Tire Fit on 02 EX V6... - Honda Accord Forum : V6 Performance Accord Forums
Old March 13th, 2009, 11:12 PM   #1
I'm a Newbie...
I just picked up an 02 EX V6, will 245/45-18 tires fit on the car with 18x8.0 wheels with 35mm offset? Does a 73.2mm bore fit the car?
I have a chance to buy those rims and i can take em with the tires or without, suggestions please.
Thank you!
af73 is offline   Reply With Quote Quick reply to this message
Old March 13th, 2009, 11:42 PM   #2
central Cali accords
mista jc's Avatar
Depending on how low you are, those tires are pretty meaty. They will rub if you're lower than 2 to 2.5 inches, if not, you should be good.
Old March 13th, 2009, 11:48 PM   #3
xXxCLS bOoStEdXxX
slowaccord's Avatar
no way. no tires are way to fat.
Old March 14th, 2009, 12:37 AM   #4
Brad
bdeitemeyer's Avatar
Tires will present a problem more than likely if you have any plans to lower the car. The bore is incorrect as well, but can be resolved with a hubcentric ring that converts the bore to 64.1mm.
Old March 14th, 2009, 10:56 AM   #5
Thanks for the input!
It isn't lowered yet but I plan on lowering it but only 1.7 to 2.0 inches. I think I'll still get the rims but hold off on the tires.
What size of tires would be ideal for those 18x8.0 rims and the 1.7-2.0 inch drop?? Thanks so much for your help!!
Old March 14th, 2009, 11:02 AM   #6
Bobby Lane Racing
nighthawk04v6's Avatar
you will rub guaranteed. roll the fenders out.
Old March 14th, 2009, 11:06 AM   #7
Brad
225/40/18 or 225/35/18 are the typical choices.
Old March 14th, 2009, 11:14 AM   #8
Thanks Everyone!
What size of tires will have the least amount of effect on the speedometer readings?? Sorry if I'm asking so many questions, I read a lot of the posts gathering information.
Old March 14th, 2009, 08:14 PM   #9
raider's Avatar
this site will give you what you need to know
http://www.miata.net/garage/tirecalc.html
raider is offline   Reply With Quote Quick reply to this message
