lowered car making dents in the fenders? - Honda Accord Forum : V6 Performance Accord Forums
Old February 13th, 2009, 12:29 PM   #1
xXxCLS bOoStEdXxX
slowaccord's Avatar
hey guys. ive noticed ever since i lowered the car to zero gap its been rubbing alot even on slight turns. if theres a big dip or pothole the rims slam into the fender. then i noticed that both front fenders are slightly dented from what looks like impact from the wheel.
anyone else having this problem. im running 19x8.5 with roughly 30-35 offset in the front and 225/35/19. thats probably the reason but i got a dent from 19x8.5 40 offset also. that one happened a week after i lowered it.
lol anyways just ranting. anyone else have this happen to them. the dents are very slight and you can only tell from an angle
Old February 13th, 2009, 12:59 PM   #2
Bobby Lane Racing
nighthawk04v6's Avatar
roll the fenders.
Old February 13th, 2009, 01:04 PM   #3
Very Inspired
haiyter's Avatar
Send a message via AIM to haiyter
or dont slam your car
haiyter is offline   Reply With Quote Quick reply to this message
Old February 13th, 2009, 01:07 PM   #4
New Member
aznfunkyflip's Avatar
or make it negative like others do ...
Old February 13th, 2009, 01:27 PM   #5
xXxCLS bOoStEdXxX
slowaccord's Avatar
lol u guys. the camber is already negative. ima get adjustable camber so i can tweak it more.
so has this happened to the rest of you guys that are slammed with decent widths and offsets. im sure if i go 7.5 inch width with pathetic offset this problem wont even come up. i might go with less wide wheels just so i can carry passengers.
Old February 13th, 2009, 02:05 PM   #6
New Member
to answer your question ... no.
Old February 13th, 2009, 02:38 PM   #7
MoneyPit's Avatar
roll 'em up, and get a 215/35 tire on there and you should be golden.
MoneyPit is offline   Reply With Quote Quick reply to this message
Old February 13th, 2009, 02:49 PM   #8
Bobby Lane Racing
Why would you roll them if you are going to rock 215's. Unless you got 0 offset or something LOL
Old February 13th, 2009, 03:14 PM   #9
MoneyPit's Avatar
^^^to avoid rubbing with a slammed car. i have a very similar setup, 19x8.5 +42 and 215/35s, i still had to roll mine to avoid the rub
Old February 13th, 2009, 03:34 PM   #10
Destroyer of Tires
Doctor_X's Avatar
My fenders aren't dented up but that's something you should honestly expect when you are either running large wheels or a big drop.
Old February 13th, 2009, 03:47 PM   #11
Hector Ochocinco
HECz_'s Avatar
Send a message via AIM to HECz_
I'm going to put on my 8.5 +37 Sunday.. Hopefully, like you I can get away without rolling my fenders.. since mine are 18s, shouldn't rub at all, right?
HECz_ is offline   Reply With Quote Quick reply to this message
Old February 13th, 2009, 04:08 PM   #12
New Member
depends on the size and brand of tires, and ofcourse ... how much drop.
Old February 13th, 2009, 04:10 PM   #13
MoneyPit's Avatar
+1. from some other posts i've read, you don't want to stretch, right? running that setup with no stretch and a pretty big drop will warrant rolled fenders for sure
Old February 13th, 2009, 04:14 PM   #14
Boosted
1nonlyaccord's Avatar
my 19x7.5 +42 with 225/35 tires rub when i turn and especially when i hit a bump while turning..but no dents..I cut all the tabs/lip out of my fender
Old February 16th, 2009, 12:02 AM   #15
xXxCLS bOoStEdXxX
slowaccord's Avatar
anyone try the fender roller you can buy from tirerack
Old November 3rd, 2009, 09:16 PM   #16
SPLIT2NDACCORD's Avatar
or use a baseball bat worked for me
SPLIT2NDACCORD is offline   Reply With Quote Quick reply to this message
Old November 3rd, 2009, 09:18 PM   #17
xXxCLS bOoStEdXxX
slowaccord's Avatar
^^^nope. thats half ass and u risk damage. since this post i bought multiple fender rollers that i rent out now
Old November 4th, 2009, 08:18 AM   #18
4.0L
VietNinjaJ30A1's Avatar
^^ I like my cutting+heating+bending technique. It works well and is easier than rolling IMO. But rolling works too...I just did the cutting/bending because I didn't have access to a roller for less than $150.
Old November 4th, 2009, 08:56 AM   #19
hella flush
lilfotoman's Avatar
u should look at my fenders... lol
Old November 4th, 2009, 09:22 AM   #20
Destroyer of Tires
Doctor_X's Avatar
Tim's fenders are gangsta.
Old November 4th, 2009, 09:28 AM   #21
neeeeeeeeeeeeeeeeeeeeeeel
implayaz9's Avatar
tims' and mine are all banged up.. sad but mine were messed up due to a mishap!
Old November 4th, 2009, 10:52 AM   #22
gangsta?
Old November 6th, 2009, 02:44 PM   #23
Well I'm running 27s with the stock height on the front end and they were rubbing so I took a sledge hammer to the wheel wells and the fenders and they don't hardly rub at all anymore.
Jeffy is offline   Reply With Quote Quick reply to this message
Old November 6th, 2009, 03:05 PM   #24
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
27's?.....I really hope that is a typo.
Old November 6th, 2009, 03:14 PM   #25
nope they're my winter tires
Old November 6th, 2009, 03:34 PM   #26
Destroyer of Tires
Doctor_X's Avatar
I didn't even think companies made wheels that large in 5x114.3...
Honestly, that kind of fitment should be frowned upon in the industry, that's disgusting.
Originally Posted by 99cfENVYv6
"Yeah, yeah, yeah" - Doctor X
What is
Old November 6th, 2009, 03:51 PM   #27
MoneyPit's Avatar
^27" TIRES yo. you've got a goddamn brain, use it. geez
Old November 6th, 2009, 03:53 PM   #28
lol I'm talkin tires not wheels. I don't know if 114.3mm is 4.5in but they are 15s that came off a 65 Ford.
Old November 6th, 2009, 03:59 PM   #29
V6 6SPD
allgonoshow's Avatar
My fenders are destroyed from running on road courses/ mountain courses. O well
allgonoshow is offline   Reply With Quote Quick reply to this message
Old November 6th, 2009, 04:04 PM   #30
MoneyPit's Avatar
^No doubt. My fenders are starting to get a little mis-shapen now too. I'm a bit anal, so it's seriously bothering me. The aggressive fitment is sick, but it's pushing my fender out and fugging up the fender/door reveal. Now my front fenders look like steve's rears D:
