Need help with wheel offset! - Honda Accord Forum : V6 Performance Accord Forums
Old November 19th, 2008, 07:22 PM   #1
OmBoY
omboy's Avatar
Send a message via Yahoo to omboy Send a message via Skype™ to omboy
I'm thinking about buying this wheel for my 6th gen sedan but i don't know if this offset will work or not.
17x7+35 17x8+36
omboy is offline   Reply With Quote Quick reply to this message
Old November 19th, 2008, 07:38 PM   #2
Senior Member
csmiths98AV6's Avatar
well i have 18x7.5 +35 and mine sit FLUSH with the fender, so you might have to camber in the rears a little, but shouldnt be drastic
csmiths98AV6 is offline   Reply With Quote Quick reply to this message
Old November 20th, 2008, 04:37 AM   #3
hella flush
lilfotoman's Avatar
you should be good. run 215 or 225 tires.
Old November 20th, 2008, 02:52 PM   #4
Senior Member
agreed id run 215's bc there should be less of an issue if there is one at all
Old November 21st, 2008, 02:15 AM   #5
Destroyer of Tires
Doctor_X's Avatar
They will fit for sure. I just hope you're low enough so that the car naturally cambers the wheels in.
Old November 21st, 2008, 11:51 AM   #6
You will probably have to go with 215/40 tires or even 35 depending on drop. But those should look sick on a sedan
alexd10 is offline   Reply With Quote Quick reply to this message
Old December 4th, 2008, 09:42 PM   #7
baknoy
baknoy's Avatar
Send a message via MSN to baknoy
damn i love your accord !!! im jealous mouahahahah
baknoy is offline   Reply With Quote Quick reply to this message
Old December 4th, 2008, 09:44 PM   #8
baknoy
baknoy's Avatar
how can i put 18x8 38 offset with 3 1/2 inch drop without rubbin ... i had 18x7.5 42 offset and i rub behind with my drop
