Offset and Tire Size - Honda Accord Forum : V6 Performance Accord Forums
Old March 6th, 2009, 10:06 AM   #1
Blah Di Blah
E-Rock Accord's Avatar
So I'm looking around and I found a set of rims I like. They're 18x8 and come in offsets +33,+38 and +44. I'm lowered about 2-2.5in all around. So which offset would be best for me and what size tires should I look into?
Gotta get on it now that everyone's being flush to death.
E-Rock Accord is offline   Reply With Quote Quick reply to this message
Old March 6th, 2009, 10:15 AM   #2
THLA 2009 Bombsquad
Dtownz Thrillah's Avatar
Ditch the +44.
Go for either +33 or +38.
And you gotta go at least 3 inches =D
Old March 6th, 2009, 10:30 AM   #3
Blah Di Blah
Well I'm not sure when I'll be able to ditch the springs and get coilovers. But,now there's another question. If I drop it another inch lower, will I lose the flush stance if I buy rims now? lol
Old March 6th, 2009, 11:12 AM   #4
Destroyer of Tires
Doctor_X's Avatar
To answer your questions...
It is more complicated than a simple yes or no answer because those wheel sizes vary. For instance, you should probably go with the +38mm offset wheels at your current height, however if you were to go lower those wheels would not be as flush as the set that is a +33mm offset. If you want to make your wheels as flush as possible you have to have a few things dialed in to beforehand, tire size being one of them. To be completely honest with you I would say you best bet would actually be the +38mm offset wheels. They would still be pretty flush even if you did lower your car more, later down the road. As for tires, I would stick to a 225/40/18 at the LARGEST. Anything wider will more than likely cause you to rub in the rear.
Old March 6th, 2009, 03:19 PM   #5
Blah Di Blah
Thanks that's the info I was looking for. I'm not concerned with having the most aggressive fitment just to be as flush as I can with setup I have. So I'll be taking your advice on the +38 offset and I'll look into a tire less than 225/40/18 just to be safe and have the most comfortable ride possible.
Old March 11th, 2009, 11:27 PM   #6
baknoy
baknoy's Avatar
Send a message via MSN to baknoy
18x8 38 offset is the best cause i have the same set up with 3inch drop ....pretty flush not well but perfect...and yes i add camber,stretch tires 215-40-18,roll fenders ...but the looks its just wow ahahaha
baknoy is offline   Reply With Quote Quick reply to this message
Old March 12th, 2009, 08:57 AM   #7
Blah Di Blah
Thanks for the info. Glad to hear it'll still sit nicely when I drop more. Did you roll just the rears and how much camber?
Oh and do you have any closeup shots?
