camber kit - Honda Accord Forum : V6 Performance Accord Forums
Old March 25th, 2009, 08:49 PM   #1
DatBoiT's Avatar
camber kit
my front tires have bad camber wear on the inside...what should i do to fix it? im getting new tires ofcourse but i dont want it to happen to da new one...my friend say just buy da front camber kit ball joint on ebay. put it on and get alignment...is dat all?
DatBoiT is offline   Reply With Quote Quick reply to this message
Old March 26th, 2009, 09:29 AM   #2
t|23v0|2 n00b t00n3|2
Trevendous03's Avatar
are you dropped? i'm dropped 3 inches, and I don't have a camber kit in the front... I'm not getting bad wear on my tires. I just got rear camber arms, cause I was advised to. You shouldn't really need the ball joints, but that would fix the issue. You still wanna run some negative camber though, cause that looks hott. If you're gonna get the camber kit, get Ingalls, not just any ebay brand.
Old March 26th, 2009, 10:53 AM   #3
DatBoiT's Avatar
yea its drop on eibach sportline so dat about 2" front and rear...and dat front is bad i can see the thread sticking out but da back is just fine wit bout 80% thread left....n yea i was looking for ingall front camber kit but couldnt find any...but u think dat ball joint and alignment should fix it? and yea its look tight wit some negative but man it killing mah tires...
Old March 26th, 2009, 10:58 AM   #4
Bobby Lane Racing
nighthawk04v6's Avatar
get an allignment. the front can be adjusted via stock honda components.
Old March 26th, 2009, 11:45 AM   #5
ready for more
nixed007's Avatar
!wow! this is a subject that just can't be beaten any harder.
nixed007 is offline   Reply With Quote Quick reply to this message
Old March 26th, 2009, 10:12 PM   #6
DatBoiT's Avatar
oh so just the alignment fix the camber wear? no need for camber kit?
Old March 27th, 2009, 06:08 AM   #7
ready for more
nixed007's Avatar
Yes and no
The alignment will fix the wear but what you are seeing is a combination of toe and camber. Toe causes the wear camber causes where the wear is located. The guys at the tire shop will tell you its camber so they can do more work on your car. However, i know people running -3 degrees of camber all year long with no problems. Its all your toe that you need to worry about.
Let me back step a sec.
If you are running bf goodrich Traction T/A or a similar tire you may see faster wear on the sides of the wheel because they use a synthetic rubber shoulder so they have better traction but they wear faster on the outside.
Old March 27th, 2009, 10:20 AM   #8
DatBoiT's Avatar
so wats the best way to fix the problem im having bro? cuz ima get new tires but dont want it to wear out in a few months...
Old March 27th, 2009, 10:24 AM   #9
Bobby Lane Racing
get an allignment foo
Old March 27th, 2009, 11:14 AM   #10
DatBoiT's Avatar
no camber kit just an alignment? aight brotha ima trush u man lolz....u sur its not gunna wear out in a few month?
Old March 27th, 2009, 11:25 AM   #11
Bobby Lane Racing
your not low enough to need a camber kit. yes an allignment will fix the problem.
