what do you think.9/9.5.+12offset.. - Honda Accord Forum : V6 Performance Accord Forums
Old February 15th, 2009, 11:41 AM   #1
Boosted
1nonlyaccord's Avatar
Found some rims that i really like the style and color of.
But im not sure how they will fit:seeing the thread "the adventures of doctor x and keychain"
I like how the wheels are flush and tires are streched.
but what do yall think;will that ruin my light-weight 17" rota subzero plans?
17x9.0 +12offset Front
17x9.5 +12 offset Rear
center core:67.1mm..
and for people who are curious they are Rota P45R, bronze color.
Old February 15th, 2009, 11:58 AM   #2
neeeeeeeeeeeeeeeeeeeeeeel
implayaz9's Avatar
i doubt they will fit on a 6gen but i could be wrong.. 7gen yes they will fit with camber and rolled fenders.
Old February 15th, 2009, 01:32 PM   #3
xXxCLS bOoStEdXxX
slowaccord's Avatar
thats a pretty hardcore offset along with a wide footprint. maybe a little too hardcore. id skip on em
Old February 15th, 2009, 01:33 PM   #4
4.0L
VietNinjaJ30A1's Avatar
+12?! You're gonna have to flare those fenders...or roll 4x4.
Old February 15th, 2009, 02:20 PM   #5
hella flush
lilfotoman's Avatar
not sure itll fit on 6th gen... you can try it though.
Old February 15th, 2009, 02:25 PM   #6
same avatar since 03'
kEyChAiN's Avatar
Send a message via AIM to kEyChAiN
+12 is really intense. I really don't think it will fit without pulling the fenders or running flares.
kEyChAiN is offline   Reply With Quote Quick reply to this message
Old February 15th, 2009, 02:35 PM   #7
Brad
bdeitemeyer's Avatar
You can make them work, but I don't think you'd be willing to do what it takes for that to happen...my $.02. Move on & look for another set.
Old February 15th, 2009, 03:24 PM   #8
Boosted
well i wouldnt slam my car with them,just enough where they just sit under the fenders/quarter.
I already have my fender lip/tabs cut off and no fender liners.Id get my fenders rolled and quarters rolled,and cut the tab off the bumper and just screw in the bumper with tapping screws.
but would they stick out way to much? and would i still be able to run a BBK with that offset?
Old February 15th, 2009, 03:30 PM   #9
The End.
IcyAccord's Avatar
lol.. good luck . hahahahahaha
Old February 15th, 2009, 03:47 PM   #10
implayaz9's Avatar
ohh yea they will stick out..
Old February 15th, 2009, 03:47 PM   #11
xXxCLS bOoStEdXxX
slowaccord's Avatar
thats a crazy low offset. more than likely any bbk for accords will work with that low of an offset. but i dont think u can make it work without flares
Old February 15th, 2009, 04:30 PM   #12
Brad
You would have to run A LOT of negative camber (so much that it would negate your reasoning for getting the wider setup...traction), and it would still look much worse than this:
Cliff notes: look for another set of wheels.
Old February 15th, 2009, 05:35 PM   #13
-Maninder
Should look something like this:
Old February 15th, 2009, 05:56 PM   #14
implayaz9's Avatar
^lol
Old February 15th, 2009, 06:20 PM   #15
v not some model, my girl
99v6sedan's Avatar
^^roflmfao
Old February 16th, 2009, 07:08 PM   #16
Boosted
Checked out Rota's official website..and they offer
17x9 +25 offset would that be any better?
i dont understand how to read the wheel offset calculator:
Inner Clearance:2mm LESS
Outer Position:EXTEND an extra 36mm
Old February 16th, 2009, 07:35 PM   #17
Brad
17x9 +25 would still be pretty extreme, but it could work if you really wanted to make the effort. You'll end up running quite a bit of negative camber, so if unless you don't mind replacing your tires pretty often from inner camber-wear, try to find something in the 30-40 range.
Rota Torque comes in 17x9 +30, a little bit better: http://www.rotawheels.com/wheels.asp?wheelid=45
Rota Slip Stream comes in 17x8.5 +40, a nice fit: http://www.rotawheels.com/wheels.asp?wheelid=40
As far as the wheel offset calculator goes, it's comparing the position of the potential wheels/tire setup to your current setup. So if it's saying "2mm less for the inner clearance", that means you'd have 2mm less room between the inner wheel and the strut housing compared to your current setup. If it's saying "extend an extra 36mm for the outer position", that means the setup would stick out 36mm further than your current setup does. It's surprisingly accurate, I used it to order my wheels and it was dead-on.
So take a look at your car the way it is now, take a rule & measure 36mm (about 1.4 inches) from the outside of your wheels, and that's how far the 17x9 +25 would stick out. It may or may work without a lot of modification.
Old February 16th, 2009, 07:46 PM   #18
Boosted
Thanks alot Brad..I really like the style P45R tho..ill take some measurements tmr. 1.4" isnt too too bad sticking out but ya itl be sticking out and i cant tuck anymore.
but its either those..or just plain 17x7.5 subzeros +45 for performance.
and to clear a BBK.
Old February 16th, 2009, 07:52 PM   #19
Boosted
heres a pic i found on a 2G DSM:but i know all cars,wheels are different..
17x9 +25 offset with 255/40/17 tires.
Old February 17th, 2009, 07:42 PM   #20
Touch of CLaS
importtigger's Avatar
Send a message via AIM to importtigger
Hey bro, just be careful I got 40 offset to clear my bbk and had to roll and flare to clear the back for my 19's and u know I'm not slammed!!! Those are sexy ass wheels though
importtigger is offline   Reply With Quote Quick reply to this message
Old February 17th, 2009, 07:46 PM   #21
Im pretty sure you could run a 17x9 +25, you just need to do a bit of stretch. You guys expect to run a 9 wide and have meaty tires? Yeah right, have fun with that.
If you do a 9 wide just a 215/40 would be fine.
Forte EXE is offline   Reply With Quote Quick reply to this message
Old February 17th, 2009, 09:54 PM   #22
That a lil too extreme! i dont know why wheel companys dont just start doing custom ordering,i know thay do but it too much and wait is too long...
Im thinking of switching to a D2 18x8 35mm offset anyone rolling a setup close to that?......
as far as the +12,wow.........
jdmflip is offline   Reply With Quote Quick reply to this message
Old February 18th, 2009, 02:33 AM   #23
hella flush
lilfotoman's Avatar
+12 will be too aggressive on a 6th gen. run 20's in anything.
Old February 18th, 2009, 11:13 AM   #24
*VIP ACCORD*
BlackDeathV6BG's Avatar
Send a message via AIM to BlackDeathV6BG
Yeah too low of an offset for a 6th gen especially when your turbo'd. A 9.5 +12 in the front will stick out way too much and you will loose traction running such negative camber.
BlackDeathV6BG is offline   Reply With Quote Quick reply to this message
