tuneup at 60k? - Honda Accord Forum : V6 Performance Accord Forums
Old August 29th, 2006, 12:35 PM   #1
tuneup at 60k?
My dad does my oil changes and did a transmission fluid change once as well. I was wondering if there is anything else I need done since I haven't gone in for regular honda maintence.
Old August 30th, 2006, 08:01 AM   #2
do u drive ur car hard? hows ur tranny holding up? at 60k u gotta check like everything except timing belt! gl
Old September 11th, 2006, 09:40 PM   #3
i believe that when we hit 100k , then we turn up.
02SilverAcc2dr is offline   Reply With Quote Quick reply to this message
Old September 11th, 2006, 09:47 PM   #4
Champaned_out's Avatar
60k is a bit early for the full tune up... its probably a good time just to check your spark plugs, belt, pcv valve, plugs, and all the other little things like that
100k is usually the major tune up.. but alot people do it when they hit 80k-90k
my major tune up is comming up as well.. im at 74k
2001 CG5 Deep Blue Metallic Honda Accord EX
Old October 3rd, 2006, 12:38 PM   #5
my car isn't in gear untill 2,000 rpm and then it slams into gear. what the hell is goin on with it
slvr2000v6 is offline   Reply With Quote Quick reply to this message
Old October 3rd, 2006, 12:40 PM   #6
(つ◕‿◕)つ*.★.*.★.* .★.
Red02AccordV6_2's Avatar
http://www.v6performance.net/forums/...ead.php?t=9664
▬▬▬▬▬▬▬▬ஜ۩۞۩ஜ▬▬▬▬▬▬▬▬
