wicked tuning camber kit install help - Honda Accord Forum : V6 Performance Accord Forums
Old November 16th, 2009, 10:36 AM   #1
&mpt=[CACHEBUSTER]"> &mpt=[CACHEBUSTER]">
i have a problem removing the joint circled in yellow. Do i need a special tool for that? i thought there was just a nut underneath(red arrow) with a pin and it show come out. But it was still snug. I removed the [email protected]$$ bolt(red circle) annoying btw, still wont come out. Any info would help.
i searched and everyone says its really easy with just basic hand tools but i cant seem to get this last joint out. thank you!
catchnshoot3233 is offline   Reply With Quote Quick reply to this message
Old November 16th, 2009, 11:46 AM   #2
4.0L
VietNinjaJ30A1's Avatar
Check the head of the bolt on the underside of that yellow joint...I think it's like your endlinks where there's an allen head in the end of the bolt so you can hold the bolt while turning it with an open ended wrench.
Old November 16th, 2009, 11:52 AM   #3
Ok I'll try that thank you so much.
Old November 16th, 2009, 03:58 PM   #4
you need to go rent a ball joint separator from any of the retail auto part store.
GL with the install.
jeff90630 is offline   Reply With Quote Quick reply to this message
Old November 16th, 2009, 04:13 PM   #5
i knew there had to be something else, because i thought it would slip right out, it looked like it was just a pin but i guess not. Ill rent one then thanks!
Old November 16th, 2009, 04:23 PM   #6
Senior Member
eugene3524's Avatar
Send a message via AIM to eugene3524 Send a message via MSN to eugene3524
Hmm, I got it out...blow torch to heat up, A wedge to gain leverage, hammer to knock out. U won't be needing the oem camber kit anyway so If u damage it who cares, idk tht was my point of view, one took 2 min to get out the other took 15
eugene3524 is offline   Reply With Quote Quick reply to this message
Old November 16th, 2009, 04:25 PM   #7
seriously, i hammered that thing yellow circle in every direction a long pole for leverage and banged on it every which way...blow torch ehh? i gotta "flame on" for this...
Old November 16th, 2009, 04:39 PM   #8
Senior Member
eugene3524's Avatar
Lol just heat that succer up and yank it out
Old November 16th, 2009, 07:35 PM   #9
4.0L
Yea I had a ball joint get stuck...I took it to my uncle's shop to have it removed. I'm not sure what he did or how he did it, but he removed it. According to NVA-AV6...water on the surfaces that make contact can cause it to stick like that after being compressed over time.
Old November 17th, 2009, 01:45 AM   #10
Godzilla
syclone's Avatar
you need to rent a ball-joint seperator tool. it'll make your life so much easier and the install go that much faster.
Solo, Track, Drift, Kart... Race!! #114
-RIDES: '92 Skyline R32-GTR, '01 Honda s2000, '99 Accord EX 5-spd
syclone is offline   Reply With Quote Quick reply to this message
Old November 17th, 2009, 08:38 PM   #11
im going to try that this weekend...ill update once i get to it
Old November 20th, 2009, 05:39 AM   #12
Godzilla
syclone's Avatar
in case you don't know what it looks like, it's a fork shaped tool that wedges in between the arm and the hub attachment. you will hammer that wedge in between to pop it loose.
