc
Now my car has 6 speakers, 2 tweeters at top dash, 2 front doors, and 2 rear. Is the wirering still the same? Bc whats is shown is only 4 speakers.
DeadDoc is offline   Reply With Quote Quick reply to this message
Old November 4th, 2005, 12:44 AM   #30
in the Motorcity baby!!!
Send a message via ICQ to mlrtimev6 Send a message via AIM to mlrtimev6 Send a message via MSN to mlrtimev6 Send a message via Yahoo to mlrtimev6
being bitter about my avic-d1 being stolen I want this sticky taken down NOW! hahah j/k BUT there is also a way to theft proof your radio that some of you may want to think of while doing a headunit install. It can't stop them but it will sure slow them down.
Step 1
Notice the four phillips/hex screws that bolt the mounts to the radio to the chassis, take one of these to Lowes/Home depot and find the same thread but in different head types. For example I have 2 allan heads, 1 oem phillips, and 1 bit spanner screw holding my radio in. It would take THREE tools to simply unbolt my radio and hopefully no thief would be carrying all 3.
Step 2
There are 2 very solid structural supports on either side behind your radio, you'll notice some substantial bolts running through them. I ran a wire strap from the screws on the side of my radio that run through the mounting bracket and into the head unit to these bolts on the structural tubing. These were installed between the headunit and the side mounting brackets, and then once the unit was in place i used the slack to bolt it up. (I can take a pic later to explain)
None of this can prevent a theft of course but hopefully will give you enough time to either catch them and find your baseball bat or hopefully make them give up (most thiefs don't like to spend all day trying to remove a headunit.... looks a little suspicious)
mlrtimev6 is offline   Reply With Quote Quick reply to this message
