Recommend me a wheel/tire/suspension set up - Honda Accord Forum : V6 Performance Accord Forums
Old November 23rd, 2009, 02:20 PM   #1
TD = The Destroyer
oltorftd's Avatar
First of all, the car in question is a 2001 accord coupe EX 2.3L 5 speed. I am considering doing some upgrades, but i want to start with suspension. If I do this project i'll do the 5 lug conversion and a big brake kit. Also, it's going to need tires soon, so why not start with wheels and tires?
What wheel/tire setup is best for handling? So far this is what i've got picked out:
wheels (18x8):
http://www.tirerack.com/wheels/Wheel...&wheelModel=C2
Tires (215/45R18):
http://www.tirerack.com/tires/tires....rd+Coupe+EX+V6
How about lowering? I honestly don't like super lowered cars for looks. I'm only interested in lowering enough to close up the wheel gap. How far should one lower one's car if all you want to do is improve how it handles?
Coilovers/shocks/struts? what an ideal setup here?
Swaybars? recommendations?
Anything else i should think about?
Oltorf the Destroyer
2001 Honda Accord EX Coupe 5spd 2.3L|1994 Toyota Pickup 4x4 SR5 5spd
oltorftd is offline   Reply With Quote Quick reply to this message
Old November 23rd, 2009, 02:58 PM   #2
i recommened a 2 inch drop since our cars are very high from factory. swaybar helps reduce understeer to corner better.
Old November 23rd, 2009, 03:05 PM   #3
Brad
bdeitemeyer's Avatar
It sounds like you have a nice plan, except I would recommend lowering the car first instead of finding the wheels/tires.
Why don't you look through pics of 6th-gen coupes that give you an idea of the look you're aspiring for, and we can help you from that point. Your questions are so vague that many many answers could all be right, yet they may not be exactly what you're looking for.
First of all, what's your budget? Are you using your car for everyday driving, or are you looking for track-level handling? Etc etc.
Old November 23rd, 2009, 04:07 PM   #4
TD = The Destroyer
oltorftd's Avatar
My goal is track-level handling. I don't have a budget, but i'm definitely not going to cheap out on parts. I'm not going to waste money on ebay parts. I'm going to stretch out this project over a few years to give me a chance to save up for quality parts.
Thanks for the responses - i've been lurking the 6th gen coupes thread and the wheel/tire thread for a while and i think i have a pretty good idea of what i want to do. I just don't know that much about suspension and lowering and stuff. I don't know if a 17" vs a 18" whell will affect handling that much compared to the stock wheels, but since that's the first thing i'll do (unless i lower first, like you recommended) i don't want to buy some wheels that just look good when it turns out there are better ones out there. I just basically got the lightest wheels that i liked on tirerack that weren't $600 a wheel.
so what you're saying is that i should look for some coilovers to drop the ride height, right?
Old November 23rd, 2009, 04:16 PM   #5
xXxCLS bOoStEdXxX
slowaccord's Avatar
my advice is to make sure the wheels you get are 20 pounds and under. and instead of 215/45/18 get 225/40/18. you can get a very nice package that fits this for 1200-1500 used and maybe even new if you pick out the right wheel.
hope that helps somewhat
Old November 23rd, 2009, 04:20 PM   #6
TD = The Destroyer
oltorftd's Avatar
why do you recommend that tire set up instead?
edit - hey those wheels i got are exactly 20 lbs. maybe i should get 17" inch wheels instead? those are pretty light.
Old November 23rd, 2009, 04:37 PM   #7
xXxCLS bOoStEdXxX
slowaccord's Avatar
if you want REAL performance and the option of a BBK later then 17's are your best bet. u can get nice and wide 17" that are about 18 pounds a piece with some sticky rubber. but if you never plan on getting a BBK then even 16's will work out nicely but your tire choices get more limited.
Old November 23rd, 2009, 05:54 PM   #8
TD = The Destroyer
oltorftd's Avatar
i might just do 17"s. they're cheaper, the tires are cheaper, they're less bumpy, and you run less of a risk of breaking a wheel. the only downside is that selection is limited.
Old November 23rd, 2009, 07:11 PM   #9
I would do 17s if your goal really is handling. Plenty of tire choices in proper sizes for our car in 17". If you want looks go 18...
Furple is offline   Reply With Quote Quick reply to this message
Old November 23rd, 2009, 10:11 PM   #10
Super IcyAccord
changaroo's Avatar
track handling + 6 gen wheel base = near impossible.
Old November 24th, 2009, 07:26 AM   #11
TD = The Destroyer
oltorftd's Avatar
what's wrong with the 6th gen wheel base?
Old November 24th, 2009, 04:38 PM   #12
TD = The Destroyer
oltorftd's Avatar
how are the tein basic dampers? i'm going to get those or the tein SS or eibach coilovers. i don't know if i really need something as expensive as the latter 2. the tein basic dampers are probably just fine for what i want. they seem like they're quality.
Old November 27th, 2009, 02:01 AM   #13
awww cute stickers
AngusTEx's Avatar
I beg to differ.
&mpt=[CACHEBUSTER]">CBR600 F4i|CG3MT Solo2 ST #96
AngusTEx is offline   Reply With Quote Quick reply to this message
Old November 27th, 2009, 08:44 AM   #14
TD = The Destroyer
oltorftd's Avatar
what did you do to get good handling?
Also, i think i changed my mind about the tein coilovers. i'm sure they work great, but man they're hack of expensive. i'm looking at the eibach pro system plus now. any thoughts on those?
Old November 27th, 2009, 01:21 PM   #15
(つ◕‿◕)つ*.★.*.★.* .★.
Red02AccordV6_2's Avatar
long wheelbase, takes more effort to change directions than shorter wheelbase.
very soft, great for daily and a decent drop but not going to achieve the "track-level handling" you're after.
▬▬▬▬▬▬▬▬ஜ۩۞۩ஜ▬▬▬▬▬▬▬▬
Old November 27th, 2009, 06:39 PM   #16
Destroyer of Tires
Doctor_X's Avatar
If you want track level handling it'll cost you a lot for good parts. Tein Basics aren't going to improve your handling.
Look into some Koni Yellows + Ground Control sleeves that are custom tailored to your liking, AMR coilovers, or some top dollar race systems like Zeal or JIC. The last two I listed are $2000+ though.
Also you should get a Progress rear sway bar, some light weight wheels (RPF1s are nice and light, and relatively inexpensive) along with some STICKY rubber.
Old December 13th, 2009, 02:10 PM   #17
alrite. i need help with my suspension. I don't want to go cheap with this, but anything over 800$ really hurts my wallet. I am looking for something round 200-300 that gives me a great drop.
I want to slam it, not to the point where it will rub, but to the point where my wheel gap is almost non-visible or really minimal.
pictures would be great, and recommendations as well. thanks!
bzhou4 is offline   Reply With Quote Quick reply to this message
Old December 13th, 2009, 02:16 PM   #18
Brad
Look into Neuspeed Race springs...
Old December 14th, 2009, 06:39 PM   #19
┌∩┐(◣_◢)┌∩┐
skatingclaybird's Avatar
Is Omni Power or teinsuper street damper any competition to the JIC
Old December 14th, 2009, 06:46 PM   #20
Brad
Ehh...it depends what you're comparing Clay (comfort, handling, etc.). Also, which JIC coilovers are you thinking of (FLT-A2 or FLT-TAR). JICs are also much more expensive...
Old December 15th, 2009, 12:11 PM   #21
Legendaryyaj's Avatar
Send a message via AIM to Legendaryyaj
Look up memeber Syclone for track setups on a Accord. He had a sedan and it rocked!
For suspension, all you'll need is custom Ground Control coils with Koni Yellows. DO NOT try to track with Tein basics or SS as they suck.
As for rims, go with a lightweight 17x8's with beefier tires.
Also I wouldnt buy a tire/wheel package from Tirerack as they try to spec it out as close to stock as possible for their name sake.
Legendaryyaj is offline   Reply With Quote Quick reply to this message
Old December 15th, 2009, 10:43 PM   #22
┌∩┐(◣_◢)┌∩┐
Im comparing more to th performance side. But see my car is a 50% Show (no right now) 50% go So i think im going to go wit a air strut system so i can dump and not scrape when i feel like it and then compete in my auto cross events.
Man tat sounds great!
Old December 15th, 2009, 11:08 PM   #23
xXxCLS bOoStEdXxX
slowaccord's Avatar
count on tirerack to give you a crappy offset and narrow ass width. thats one thing i don't like about them. they are waaaay too conservative. But i know where they are coming from. Alot of people are stupid and dont know what they are buying
Old December 16th, 2009, 08:49 AM   #24
┌∩┐(◣_◢)┌∩┐
Like .....me? lol
Old December 16th, 2009, 01:16 PM   #25
xXxCLS bOoStEdXxX
slowaccord's Avatar
why would you fall under that category? you have this website to advice you.
Old January 7th, 2010, 06:14 PM   #26
i just bought an 02 v6 coupe not sure what suspension i should put on... i want something that will look nice but i wanna be able to still drive my car hard with out worrying about bottoming out... any suggestion?
02redaccordv6 is offline   Reply With Quote Quick reply to this message
Old January 7th, 2010, 07:40 PM   #27
1whitehonda's Avatar
get the ssp very nice for the 6th gen. very nice control
1whitehonda is offline   Reply With Quote Quick reply to this message
Old January 7th, 2010, 09:01 PM   #28
strong screenname. lol
Old January 8th, 2010, 01:13 AM   #29
xXxCLS bOoStEdXxX
slowaccord's Avatar
hes ur long lost brother!
Old January 8th, 2010, 02:46 AM   #30
UCRk24accord's Avatar
JIC coilovers
DPE's 18x9.5 +30 front 18x9.5 +20 rears o disk
UCRk24accord is offline   Reply With Quote Quick reply to this message
