Wheel size affect drops? - Honda Accord Forum : V6 Performance Accord Forums
Old March 14th, 2009, 11:21 PM   #1
I am planning to drop my car but I am keeping the stock 15" wheels. How does this affect the drop vs a bigger tire?
More finger gap or less?
I become lower to the ground vs if I were using bigger wheels?
mew1838 is offline   Reply With Quote Quick reply to this message
Old March 15th, 2009, 09:27 AM   #2
awww cute stickers
AngusTEx's Avatar
Not sure if I'm reading your post right.
What dimensions are changing of a bigger tire are we talking about? Added width while keep the same sidewall ratio or what...? Assuming the sidewalls are bigger than the original tires, the wheel gap will be lessened but not by much and gap dependent on the tire dimensions.
However, with the same spring height, the extra sidewall will make you a tad bid higher off the ground too. Again, it depends on the tire dimensions.
Good thing you're dropping BEFORE getting new wheels.
&mpt=[CACHEBUSTER]">CBR600 F4i|CG3MT Solo2 ST #96
AngusTEx is offline   Reply With Quote Quick reply to this message
Old March 15th, 2009, 10:07 AM   #3
Senior Member
eugene3524's Avatar
Send a message via AIM to eugene3524 Send a message via MSN to eugene3524
why is it better to drop before gettin new wheels/? im plannin on doing both at same time in a couple weeks, is there something i should know?
sorry for hijacking
eugene3524 is offline   Reply With Quote Quick reply to this message
Old March 15th, 2009, 03:34 PM   #4
awww cute stickers
AngusTEx's Avatar
Well, a lot of people just get new bigger wheels and forget/don't care or just delay their suspension. Bigger wheels on stock height with massive wheel gap looks ridiculous b/c the smaller tire sidewall creates the illusion of an even BIGGER gap. Looks like SH1T.
Just my $0.02.
Old March 15th, 2009, 06:19 PM   #5
Boosted
1nonlyaccord's Avatar
Ur post is a little hard to understand what ur asking.But for example..
I just changed from 19" tucking all the way around..to 17s,and had a 2"
gap even from my previous tucking drop I had with my 19s so i had to lower it 2"more to tuck my 17s..and i scrape frame in some areas i drive now.
Old March 15th, 2009, 06:46 PM   #6
tuckin
coupeblack's Avatar
its more about tire size then rim size. Because you can run 15s with alot of beef and 18s with low pro tires and they will be the same size
coupeblack is offline   Reply With Quote Quick reply to this message
