Installation Instruction for SPE Helix Throttle body spacer - Honda Accord Forum : V6 Performance Accord Forums
Old July 25th, 2003, 11:25 AM   #1
Senior Member
aCcOrDv6VTEC3R's Avatar
SPE Helix Throttle body spacer Installation
From everything you see above, only things you will be using are the gaskets and the SPE Helix spacer.
The bolts included are too short. You will need to get longer bolts.
You will need 4 8mm x 1.25 x 70mm bolts. I got the last four they had at the Home Depot.
1. Take your intake off
2. Take off the cover that covers the throttlebody. 2 plastic screws. Turn it half way and pull it of
3. There are 2 screws securing the throttle likage on to the throttle boty. Unscrew those. Set the screws a side
4. There are 2 bolts and 2 nuts securing the throttle body. Take those off.
5. There are 2 long studs where the nuts were unbolted from. Take a plier and unscrew these.
Red in the picture
6. Throttle body isn't just gonna fall so don't worry. It's stuck to the gasket to the stocke throttle spacer to another gasket (which you will be scraping off) to the intake manifold)
7. Shake the throttle body lose.
8. let the throttle body hang on the side and start scraping off the nasty green gasket. It might take a while but scrape them all off.
9. Time to put the spacer in. Put everything back together in this order from intake manifold.
new gasket, SPE Helix spacer, gasket, stock spacer, stock gasket, throttle body spacer.
10. Secure these wit your 4 new longer bolts (8mmx1.25x70mm).
11. Torque it to 15 ft/lbs.
12. put the throttle linkage back on. screw two screws back in ( don't drop these. I dropped mine when mosquito landed on me and I tried to flick it off. Took me about half an hour just to find the screw in the dark )
13. Put your intake and engine cover back on
If you have stock airbox. You can squiz the tube in there and use the stock mounting holes
If you have aftermarket intake, drill a new hole or cut your intake or ______.
14. Reset the ECU. Pull out the Clock/Backup fuse in the passanger side fusebox, put it back in.
15. Drive around
Link to more pix
http://www.imagestation.com/album/pi...&id=4291126439
Old July 25th, 2003, 11:39 AM   #2
Senior Member
hey howcome my pix arent working? oh well
Old July 25th, 2003, 11:48 AM   #3
Senior Moderhater
abram2001's Avatar
the pics work fine for me, thanks for the good info
Old July 25th, 2003, 01:02 PM   #4
Bri
Car Enthusiast
Bri's Avatar
Send a message via ICQ to Bri Send a message via AIM to Bri
Thanks a lot man!
"Those who cannot remember the past are comdemned to repeat it."
"If everything seems under control, you're just not going fast enough."
-Mario Andretti
Bri is offline   Reply With Quote Quick reply to this message
Old July 25th, 2003, 02:25 PM   #5
Senior Member
pictures arent showing up. pix are just linked.
wth
Old July 25th, 2003, 03:06 PM   #6
what i did to get the 2 thread screw is put the nut back on after i got the trottle body off and tighen then loosen this removed it the easyest i tryed plyer but it didnt get enought of a grip and kipt sliping
Old July 26th, 2003, 08:35 AM   #7
Bri
Car Enthusiast
Bri's Avatar
Does anyone have an idea how to mount the AEM SR Intake without drilling a hole? Help would be appreciated!
Just don't want rust to start creeping up. Thanks!
Old July 26th, 2003, 10:09 AM   #8
i just installed mine with my AEM SR. i didn't have a pipe cutter so i kind of squeezed it in. the rubber mount is not diagonal, so i don't think i will leave it like that for long. i'm thinkiing to borrow my friend's pipe cutter and slice off 1/2 inch from the end so the mounts will line up nice. and yea, green gasket is a biznatch to scrape off.
lengjai223 is offline   Reply With Quote Quick reply to this message
Old July 27th, 2003, 11:53 PM   #9
i used some of the spare parts that came with the helix...check it out
http://www.imagestation.com/picture/...4/fb9667c9.jpg
don't know if any of you guys had any problems with the hoses, i think it's the AC lines.
http://www.imagestation.com/picture/...e/fb966785.jpg
more pic's...http://www.imagestation.com/album/?id=4289590983
aRnL4L is offline   Reply With Quote Quick reply to this message
Old July 28th, 2003, 01:24 AM   #10
Bri
Car Enthusiast
Bri's Avatar
That's what I'm talking about. It's kind of a connector from the intake mounting point to the circular thing that mounts on the fender well of the car.
Thanks very much aRnL4L for the pics. What bracket did you use? Also the bolts? Is the intake shaking or something? I hope that by doing this, there's no extra tension on the intake and throttle body since it's not fully supported. I hope to hear from you soon. Thanks again for the help.
-Mario Andretti
Old July 28th, 2003, 03:01 PM   #11
Used the only bracket supplied with the kit, and 6mmx25mm bolt and nut.
The intake is very secure, no shaking whatsoever, it's nice and stable. Might just get a longer hose to release the tension the spacer created (2nd pic).
Old July 30th, 2003, 04:49 PM   #12
Hey, replace that hose with a longer one. I left mine stretched (slightly) and lost that coolant hose. It made a mess and I had to replace the hose at work. The car's temp. soared to the red.
wingman is offline   Reply With Quote Quick reply to this message
Old July 30th, 2003, 05:02 PM   #13
Bri
Car Enthusiast
Bri's Avatar
What hose? Could you point it out'? Thanks! I'm planning on installing mine soon. Thanks again!
-Mario Andretti
Old July 30th, 2003, 06:50 PM   #14
Second picture a couple (maybe three) of post up. It's a right angle coolant hose (I think it's 5/8") that is located under the throttle body. You can see the clamp in the picture.
Actually you will know when you pull the throttle body.
I hope that helps.
Old July 31st, 2003, 01:15 AM   #15
Thanks for the warning . Was thinking of leaving it for a while, but now i'm replacing it ASAP. Thanks again
Old July 31st, 2003, 08:24 AM   #16
Bri
Car Enthusiast
Bri's Avatar
Wingman,
Thanks for the warning. Getting mine installed this weekend. Where could I buy the hose and what's the size? So that I could buy it before taking off anything. Thanks! I'll just buy it with the 4 bolts needed. Thanks!
Old July 31st, 2003, 09:29 AM   #17
Originally posted by Bri on July 31st, 2003 at 03:24 PM
Wingman,
No problem, glad to help.
I checked the size of that hose, and it's 5/16" or 8mm inside diameter. You can buy this hose at any auto parts store (Pep Boys, kragen or Autozone). I couldn't find coolant line specific hose so I used fuel line. Buy about 18", incase you make a mistake in cutting (you will problaby use only half of that). Also, you might want to replace the hose clamps with one's that screw tight. The outside diameter of the new hose may not be the same as the stock.
Old July 31st, 2003, 09:38 AM   #18
One other thing. Make sure you have enough threads going in the the intake manfold. Some people recommended 8X65mm bolts, 8X70mm worked better on my '97 3.0 CL. You risk striping out the threads if their too short. So beware.
Old July 31st, 2003, 11:26 AM   #19
Senior Member
used 8 70mm
Old July 31st, 2003, 12:30 PM   #20
Bri
Car Enthusiast
Bri's Avatar
For everyone who has the old version of the Helix Power Tower, what part number was in the box? I have 91003... Did all of you get the same? Thanks!
-Mario Andretti
Old August 4th, 2003, 11:38 AM   #21
I have the old one that whistles. The part number is the same.
How did your install go, Bri?
Old August 4th, 2003, 12:57 PM   #22
Bri
Car Enthusiast
Bri's Avatar
Wingman,
Thanks for asking man... I'm having troubles removing the 2 studs on the top portion of the TB, I've already removed the 2 nuts from them though. I also hope I won't be having problems with the hoses.
The car has been sitting in the garage for more than 24 hours without power from the battery. should I need to bother reseting the ECU when I fire the engine up? Coz I've read before that the ECU will reset itself when it has no power supply for 24 hrs? Thanks
Old August 4th, 2003, 03:03 PM   #23
The easy way to remove those studs is to thread the two nuts the one's you just removed, into one of the studs, thighten the nuts against eachother, then use a socket and remove the stud just like a bolt.
Removing the cables to the battery for 10 to 20 min. should be sufficent, to reset the ecu, so 24 hours... would be more than enough time. So no need to remove the fuse to reset the ecu, you are doing the same when you removed the power cables.
Just bored to death at work.
Old August 4th, 2003, 03:33 PM   #24
Bri
Car Enthusiast
Bri's Avatar
Toby already told me that but there's not enough room for the 2 bolts in that 1cm stud sticking out.
Old August 4th, 2003, 03:44 PM   #25
"1 cm"? Is this before you removed the bottom two bolts and pulled the throtle body out?
Old August 5th, 2003, 11:16 PM   #26
Bri
Car Enthusiast
Bri's Avatar
I've already installed the Helix and my AEM SR intake! Sounds so nice! BTW, the intake filter is hitting the side fender well in the engine. Is this ok? Won't this decrease the efficiency of the intake coz there's less air coming in? Just curious...
I wanna say a BIG THANK YOU to Toby (Ei-ccord) and David (aCcOrDv6VTEC3R) for helping me out with all of my pesky questions... Thanks guys!!! I really appreciate it!
-Mario Andretti
Old September 28th, 2003, 10:17 PM   #27
yah
It seems like i will be needing a torque wrench, so i went out and look for some. they were like $50 bucks, can't afford this right now. Do I have to use a torque wrench to torque it to 15ft/lbs. Can't i just tighten the bolt with a regular wrench?
yah is offline   Reply With Quote Quick reply to this message
Old September 28th, 2003, 10:32 PM   #28
yah
Old September 28th, 2003, 11:17 PM   #29
Senior Moderhater
abram2001's Avatar
yeah, its fine. Dont SUPER tighten it, just use your judgement to decide if its tight enough. You really dont need to torqu it exactly imo.
Old September 29th, 2003, 01:50 AM   #30
why not?
sheep208 is offline   Reply With Quote Quick reply to this message
