Poping noise in front area - Honda Accord Forum : V6 Performance Accord Forums
Old May 16th, 2009, 09:14 PM   #1
lippstuh's Avatar
I've had this loud POP noise on my car. I can kind of feel it through the foot well. It happens when:
- Usually when i'm turning a LOT, example would be manuevering out of a parking lot. i would say turn 2 full turns left, right when i want to turn RIGHT it pops
- sometimes when one wheel would go down (wheel gap is huge) when you're going through drive ways and such
- sharp turns sometimes
its always just ONE pop, not that tick tick tick sound.
NO tears in axels, upper ball joints looked fine, wtf is going on?
lippstuh is offline   Reply With Quote Quick reply to this message
Old May 16th, 2009, 09:26 PM   #2
THLA 2009 Bombsquad
Dtownz Thrillah's Avatar
wheel hitting the coils?
Old May 16th, 2009, 10:53 PM   #3
Super IcyAccord
changaroo's Avatar
lower ball joints? motor mounts? axles?
my axles tick, but they arent ripped.
my car has a faint pop, and im pretty sure its my motor mounts. ticking is usually from axles / lower ball joints. both of which i need to replace sooner or later. lol. i haz no more boots on my ball joints.
Old May 16th, 2009, 10:57 PM   #4
Bobby Lane Racing
nighthawk04v6's Avatar
lower control arm bushings?
Old May 16th, 2009, 10:58 PM   #5
-Maninder
I thought you sold your car.
Old May 17th, 2009, 12:40 AM   #6
lippstuh's Avatar
i'll look that.
motor mounts? 60k on the car, but motor mounts have something to do with turning while not moving doesn't make sense to me. then again i thought i knew what was wrong and the mechanic who took a quick look couldn't figure it out yet.
i personally thought it was the axels or upper ball joints.
any way it can be sway bar related? which is also hard to believe... =[
Old May 17th, 2009, 07:17 AM   #7
Super IcyAccord
changaroo's Avatar
dont think its sway bar related, unless your bushings are out. and if they are, they would make more of a squeaking noise if anything.
i want to think its the axles. ive been through 3 drivers / 2 passenger ones lol. bout to go through 2 more.
Old May 17th, 2009, 10:07 AM   #8
lippstuh's Avatar
yeah but the mechanic's all like "if you're not moving and it still pops its not axels"
and the boots aren't ripped
Old May 17th, 2009, 10:26 AM   #9
Super IcyAccord
changaroo's Avatar
so if you turn on the car, leave it in neutral, and just turn the steering wheel full lock to one side... do you hear the popping? if you do im willing to bet its the LCA ball joints.
Old May 17th, 2009, 10:35 AM   #10
4.0L
VietNinjaJ30A1's Avatar
is it a loose endlink knocking? i had similar symptoms when one of mine was loose.
Old May 17th, 2009, 01:55 PM   #11
lippstuh's Avatar
that's correct, a few months ago it was 90% that i'm in neutral, turn full one way, right when i turn the opposite way it POPS, its loud and you can feel it through the footwell.
the other 10% of the time its hard turns while moving or when I go up driveways and the wheel decompresses (large wheel gap). also when I jack up my car i heard it a few times...
Old May 17th, 2009, 02:38 PM   #12
Super IcyAccord
changaroo's Avatar
hmm... i dont know about feeling it through the footwell though. thats really odd.
Old May 17th, 2009, 06:02 PM   #13
lippstuh's Avatar
its such a loud pop that u can sort of feel it.
Old May 18th, 2009, 02:44 AM   #14
Red FoXX
aznartist34's Avatar
I had a strange sound similar to popping before and I felt it with my feet on the footwell also. But this only happened when I was moving and going over bumpy roads. I had friends jump around in my car when it was not moving so I can locate the source of the sound and it turned out to be the sway bar. One end of the sway bar was not tightened enough to the endlinks and would make a sound when the sway bar moved. Not sure if my situation is the same as yours since yours only happens when you turn your wheels.
aznartist34 is offline   Reply With Quote Quick reply to this message
Old May 18th, 2009, 03:13 AM   #15
Hector Ochocinco
HECz_'s Avatar
Send a message via AIM to HECz_
The sway bar is near the footwell.. so yeah. Have you checked that?
HECz_ is offline   Reply With Quote Quick reply to this message
Old May 23rd, 2009, 09:47 AM   #16
Did My Time21's Avatar
Send a message via AIM to Did My Time21
check for a collapsed spring, have someone turn the wheel for you and try and get someone else to look at it. i just had to replace one the other day made the same noise your talking about
Did My Time21 is offline   Reply With Quote Quick reply to this message
Old May 23rd, 2009, 10:37 AM   #17
lippstuh's Avatar
i went through 3 different suspensions (coilovers) and it made the same sound during all 3...
Old May 23rd, 2009, 11:14 AM   #18
The End.
IcyAccord's Avatar
Uh, collapsed spring? wat.
flickr&mpt=[CACHEBUSTER]">
Old May 24th, 2009, 12:03 AM   #19
if you hit a bump or pothole hard enough it does happen but either way it should be an easy find if its as loud as he says it is
Old May 24th, 2009, 11:32 AM   #20
lippstuh's Avatar
some times its loud, sometimes its not, sometimes i get 4 pops in 2 full turns.
Old May 24th, 2009, 12:58 PM   #21
Destroyer of Tires
Doctor_X's Avatar
Maybe it's your axles going out?
Old May 24th, 2009, 10:11 PM   #22
lippstuh's Avatar
thats what i said, but the shop doesn't think so. ken (member here) said he doesn't think its the axels because it makes the sound when my car isn't moving (turning wheels)
Old May 24th, 2009, 11:10 PM   #23
Super IcyAccord
changaroo's Avatar
make a videoo
Old May 24th, 2009, 11:16 PM   #24
Destroyer of Tires
Doctor_X's Avatar
Everyone loves pictures. You know that if you see a thread title that could have pictures inside, and there are none, you leave disappointed.
Old May 24th, 2009, 11:27 PM   #25
Super IcyAccord
changaroo's Avatar
kinda hard to take pics of a noise :P
Old May 24th, 2009, 11:42 PM   #26
Destroyer of Tires
Doctor_X's Avatar
Pics of anything would be sweet!
Take a picture of the axles just to confirm it's not them hahaha.
Old May 25th, 2009, 03:33 PM   #27
lippstuh's Avatar
take them yourself lol u know where i live... for now..
Old May 25th, 2009, 03:43 PM   #28
Destroyer of Tires
Doctor_X's Avatar
That's super pedo status hahahaha. I was there on Friday night but I didn't see your car?
Old May 25th, 2009, 04:29 PM   #29
Super IcyAccord
changaroo's Avatar
ok, i just fixed my clanking / popping noise issue... i doubt this is your problem, but im just throwing it out here for ya
my k frame bolts were hella loose (i removed the k frame for the tranny swap), probably because my friends snap on impact failed me. i jacked up the car today, busted out my breaker bar and a 3 ft pipe and tightened them bishes.
now my car is silent.
and here i was the whole time thinking they were my ball joints (although they still do need to be replaced)
damn i coulda got pwnd so bad if i drove another week like this. aka whole front end falling out LOL.
Old May 26th, 2009, 10:13 AM   #30
lippstuh's Avatar
i was out.... stalkers.. esp b/c you spied my flickr
