Help - Sedan: 17x8 +35 17x9 +35 - Honda Accord Forum : V6 Performance Accord Forums
Old June 12th, 2009, 07:31 AM   #1
blackaccord's Avatar
I saw a set of rims i am interested in getting.
I am thinkin of going from my 18in to 17s
the size of the rims are
17x8 +35 17x9 +35
seeing what other people are running on this site.
its an aggressive but seems like it would work. at least for a coupe for sure.
i wonder what is the most aggressive offset people have ran for the sedan
I have rolled my fenders and i have a rear camber kit to adjust...i do not wish to run much negative camber tho.
what tires should i run with this setup
Should i go
215/50/17 front
225/45/17 rear
or
225/45/17 all around?
blackaccord is offline   Reply With Quote Quick reply to this message
Old June 12th, 2009, 08:07 AM   #2
The End.
IcyAccord's Avatar
You'll be fine. 215/45/17 and 225/45/17 is okay too.
Old June 12th, 2009, 08:42 AM   #3
isnt 215/45 too small for the front?
Old June 12th, 2009, 08:54 AM   #4
The End.
IcyAccord's Avatar
Nah, just the right amount of stretch too~
Old June 12th, 2009, 11:50 AM   #5
same avatar since 03'
kEyChAiN's Avatar
Send a message via AIM to kEyChAiN
They will fit. I'm running 17x9 +35 all around with 215/45/17 tires. I am also running -3 camber all around.
kEyChAiN is offline   Reply With Quote Quick reply to this message
Old June 12th, 2009, 12:07 PM   #6
*VIP ACCORD*
BlackDeathV6BG's Avatar
Send a message via AIM to BlackDeathV6BG
Yeah those would def fit. I would have to agree with Steve and get 215/45 F & 225/45 R cause that's exactly what I ran before.
So you didn't decide to buy those other Works wheels you showed me before? Or are those the specs?
BlackDeathV6BG is offline   Reply With Quote Quick reply to this message
Old June 12th, 2009, 12:49 PM   #7
^^mm cant remember which works i showed you. but no. i dont think its the same rims.
Old June 12th, 2009, 01:17 PM   #8
*VIP ACCORD*
The RC Starks...
Old June 12th, 2009, 01:31 PM   #9
no the RC starks got sold before i can snatch them up.....
Old June 23rd, 2009, 09:22 AM   #10
*VIP ACCORD*
I think you should try and fit 18x10's all around. No one has tried it yet on a 6th gen I don't think.
Old June 23rd, 2009, 01:01 PM   #11
does anyone know if the 2007 RDX wheels (18" x 7.5") will fit 6th gen? Specifically the five spoke alloy. I was thinking about putting them on my sedan, and will it look good?
Morrow is offline   Reply With Quote Quick reply to this message
Old June 23rd, 2009, 01:17 PM   #12
*VIP ACCORD*
Yes the RDX wheels would fit. Personally, I think they only look good on certain cars. I've seen them on an 8th gen civic si and they look ok. You need to be dumped inorder for them to look good.
Old July 15th, 2009, 10:06 PM   #13
so i managed to fit 18x7.5 +25 with no problem
running 225/40 yoko prada
Old July 15th, 2009, 10:50 PM   #14
Legendaryyaj's Avatar
Send a message via AIM to Legendaryyaj
Not if you want to follow the stupid trend of stretching tires.
How much negative camber is too much? If you dont want to run negative camber then I wouldnt suggest going aggressive.
I think Yogi's Accord might have been one of the most aggressive setups yet on a Accord.
IMHO, thers no point in getting low offset if you're only running a 7.5" tire. Low offset and wide tires are the way.
Legendaryyaj is offline   Reply With Quote Quick reply to this message
