Rubbing on 17x8s? - Honda Accord Forum : V6 Performance Accord Forums
Old August 29th, 2009, 09:02 PM   #1
MAKDADDY
Y2kSignetEx's Avatar
Send a message via Yahoo to Y2kSignetEx
Rubbing on 17x8s?
I have an Eibach 1.2" drop, 17x8 rims with 215/50 Bridgestones on a 00 AV6. The tires are at 42 psi. I am scraping when I am braking no matter the speed and when I turn the wheel. I see where the wheel is rubbing.
Should this be happening? Should I increase the pressure to have more clearance?
Anyone else running 50 series and rubbing?
TIA
2000 sedan
AEM blue CAI, AEM blue TruPower pulleys, Eibach 1.5" Prokit, Tokico Illuminas, DCSports StrutBar, SuspensionTechniques sway bars
Goodridge SS brakelines, Axxis MM brake pads, red/clear tails
http://photos.yahoo.com/raymak
Y2kSignetEx is offline   Reply With Quote Quick reply to this message
Old August 29th, 2009, 09:06 PM   #2
lol with a 1.2 drop i dont think its possible to rub front. wut u mean ur scraping when ur braking...???
Old August 30th, 2009, 08:14 AM   #3
4.0L
VietNinjaJ30A1's Avatar
^^ I think he means when he hits the brakes, the front of the car dips and the front tires rub. I agree...it's weird that you're rubbing with a 1.2" drop...but really you just have to get lower profile tires...maybe a 215/45...you'd get about 1cm more clearance...which should be enough.
Old August 30th, 2009, 09:23 AM   #4
MAKDADDY
Ha, that's what I meant, rubbing. It's the right plus size and the TL's run the same size so it should've been fine. Just wondering if any AV6ers on 50 series are having the same issue.
Old August 30th, 2009, 09:43 AM   #5
(つ◕‿◕)つ*.★.*.★.* .★.
Red02AccordV6_2's Avatar
i've run 235/45/17 in front with a 1.5 inch drop with no problems. The tire profile height of the 235/45 is about the same 215/50. Are you sure it's the tires that are rubbing and not something else?
I'm currently on 225/45 in front and i'm dropped 3 inches from stock and i don't rub. I'm on 17X8+45 btw.
Old August 30th, 2009, 08:51 PM   #6
THLA 2009 Bombsquad
Dtownz Thrillah's Avatar
Higher offset like above +42 will not rub
My Works were 17x8 rear +35 offset and my tire size is 215/50/17, wow and that crap rubbed in the back all day long, but I semi rolled my rear fenders and they stopped until I lowered it more.
But now my fenders are about 90% rolled and I shouldnt have a problem. If I had lower profile tires 40 or 45 series, then I would put my works back on again
Old August 30th, 2009, 10:04 PM   #7
Super IcyAccord
changaroo's Avatar
i run 225 45 17 on an 8.5 et 25 in the front. theyre not rolled.
im dropped too lol. no problems.
are you sure its not the fender linings?
Old August 30th, 2009, 10:25 PM   #8
CRV_33's Avatar
215 on an 8" wheel would be a stretch. like what dtown said...i bet the issue is with the offset of his wheels
Old August 30th, 2009, 10:41 PM   #9
THLA 2009 Bombsquad
not thaaaat much of a stretch =P
Old August 31st, 2009, 10:38 AM   #10
awww cute stickers
AngusTEx's Avatar
42 psi WTF?
That's tremendously too high unless you're on the track.
AngusTEx is offline   Reply With Quote Quick reply to this message
Old August 31st, 2009, 07:24 PM   #11
MAKDADDY
The rubbing I see is on fender linings on the inside, not the outside. If I get any offset, I'd end up with rubbing on the outside.
That's the psi that I got from TireRack when they sent it to me.
Old August 31st, 2009, 08:11 PM   #12
awww cute stickers
AngusTEx's Avatar
I can understand a bit since it's a slight stretch of a 215 tire onto an 8" width.
But I dunno, 42 still sounds too high to me.
Old August 31st, 2009, 08:25 PM   #13
The End.
IcyAccord's Avatar
lol.. I laugh at this thread.
Old September 1st, 2009, 04:34 AM   #14
3.5L s/C'd 6 Speed
MikeyMikeCG2's Avatar
Send a message via AIM to MikeyMikeCG2
whats the offset?
from my experience an 8" wheel the lowest offset that will clear is 45(04 TL wheels)
ps 42 psi is way to much... u go any higher ur going to be in for a bad experience when you hit a bad pothole or bump
MikeyMikeCG2 is offline   Reply With Quote Quick reply to this message
Old September 1st, 2009, 08:03 AM   #15
4.0L
^^ I don't think the base 3G TL wheels are 8" wide.
Old September 1st, 2009, 08:18 AM   #16
3.56thgen's Avatar
you don't rub with the 235/45R17 in the front!?
Honda with a six pack
3.56thgen is offline   Reply With Quote Quick reply to this message
Old September 1st, 2009, 10:28 AM   #17
they are 8 inches
yup, my drop was weak though. I rubbed after i slammed my car so i switched to 225/45. I don't know how the hell icyaccord fit 255/40 in there. lol
Old September 2nd, 2009, 11:51 AM   #18
4.0L
Interesting. So is it just the offset that makes the TL and TL-S wheels different? Or are they the same spec just different design?
I have 215/45s up front on the TL-S wheels and I still rub sometimes. I have 235/45 in the back and they don't rub...but that's because I folded the fender lip in.
Old September 4th, 2009, 10:28 AM   #19
Euro accord wannabe
aznboi128's Avatar
i got 225 45 18 with 18 x 8 wheels + 45 offset no rub
I have tein SS and it's lowered about 2-2.5 up front when I had the suspension at the softest it rubbed how I have it at 20 /25 no rub
get harder suspension
07 accord ex-l v6 6mt coupe / HFP kit on the way / tein / yakima / TE37
07 accord ex-l v6 sedan
99 accord ex-l v6 / WW kit / tsx retro / Tein SS coils / 08 accord coupe 18"s
aznboi128 is offline   Reply With Quote Quick reply to this message
Old September 4th, 2009, 01:40 PM   #20
The End.
IcyAccord's Avatar
they are 8 inches
hohoohooho
I dropped the car a quarter of an inch, I hate running finger gaps.
Old September 4th, 2009, 09:22 PM   #21
MAKDADDY
Just checked the offset on the rims, 50mm and they're all at 32psi. Still no reason why they would rub on the inside lining...
Old October 7th, 2009, 02:51 PM   #22
Needs new paint
Hey guys, sorry to revive this but I have a question, and this thread seems as good a place as any to ask it.
Some wheels popped up on my local forum, and I was thinking about picking them up. I don't know anything about wheel fitment though, so here are the specs.. maybe you guys could fill me in on what I might need to do to get them to fit right.
Wheel specs are 17x8 +35 offset, tires are 215/45/17.
Suspension-wise, I'm on stock struts and Eibach Prokit springs (~1.5" drop).
The roads are pretty bad here in Winnipeg, but so far I haven't rubbed with my stock EX-V6 alloys and 205/40/16 tires.
How do you think these will fit on a 6th gen coupe?
av6_sm1ke is offline   Reply With Quote Quick reply to this message
Old October 7th, 2009, 03:24 PM   #23
The End.
IcyAccord's Avatar
it will fit.
Old October 7th, 2009, 03:26 PM   #24
THLA 2009 Bombsquad
it will good
Old October 8th, 2009, 01:49 PM   #25
Needs new paint
What about the offset? I dont want the wheels to stick out past the fender..
Old October 8th, 2009, 01:53 PM   #26
THLA 2009 Bombsquad
offset is good and it will not stick out past the fenders front or rear.
I have +36 offset 17x8 rear with some thick tires and the tires rubbed onto the fender since i had a 215/50/17 tire lulz.
215/45/17 is good enough
Old October 8th, 2009, 02:14 PM   #27
Needs new paint
Thanks for the info!
Old October 28th, 2009, 11:44 AM   #28
Honda Nation OGON
Accordn2Blk's Avatar
Send a message via AIM to Accordn2Blk
I love this site
Accordn2Blk is offline   Reply With Quote Quick reply to this message
Old November 6th, 2009, 01:19 PM   #29
My winter tires are 27s and they did the same thing so I took a sledge to both of the wheel wells and it got rid of almost all of the rubbing.
Jeffy is offline   Reply With Quote Quick reply to this message
Old November 16th, 2009, 10:00 AM   #30
bovodo's Avatar
get some 45 or 40 series tires with a 5mm spacer, you'll be fine.
bovodo is offline   Reply With Quote Quick reply to this message
