Test fitted 9.5 - Honda Accord Forum : V6 Performance Accord Forums
Closed Thread
Old December 21st, 2008, 10:37 PM   #1
Hector Ochocinco
HECz_'s Avatar
Send a message via AIM to HECz_
Test fitted 9.5
So I went to a local shop and test-fitted some Racing Hart c2s
18x9.5 +45
Like 2 cool cats on the forum warned me, they rubbed (barely) on the rear strut/coilover . Now my concern is.. if I were to run 5-7mm spacers will I run into any problems? I know I need to roll my fenders, but is that all? I would need to run neg camber also since I'm pretty low (WTF am I saying.. I am running neg camber already) . Will the neg camber bring back the rubbing even with spacers?
Here are some pics
HECz_ is offline   Quick reply to this message
Old December 21st, 2008, 10:45 PM   #2
KT!
icantsleeps's Avatar
Send a message via AIM to icantsleeps
hmm -1.5 on the camber?
icantsleeps is offline   Quick reply to this message
Old December 21st, 2008, 10:47 PM   #3
Hector Ochocinco
HECz_'s Avatar
I think I'm already running a tad more on my current setup
lol
Old December 21st, 2008, 11:18 PM   #4
KT!
haha ride VIP status
Old December 21st, 2008, 11:23 PM   #5
hella flush
lilfotoman's Avatar
+45 way too high!!! go in the 30's and itll be sick!
lilfotoman is offline   Quick reply to this message
Old December 21st, 2008, 11:26 PM   #6
Hector Ochocinco
HECz_'s Avatar
How about a 7mm spacer? lol
Old December 22nd, 2008, 12:11 AM   #7
hella flush
lilfotoman's Avatar
that would work too. but i dont trust spacers....
Old December 22nd, 2008, 01:26 AM   #8
Hector Ochocinco
HECz_'s Avatar
Why not?
Old December 22nd, 2008, 10:01 AM   #9
Brad
bdeitemeyer's Avatar
I told you.
Use a measuring tape to determine exactly how much space you'll need to clear the strut. Keep in mind that you're test-fitting the wheels without tires on, so hopefully you'll be running stretched tires that won't stick out past the wheels' lips.
If you go with a quality brand of spacers & use the extended studs, you should be fine. You won't need to do anything more than roll your fenders & adjust your camber (if necessary). I just hope you're low enough to bring those wheels in flush with the body...
bdeitemeyer is offline   Quick reply to this message
Old December 22nd, 2008, 11:26 AM   #10
Destroyer of Tires
Doctor_X's Avatar
Originally Posted by HECz_ View Post
Why not?
They put more stress on your hub assembly and without extended studs they are dangerous. I wouldn't even feel comfortable running a 5mm spacer on stock studs. Supposedly you could run a 5mm spacer on stock studs without an issue, but as I said earlier, I wouldn't trust them unless you had extended studs.
If you don't do any sporty driving you shouldn't have a problem... But spacers to put more stress on your car simply because you're pushing the wheel weight out further by placing a piece of metal between your hub and your wheel. Just know that there is a possibility that if you run spacers you could still rub the strut when you go over a bump. It probably won't be sitting on the strut when parked but if you drive I'm pretty sure you'll have a chance of running into problems with rubbing the strut. I would try and get the offset in the 30s...
Just roll your fenders when you get everything said and done, and also make sure you are running a good tire size.
Originally Posted by 99cfENVYv6
"Yeah, yeah, yeah" - Doctor X
What is
Doctor_X is offline   Quick reply to this message
Old December 22nd, 2008, 12:01 PM   #11
hella flush
lilfotoman's Avatar
^ right on!
Old December 22nd, 2008, 01:05 PM   #12
Hector Ochocinco
HECz_'s Avatar
Hmm.. sounds like too much work...
Old December 22nd, 2008, 01:11 PM   #13
hella flush
lilfotoman's Avatar
just get the right wheels with the right offset. :]
Old December 22nd, 2008, 01:16 PM   #14
Hector Ochocinco
HECz_'s Avatar
Its such a good deal
But I guess I'll pass
Old December 22nd, 2008, 01:22 PM   #15
neeeeeeeeeeeeeeeeeeeeeeel
implayaz9's Avatar
i am running 5mm spacers and wont on my next wheels.. but stil looks clean
implayaz9 is offline   Quick reply to this message
Old December 22nd, 2008, 01:24 PM   #16
Brad
Rolling the rear, buying hubcentric spacers with extended studs and 225 tires is too much work?
Old December 22nd, 2008, 02:27 PM   #17
Bobby Lane Racing
nighthawk04v6's Avatar
waste of money to rock some wheels you can wrap nice tires around imo.
nighthawk04v6 is offline   Quick reply to this message
Old December 22nd, 2008, 04:34 PM   #18
Hector Ochocinco
HECz_'s Avatar
I need wheels before the end of the week. I would need to order some falken tires, spacers, and then get my fenders rolled. I'll probably buy them, but won't mount them yet.
Old December 22nd, 2008, 05:26 PM   #19
hella flush
lilfotoman's Avatar
why u need spacers?
Old December 22nd, 2008, 05:37 PM   #20
hmmm what next?
shonda1989's Avatar
it will rub if there isnt any
shonda1989 is offline   Quick reply to this message
Old December 22nd, 2008, 05:39 PM   #21
v not some model, my girl
99v6sedan's Avatar
spacers FTMFL
99v6sedan is offline   Quick reply to this message
Old December 22nd, 2008, 05:50 PM   #22
Hatin' on me hatin' on me
inspired1's Avatar
tim wants +18 offset. hahahaha.
inspired1 is offline   Quick reply to this message
Old December 22nd, 2008, 07:43 PM   #23
Hector Ochocinco
HECz_'s Avatar
it rubs on the rear strut/coilover. I would need at least a 5mm spacer to fix that.. and about 10-15mm to run neg camber to have the wheels flush!
i hope i'm right =
Old December 22nd, 2008, 08:43 PM   #24
hella flush
lilfotoman's Avatar
so problem solved. get a 9.5 with a +30, so need spacer needed. and then run some camber and good to go!
Old December 22nd, 2008, 10:18 PM   #25
Destroyer of Tires
Doctor_X's Avatar
Hector your diagram is sort of a good representation and sort of not. In some situations that would be a good and accurate way to look at it, but you should really see how much of a space is actually between the inside rim of the wheel and your strut when you are putting them on. You have to account for any bound that your car would experience, and how it would affect the travel inside your wheel wells. I'm not sure if you know this but whenever your shocks compress, more negative camber will ensue. So if you go through a nasty dip than there is a chance that you could still hit your wheels against your coilover.
Old December 22nd, 2008, 11:42 PM   #26
Hector Ochocinco
HECz_'s Avatar
Then I'll run a 25mm spacer! LOL
jk
I'll still probably buy them.. I won't mount them though.. at least not yet
Thanks Kevin, Brad
thank you all
Old December 23rd, 2008, 02:26 AM   #27
C.R.E.A.M.
1iLlaV6's Avatar
Send a message via AIM to 1iLlaV6
how would this fit on a 7th gen coupe guys? oh and im low as shiet.also what size tires for front and rear???
1iLlaV6 is offline   Quick reply to this message
Old December 23rd, 2008, 02:38 AM   #28
Destroyer of Tires
Doctor_X's Avatar
Same wheels specs will probably make you rub as well...
Old December 23rd, 2008, 09:00 AM   #29
Brad
What's your suspension setup HECz? A 10-12mm spacer should be enough to resolve the rubbing issues after you've rolled the rears. You shouldn't have to run a crazy amount of camber to make this setup work though.
Here's my 9.0 +38 rear for reference (http://farm4.static.flickr.com/3277/...b21778b9_o.jpg). The camber doesn't look too far off from the stock accord next to me. If the car was dropped another inch & a little bit of camber added, an extra 1/2 inch of wheel should be flush.
Old December 23rd, 2008, 10:02 AM   #30
implayaz9's Avatar
u should be fine.. its all about camber and tire size.
Closed Thread
