Ingalls front control arm camber kit honda accord - Honda Accord Forum : V6 Performance Accord Forums
Old September 7th, 2009, 09:13 AM   #1
AccordWhite00's Avatar
Hey, I have ingalls camber kit control arm, and my (driverside)control arm still hits the inner fender (metal part above the control arm) when I was drop to about a finger gap with my stock wheels. Ever time I hit a road bump or dip it would hit. Does anyone else have this problem?
AccordWhite00 is offline   Reply With Quote Quick reply to this message
Old September 7th, 2009, 10:19 AM   #2
4.0L
VietNinjaJ30A1's Avatar
Yup. I have them and mine still hit. The "low profile" control arms only buy you a LITTLE bit of extra room. I was hoping it would allow the entire control arm to go up into the strut tower...but yea it's not.
Old September 7th, 2009, 12:48 PM   #3
I thought I was the only one that has the Ingalls and still have the problems D:.
I guess there is no other option.
A Local accord guy cut out the area that was bottoming out
I heard wider wheels prevents it. Since I put my TL's on they don't hit or from what I noticed. But the rubber rubb now, I think Im going to get 225/45
Old September 7th, 2009, 08:53 PM   #4
Yah, I had these when I was 0 finger gap. It was terrible!!
It did correct the camber but because of it's "low profile" design, it made the control arm so much closer to the stock tower and it always hits. It sounds really bad. lol.
So I'm running my stock control arms now with less hitting, but it still hits only on medium-hard bumps. But my tires are warm out so I'm gonna try the camber ball joints next time, that would fix my camber and since I'm using the stock control arm I should have more room or movement.
simon_y is offline   Reply With Quote Quick reply to this message
Old September 8th, 2009, 08:02 AM   #5
So Ingalls Control Arm Camber kit = Hitting
OEM stock CA = Less hitting
Anyone tried the OEM Stock CA + Ball Joint camber kit?
Old September 8th, 2009, 08:28 AM   #6
4.0L
^^ My stock CA hit more than my Ingalls one. Did you get the low profile Ingalls?
Old September 8th, 2009, 08:30 AM   #7
Yeah I did, aren't all the Ingalls CA CK low pro?
Old September 8th, 2009, 02:18 PM   #8
4.0L
No, I think I saw one that was just normal. Basically the ball joint is different. On the normal one...the ball joint sticks up like the stock one. The low profile one has a flat plat on top instead of a protruding ball joint.
Old September 8th, 2009, 03:53 PM   #9
Lol yeah I got the plate one.
Old September 8th, 2009, 07:28 PM   #10
I'm gonna try the ingalls ball joint on my OEM control arm and see how that works out.
Old September 10th, 2009, 12:03 PM   #11
Tell us how it goes
Old September 16th, 2009, 03:08 PM   #12
Sail on Soothsayer
VindiCated's Avatar
Just installed my Ingalls control arms today. They hit only on medium to high bumps. but it only happens on my passenger side, rarely the drivers side.
VindiCated is offline   Reply With Quote Quick reply to this message
Old September 17th, 2009, 09:02 AM   #13
Weirdd. I hit on my Driver side and not ever on my passenger...
Old February 15th, 2010, 10:55 AM   #14
Ever since I slammed my car even more, my camber hit doesn't hit as much or as hard.
These maybe reasons why
Instead of OEM 16X 6.5 I now have 17X8
When I dropped my car more, I believe that makes your suspension stiffer
and on top of dropping it, my camber went slightly negative. Therefore increasing the distance between the strut tower and control arms.
I might be getting some 17X 7.5 next and an alignment, lets see whats gonna happen
Old March 5th, 2010, 12:01 AM   #15
6th. gen Stunna
Hondamugen's Avatar
Send a message via AIM to Hondamugen
can you put a spacer on the control arm bolts?
Hondamugen is offline   Reply With Quote Quick reply to this message
Old March 5th, 2010, 08:14 AM   #16
What would that do?
Old March 6th, 2010, 12:55 AM   #17
6th. gen Stunna
Hondamugen's Avatar
well if the control arms are bottoming out.. cant you put a spacer on the bolt to keep it from hitting the fender. Could that work or am i just retarded?
Old March 6th, 2010, 10:12 AM   #18
Well the control arms are mounted horizontally.
And the control arm hits the tower vertically.
Lol so no it wont do anything
Old March 6th, 2010, 09:49 PM   #19
6th. gen Stunna
Hondamugen's Avatar
ok, well i'm just retarded then! lol
*2000 Accord 5spd coupe Ex-Leather
BTFD
