rubbing on the inside of fender - Honda Accord Forum : V6 Performance Accord Forums
Old July 13th, 2009, 03:47 AM   #1
inthikmelody's Avatar
so i jacked my car to check my axle and i noticed that my wheel is rubbing the inside where there's this metal tab sticking out. i searched threads about people rolling/cutting their fenders, but no one talks about this. my question is if it is okay to cut that metal tab off.
here's a pic
added pic:
inthikmelody is offline   Reply With Quote Quick reply to this message
Old July 13th, 2009, 09:57 AM   #2
4.0L
VietNinjaJ30A1's Avatar
What are your wheel specs? I'm pretty low and I don't have that problem.
Old July 13th, 2009, 12:12 PM   #3
4.0L
Are you sure that thing is metal? It looks like it's melting away...
Old July 13th, 2009, 12:17 PM   #4
17x7 +50. Well the fender lining is plastic, but it covers this part that is metal. I guess you can't really see from the pic I took but it's on the right side where the whiteish part is.
Old July 13th, 2009, 04:44 PM   #5
4.0L
Oh I see what you're saying. I don't think mine is doing that. Do you have a camber kit or camber issues? I actually don't even remember seeing that tab on my car.
Old July 13th, 2009, 04:46 PM   #6
The End.
IcyAccord's Avatar
That looks like fender liner d00d.
Old July 13th, 2009, 05:54 PM   #7
Super IcyAccord
changaroo's Avatar
that is weird. 17x7 et 50 shouldnt do that.
i had 18x8 et 50 with no rubbing there.
are any of your suspension components worn?
Old July 13th, 2009, 06:02 PM   #8
i don't have a camber kit in the front. running about -1.6 in the front.
Old July 13th, 2009, 06:03 PM   #9
i don't think so, but my axle is giving out i think.
Old July 13th, 2009, 06:08 PM   #10
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
im only seeing fender liner...
17x7 +50 should rub at all. im 18x7.5 +48..two mm different in offset but 2.5in greater on each side of the rim.
Old July 13th, 2009, 06:26 PM   #11
i uploaded another pic, i don't know if its better, but the area where i circled, the fender liner has a slit where the metal tab is. its under the fender liner.
Old July 13th, 2009, 06:29 PM   #12
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
I dont know why you would by rubbing...maybe its the tire size...how big are they?
Old July 13th, 2009, 09:48 PM   #13
215/50
Old July 14th, 2009, 12:55 PM   #14
4.0L
Yea I think that's just fender liner...
Old July 14th, 2009, 03:22 PM   #15
xXxCLS bOoStEdXxX
slowaccord's Avatar
i noticed my car rubbed in the same spot. i dont know which wheels did it but i dont think its my current ones.
