Extreme tire wear (only 7000 miles) - Honda Accord Forum : V6 Performance Accord Forums
Old November 26th, 2009, 05:58 PM   #1
turbo_911's Avatar
Hello guys,
As you know I bought rims not to long ago (white 5Zigen's) and new tires along with them. The tires are General Exclaim UHP. I have Tein S-Tech springs on stock struts (though my front shocks are from 01 cl since mine started leaking and rear are still from accord). I did alignment after I put new rims to make sure no tire wear. Ok, now the problem, I drive to college (130 miles every day) and I've noticed extreme tire wear on my front left tire. The tires have tire wear indicator and in some places its like almost flat with tire thread. I would say it has like 40% of life left or so. Here's the thing, other 3 tires are still like new 90-95% of life left... I don't know what could cause this extreme tire wear on just only one tire?
Do you guys have any thoughts, suggestions?
Appreciate for the help. Thanks.
turbo_911 is offline   Reply With Quote Quick reply to this message
Old November 26th, 2009, 06:08 PM   #2
xXxCLS bOoStEdXxX
slowaccord's Avatar
maybe ur alignment is off only in one corner? like you could of hit a curb or bump
maybe u have a bad strut in one corner? this could cause feathering more than truly uneven wear. but thats one form of it.
thats two things off the top of my head
Old November 26th, 2009, 06:30 PM   #3
turbo_911's Avatar
well, but I did alignment 2 months ago and I replaced my front struts 3 months ago, since my oem ones started leaking but I didn't had such bad thread wear, hmmm that's strange. I will check with the alignment tomorrow if they are open otherwise i was thinking the maybe I got one bad tire that it wore off so fast?
Old November 26th, 2009, 06:48 PM   #4
no bent control arms right? its kinda weird only 1 is wearing out.
Old November 26th, 2009, 06:54 PM   #5
turbo_911's Avatar
umm I don't think anything is bent, I checked visually and everything is straight lol.
Ok, do you guys know what PSI I should run in 225/40/18 tires?
Old November 26th, 2009, 06:59 PM   #6
check ur tires. my tires hold 40 max so i run 35-37
Old November 26th, 2009, 07:10 PM   #7
turbo_911's Avatar
well it says they hold 51 psi max
i run them at 38-40. also when the tires were mounted at BMW dealership they put 32 psi.
Old November 27th, 2009, 01:44 AM   #8
awww cute stickers
AngusTEx's Avatar
The best thing to do now is to redo that alignment. A lot can happen in two months.
My tires are also 50 psi max, so I run 45-50 psi.
Better handling, better mileage due to less rolling resistance, and tires last muuuuuuuch longer.
&mpt=[CACHEBUSTER]">CBR600 F4i|CG3MT Solo2 ST #96
AngusTEx is offline   Reply With Quote Quick reply to this message
Old November 27th, 2009, 08:09 AM   #9
turbo_911's Avatar
Ok thanks I will make them check my alignment today again if they are open lol.
