Knocking Inquiry - Honda Accord Forum : V6 Performance Accord Forums
Old November 25th, 2009, 04:35 AM   #1
3.5L s/C'd 6 Speed
MikeyMikeCG2's Avatar
Send a message via AIM to MikeyMikeCG2
Knocking Inquiry
if we can keep this to a minimal flame and just knowledgable answers please
when i changed my suspension from H&R/KYB to full tein SSp coil over, i went from silent, slightly bouncy ride. to noisy, stiff as a sob ride.
stiff i dont care about, edfc helps..
ever since. my car sits higher just to keep the tension on the springs when it is off the ground. to "prevent" that rattling sound.
What went into the car when i did the suspention was
New lower control arms (oem)
new lower ball joints (oem)
ingalls front/rear camber kits
tein ssp coil overs
tein edfc.
new inner/outer tie rods
people all see my wheel well gap now compaired to when i was rocking the H&R/KYB
my problem is, it still clunks over little bumps, and i mean little. NYC streets, where its slightly un-even. Now i don't know if its the springs rattling, which i fear it cant be. simply because the shock isnt expanding enough over these little bumps to release tension on the spring.
Anyone ever have problems with Ingalls camber kit, possibly hitting the strut tower/inner fender apron?
I bought tein's helper springs to maybe see if it would help, and next thing is upgrading my sway bars. but im tried of playin trial and error. im spending too much money.. Thanks in advance
♠ 3.5L Six Speed SuperCharged Accord ♠ New York City 'Built for Abuse' ♠
MikeyMikeCG2 is offline   Reply With Quote Quick reply to this message
Old November 25th, 2009, 08:29 AM   #2
Super IcyAccord
changaroo's Avatar
is the ingalls kit the new control arm or just the balljoint?
Old November 25th, 2009, 08:41 AM   #3
Bobby Lane Racing
nighthawk04v6's Avatar
did you leave any pre-load on the springs, are did you dump it all the way down?
the ingall fronts are known to hit under the fender when you're dumped.
Old November 25th, 2009, 09:53 AM   #4
New Member
aznfunkyflip's Avatar
1st thing it pops in my mind when i read "ingalls front/rear camber kits".
Old November 25th, 2009, 10:24 AM   #5
The End.
IcyAccord's Avatar
plus one.
and on the
with SSPs
Old November 25th, 2009, 12:33 PM   #6
4.0L
VietNinjaJ30A1's Avatar
Are there any control arm camber kits that WON'T hit the inside of the fender? I have the ingalls and they knock when I hit bumps.
Old November 25th, 2009, 12:38 PM   #7
New Member
that must be really annoying
Old November 25th, 2009, 12:44 PM   #8
The End.
IcyAccord's Avatar
My control arm camber kits don't hit as much as the ball joint ones.
Old November 25th, 2009, 12:58 PM   #9
Ronald Aka Yeyo's Avatar
I have the same problem......
Ronald Aka Yeyo is offline   Reply With Quote Quick reply to this message
Old November 25th, 2009, 12:58 PM   #10
This is why I think dropped is better than slammed. I'm so glad I didn't try to slam my ride.
2 finger front + 1 finger rear = win
Furple is offline   Reply With Quote Quick reply to this message
Old November 25th, 2009, 01:20 PM   #11
+1 on that
Old November 25th, 2009, 01:29 PM   #12
Super Mod
aprevo15's Avatar
once you go slammed you can't never go back. lol
to the op, like kiet said it is the front ingalls kit. i installed that and it hit so i took it off. another option would be to cut a hole where the top of the ball joint hits the fender well if that is the problem.
Also, I don't think that's the right application of "hella" lol...
Old November 25th, 2009, 01:46 PM   #13
That's what seperates boys from men
Old November 25th, 2009, 02:23 PM   #14
New Member
Old November 25th, 2009, 02:41 PM   #15
Agreed. Men enjoy practicality and improved looks while boys cry about clunking noise, bottoming out, and dodging pot holes
Old November 25th, 2009, 02:47 PM   #16
noise free on tein ss. all the way down as well.
Old November 25th, 2009, 02:51 PM   #17
Super Mod
aprevo15's Avatar
all the way down on tein ss as well and noise free.
Old November 25th, 2009, 03:06 PM   #18
That what separate rich from poor.
bend up subframe, j-pipes, and jack points = not fun to fix.
Old November 25th, 2009, 03:33 PM   #19
Suspension Noobie
kesandoV6's Avatar
^^^^ word. Slammed suspension in the NYC FTL. I have like 1-2 finger gap on my Tein basics and clunk slightly on sharp bumps.
Garage Queen...
kesandoV6 is offline   Reply With Quote Quick reply to this message
Old November 25th, 2009, 04:24 PM   #20
Oh yea, didn't think of that. I live in NY too.
Old November 25th, 2009, 04:47 PM   #21
Sunny Cali ...
Oh and i'm not rich no way near that i haven't moded my accord in over a year jobless i need to get that progress swaybar and a H22 swap then i'm good...
Old November 25th, 2009, 05:02 PM   #22
4 bangin'
Sketch o5's Avatar
the ball joint cambers kits give you less space between the top of the uca and the strut tower. i remember on my old accord, which was about the same height youre at now mike, it would hit more often then it did before i had it installed. and now, with no camber kit, my car barely hits now, tho id hate to see what itd be like with one haha. if the clunking you hear is from the front, id say that the camber kit could be a possibility.
Old November 25th, 2009, 06:12 PM   #23
Vimal (vee-mall)
KnightRyder's Avatar
one thing i've noticed with the SSP is that the top of the spring doesnt sit tight with the tophat, meaning there's lateral movement of the spring so i have a feeling its the inner portion of the spring slapping the part of the top hat and protrudes down.
i tried asking Tein but they dont have a clue what im talking about. i figure i'll just ghetto fix it myself with a little bit of heavy duty rubber tape or something to prevent the direct contact between spring and metal top hat. i have a feeling people with OEM top hats dont have that much of an issue because the OEM top hat holds the spring pretty well from what i remember.
Old November 25th, 2009, 07:20 PM   #24
3.5L s/C'd 6 Speed
i never said anything about dumping my car, i live in Yonkers.. prob THE WORST streets in ny.. i just want to get rid of the wheel well gap i have with a $1400 setup and never had with a $135 set up.
Old November 26th, 2009, 02:42 PM   #25
3.5L s/C'd 6 Speed
what front camber kits DONT hit the fender apron lol
Old November 26th, 2009, 02:49 PM   #26
V6 6SPD
allgonoshow's Avatar
Just ditch the front camber kit if you don't want noise. I've never, in 5 years, ran camber kits and not once have I ever noticed any unusual wear.. and I am low low.
2002 Fully Loaded V6 6MT
allgonoshow is offline   Reply With Quote Quick reply to this message
Old November 26th, 2009, 03:03 PM   #27
3.5L s/C'd 6 Speed
its a very very strong possibility lol
Old December 13th, 2009, 05:16 AM   #28
3.5L s/C'd 6 Speed
so i swap wheels with a friend of mine since my tires are 1239102 times better then his and he uses his car in winter.
i look up at the control arm and see the problem finally
knocking into the apron
im gona hammer that part in, i dont feel like buying new uca's
Old December 13th, 2009, 11:12 AM   #29
4.0L
My jack points are folded...but they still function properly. My J pipe is fine...maybe some minor scuffs. My subframe is scuffed but there's no real damage to it.
And the 2 finger front + 1 finger back? Why not level it out at least?
VietNinjaJ30A1
2000 Honda Accord V6 Supercharged
Official Slammed Club Member #36 (Stage 1)
