warped rotors - Honda Accord Forum : V6 Performance Accord Forums
Old October 4th, 2009, 01:45 PM   #1
FAILLLLLLLL
whiteV6penguin's Avatar
Question warped rotors
so my driver side rear rotor is warped i was wonder would it be better if i got it resurfaced for 50 both sides? or just get a new set of brembo blanks for the rear 112 shipped?
my goal is trying to save some money so which one route would yall go with?
whiteV6penguin is offline   Reply With Quote Quick reply to this message
Old October 4th, 2009, 02:32 PM   #2
FAILLLLLLLL
hmm are there places cheaper than 112 shipped? i would love to know thx.
Old October 4th, 2009, 04:25 PM   #3
hmmm what next?
shonda1989's Avatar
upgrade
Old October 5th, 2009, 08:13 AM   #4
4.0L
VietNinjaJ30A1's Avatar
Yea, the car is 9 years old now...might as well upgrade it. If you get it resurfaced now and they warp again, you're probably going to have to replace them anyway. They can only resurface so many times before there's not enough rotor material left. There's a threshold that they won't go past.
Old October 5th, 2009, 08:27 AM   #5
Bobby Lane Racing
nighthawk04v6's Avatar
I always have two sets of rotors, one to resurface one to replace. but than again I can't get rotors my size right away. They have to be custom cut.
Old October 5th, 2009, 11:37 AM   #6
FAILLLLLLLL
thx for the advice, i'm proly going to get new ones be better in the long run.
Old October 5th, 2009, 12:59 PM   #7
New Member
aznfunkyflip's Avatar
not all warped rotors can be resurfaced for use anyways.
dont be cheap when it comes to braking system.
Old October 5th, 2009, 01:06 PM   #8
Bobby Lane Racing
yes there's a minimum spec and onces it hits that it's not recommended to go past.
Old October 5th, 2009, 09:52 PM   #9
4.0L
I'm also thinking about getting new rotors. The EBC dimpled/slotted ones I got aren't really that great...unless it's the greenstuff pads I'm using. Braking isn't really smooth unless I'm braking pretty hard.
I wanna get some PowerSlot Plus rotors. Maybe when I get my GS calipers. Kiet, what calipers are you running with the custom rotors? I'm assuming they're bigger? Did you just make yourself a bracket to more the caliper out?
Old October 23rd, 2009, 09:42 PM   #10
A. either buy aftermarket one which cost like 50/pc (Every new set of pad = new rotor)
b. Keep using dealer stuff, and keep resurfing it
SuperTurbo is offline   Reply With Quote Quick reply to this message
Old October 25th, 2009, 08:21 AM   #11
Godzilla
syclone's Avatar
doesn't really matter. unless you have floating rotors that are less prone to warping, aftermarket or factory will warp given the right occasion. how long had you had the rotors before it warped? if it's been a while, then save the money and resurface it. one advantage i like about factory is that the center hub portion is painted and doesn't really rust unlike the brembo blanks. but yes, you can only resurface so many times. if the warping is bad, buy new ones. if it's a minor shimmy, resurface.
Solo, Track, Drift, Kart... Race!! #114
-RIDES: '92 Skyline R32-GTR, '01 Honda s2000, '99 Accord EX 5-spd
syclone is offline   Reply With Quote Quick reply to this message
Old October 26th, 2009, 10:39 AM   #12
awww cute stickers
AngusTEx's Avatar
Resurfacing for $50 for two?!
I would shop around more. My nearby brake shop does $8 resurfacing per rotor.
+1 what syclone said. I'm still on my oem rotors going 9 years using cheap pads and brembo pads with some autocross and still no problems.
&mpt=[CACHEBUSTER]">CBR600 F4i|CG3MT Solo2 ST #96
AngusTEx is offline   Reply With Quote Quick reply to this message
Old October 26th, 2009, 12:29 PM   #13
Shift_
SouthStar019's Avatar
Send a message via AIM to SouthStar019
i assume you are using the cheap pads in the rear and the brembos in the front.
are your front rotors also OE also if you are using the brembo pads in the front how have the pads not are through the rotor yet. i have brembo pads in the font and it seems as if the pads are eating the rotor.
SouthStar019 is offline   Reply With Quote Quick reply to this message
Old October 26th, 2009, 12:53 PM   #14
awww cute stickers
AngusTEx's Avatar
Yeah, cheap pads rear. Brembos front. OE rotors all around.
The brembos have been on for ~15k miles.
The only hard braking I do is on the track. On the street I coast and lightly brake a ton. That should be a huge factor.
Old October 26th, 2009, 01:06 PM   #15
dang if only u needed the front. I have a set of rotors for sale but its the front only.
Old October 26th, 2009, 01:10 PM   #16
Where do you get your OEM rotors? Mine aren't painted and very rusted. Can't wait for spring to upgrade.
Furple is offline   Reply With Quote Quick reply to this message
Old October 27th, 2009, 01:21 AM   #17
Godzilla
syclone's Avatar
i just got mine from the local dealer. my brother is technician at a local lexus dealership and they all give each other discounts. so i got mine for 25% off.
