Vibration when I hit the brakes - Honda Accord Forum : V6 Performance Accord Forums
Old November 6th, 2009, 01:45 PM   #1
Hey guys when I break at over 80-90 km/h, I feel a vibration through my steering wheel but not through my pedal. I got my front end checked by a mechanic a 2 months ago and he said the front end looked fine. My brakes were last done @ 167 000km in May 2008 by Canadian Tire and the car currently has 195 000km on it. Could it be my rotors? Are our rotors pressed into the hub like the 5th gen Accords?
watut is offline   Reply With Quote Quick reply to this message
Old November 6th, 2009, 01:51 PM   #2
-Maninder
Isn't pulsating brakes a sign of bad pads?
Old November 6th, 2009, 02:05 PM   #3
Super IcyAccord
changaroo's Avatar
w
a
r
p
e
d
r
o
t
o
r
s
Old November 6th, 2009, 02:08 PM   #4
jsiriusvtec
Guest
Posts: n/a
wait, the rotors are pressed into the f'in hub on 5th gens? is this right?
Old November 6th, 2009, 02:11 PM   #5
Euro accord wannabe
aznboi128's Avatar
Originally Posted by changaroo View Post
w
a
r
p
e
d
r
o
t
o
r
s
more like
w
-a
r
-p
e
-d
r
-o
t
-o
r
-s
07 accord ex-l v6 6mt coupe / HFP kit on the way / tein / yakima / TE37
07 accord ex-l v6 sedan
99 accord ex-l v6 / WW kit / tsx retro / Tein SS coils / 08 accord coupe 18"s
aznboi128 is offline   Reply With Quote Quick reply to this message
Old November 6th, 2009, 02:26 PM   #6
Super IcyAccord
changaroo's Avatar
theyre held in by two screws that are impossible to get out lol.
Old November 6th, 2009, 02:35 PM   #7
If its not your rotors it sounds kinda like a wheel bearing.
Jeffy is offline   Reply With Quote Quick reply to this message
Old November 6th, 2009, 02:41 PM   #8
Super IcyAccord
changaroo's Avatar
if its wheel bearing you will constantly hear it.
Old November 6th, 2009, 02:44 PM   #9
gflip456's Avatar
I have da same exact problem..don't know wats causin it
gflip456 is offline   Reply With Quote Quick reply to this message
Old November 6th, 2009, 03:16 PM   #10
could be warped rotors
could be bad pads
could be unbalanced tire/wheel
Old November 6th, 2009, 03:18 PM   #11
Super IcyAccord
changaroo's Avatar
theres a monkey pushing your wheel underneath your car. call animal control.
Old November 6th, 2009, 04:35 PM   #12
jsiriusvtec
Guest
Posts: n/a
Man I've had the car for a while, and it seems that I'm ****ing with the
goddam right front brake every couple of months. It's warping the rotor
over and over and over. I rarely drive the car hard anymore, and I have
replaced the hub. It doesn't pull to either side when braking, so that
eliminates unequal pressure. What the hell else could be my problem?
I hope people aren't buying new hub assemblies because they don't know what an impact driver is.
Old November 6th, 2009, 04:52 PM   #13
It could be that the caliper is sticking from dirt/rust and isn't letting the pads release. I would probably take it somewhere with no traffic and speed up to 70 or so for a while and then down shift to slow down and use the e-brake to come to a complete stop. Then get out and if the left side is warm and the right side gives you a second degree burn I would say that's your problem. That would cause your pads to wear out fast and heat your rotor to the point of warping. imao
Old November 6th, 2009, 04:55 PM   #14
Senior Member
eugene3524's Avatar
Send a message via AIM to eugene3524 Send a message via MSN to eugene3524
Have the same problem on my 7th gen, only happens when breaking at higher speeds, so general consensus is warped rotors?
eugene3524 is offline   Reply With Quote Quick reply to this message
Old November 6th, 2009, 05:55 PM   #15
Godzilla
syclone's Avatar
the last brake service you had has nothing to do with warped rotors. you can drive away from the service station, have bad luck of events happen and have your rotors warped before you get home.
when the steering wheel shimmies during high speeds, it's usually an indication of a light warpage. you can test it out by braking a little harder during the high speed and seeing if the steering wheel shakes a little more.
Solo, Track, Drift, Kart... Race!! #114
-RIDES: '92 Skyline R32-GTR, '01 Honda s2000, '99 Accord EX 5-spd
syclone is offline   Reply With Quote Quick reply to this message
Old November 6th, 2009, 07:30 PM   #16
Senior Member
eugene3524's Avatar
That's exactly what I have, sweeeet then looks like I have a reason for some bbk or sweet break set up to look forward to in spring , no high speeds in winter anyway so I'll do just fine
Old November 6th, 2009, 11:12 PM   #17
Thanks alot guys, I'll change those front rotors and pads soon!
Old November 6th, 2009, 11:14 PM   #18
I remember that was it on my 94 Accord Exr sedan, i took those bolts out and it wouldnt come out so i took out the whole knuckle and went to my mechanic who pressed em in and out
Old November 10th, 2009, 09:30 AM   #19
rotors i have the same problem
jspic531 is offline   Reply With Quote Quick reply to this message
Old November 10th, 2009, 02:56 PM   #20
bovodo's Avatar
3/4 inch socket wrench w/ Phillips attachment took out the screw that held in my rotors. screwdrivers are useless and impact wrenches strip the screws.
if you havent had your allignment and tires balanced. and its time for new brake pads, change out the rotors while your at it, if its showing it's age. 110,000+ miles
bovodo is offline   Reply With Quote Quick reply to this message
Old November 10th, 2009, 03:57 PM   #21
┌∩┐(◣_◢)┌∩┐
skatingclaybird's Avatar
i just use a hammer and a big tip screw driver and beat the screwdriver till it digs a groove the they should loosen up and undo them!
Old November 10th, 2009, 08:25 PM   #22
Thats what I do, so I take it our cars have the rotor over hub design and our rotors are not pressed in
Old December 12th, 2009, 02:24 PM   #23
warped rotors it is...thanks i was wondering if it were my pads...
AirecKone is offline   Reply With Quote Quick reply to this message
Old December 13th, 2009, 02:14 AM   #24
Turned out to be my rotors, changed both rotors and pads now all is good
Old December 23rd, 2009, 05:56 PM   #25
03 Accord 6/6, 09 Audi A4
estradaccord's Avatar
Had the same garbage goin on ...still going on with mine. money's short so its small steps 4 now but have new EBC green stuff pads biting the front and I still have vibration. next are EBC rotors. maybe then it will stop.
estradaccord is offline   Reply With Quote Quick reply to this message
Old January 18th, 2010, 01:36 PM   #26
i have a vibration problems at 60-70mph... this happened after i put new rims and tires on... Does anyone know what would cause this?
Bronxbomber is offline   Reply With Quote Quick reply to this message
Old January 18th, 2010, 03:55 PM   #27
4.0L
VietNinjaJ30A1's Avatar
Were they properly balanced? Were the rims new? If they're used, they could be bent.
