how can you tell if you blown your shocks? - Honda Accord Forum : V6 Performance Accord Forums
Old August 14th, 2009, 11:51 AM   #1
FAILLLLLLLL
whiteV6penguin's Avatar
so my driver side is about a .5" lower than the passenger side i jacked it up and didn't really see anything strange.. any help appreciated
whiteV6penguin is offline   Reply With Quote Quick reply to this message
Old August 14th, 2009, 12:05 PM   #2
Got LSD?
00suprchrgdAV6's Avatar
usually when they sag is when they are blown.
00suprchrgdAV6 is offline   Reply With Quote Quick reply to this message
Old August 14th, 2009, 10:42 PM   #3
4.0L
VietNinjaJ30A1's Avatar
Stock shocks or coilovers?
Old August 14th, 2009, 11:24 PM   #4
FAILLLLLLLL
my coilovers tein's i proly need to take off my wheels i'll proly check again when i change my oil hopefully its not...
Old August 15th, 2009, 12:47 AM   #5
Senior Member
eugene3524's Avatar
Send a message via AIM to eugene3524 Send a message via MSN to eugene3524
I have tein coilovers as well, one of them sits lower then the other so I just adjusted them to be same... Could that mean one of them is blown? The ride feels good and everything is stiff
eugene3524 is offline   Reply With Quote Quick reply to this message
Old August 15th, 2009, 01:14 PM   #6
push that side down and see how it comes up
Johnson is offline   Reply With Quote Quick reply to this message
Old August 15th, 2009, 02:13 PM   #7
Destroyer of Tires
Doctor_X's Avatar
Untrue. Shocks do not affect ride height.
Your car isn't equal weight on all four corners so naturally you might get one side that is a little lower than the other. Just adjust it appropriately.
But to answer your question, you will see shock oil all over your shocks, hub, and wheels, along with dirt and debris that gets stuck to it along the way.
Originally Posted by 99cfENVYv6
"Yeah, yeah, yeah" - Doctor X
What is
Old August 15th, 2009, 04:31 PM   #8
sad my car is done =[
vzuptnguyen's Avatar
Send a message via AIM to vzuptnguyen
a lot of times you will hear squeaking from the shocks.
also, your height can be adjust if shocks are blown. just depends on the application type.
vzuptnguyen is offline   Reply With Quote Quick reply to this message
Old August 15th, 2009, 11:57 PM   #9
Destroyer of Tires
Doctor_X's Avatar
Bags, yes. Coilovers, no. The spring is what keeps your car from making the shock retract. You can push shock pistons down by hand, what makes you think it affects ride height?
What is
Old August 20th, 2009, 02:16 PM   #10
FAILLLLLLLL
there was grease everywhere on the shock what are my options now? i'm thinking about just sending it back to tein and have them fix it....
Old August 20th, 2009, 05:02 PM   #11
Destroyer of Tires
Doctor_X's Avatar
They were definitely blown then. If they looked like Oreo chunks were all over them, you know that they're blown.
I would say that wouldn't be a bad option, but it could be costly. Sometimes to rebuild shocks it might cost you like, 2/3 the cost of a new suspension set; and that's for four shocks and springs! Call up Tein and see what they can do for you. If it was under the one year mark, you should be able to use the warranty that came with them.
Old August 20th, 2009, 05:29 PM   #12
FAILLLLLLLL
hmm i called and i could overhaul it $75 base price instead of getting a replacement shock at 349 per shock
could i go with another brand of coilovers? like amr or w/e but just the fronts or is that a no no? cuz i would like to go lower in the front and the back is low enuff for me and i like the raked look
thx for the advices
Old August 29th, 2009, 04:03 PM   #13
98exaccord's Avatar
I could tell when mine were blown cause the shocks were squeaking with minimal movement and had bad response to heavy Gs. I replaced them with Koni yellows and lets say I fell in luv...but most people can not enjoy my preferred ride since most of my friends do not like the handling charaterics of the lowered AV6 since it loves to grab grooves and hook hard. I prefer a very agressive grip/handling for a daily driver. You will know like I did after the stocks blows and cant tske it after about 15K. Go for some good shocks like Koni yellows or equilivant
98exaccord is offline   Reply With Quote Quick reply to this message
Old September 10th, 2009, 09:33 AM   #14
Send a message via AIM to AMR Engineering
Hey OP, if your the guy I talked to last week, give me a call. I don't have your number saved. Peace! I can't PM you, I don't have enough post since I don't post a lot on here.
AMR Engineering is offline   Reply With Quote Quick reply to this message
