rubbing issues... how to solve? - Honda Accord Forum : V6 Performance Accord Forums
Old May 20th, 2010, 12:49 AM   #1
Euro accord wannabe
aznboi128's Avatar
Hey guys
Just put my spacers on so here's the specs
18x8 +55 oem 8th gen wheels
225/40/18 kumho
h%r 20mm spacer
I got my fenders rolled which isn't the problem but it's where the rear bumper meets the body
pics
07 accord ex-l v6 6mt coupe / HFP kit on the way / tein / yakima / TE37
07 accord ex-l v6 sedan
99 accord ex-l v6 / WW kit / tsx retro / Tein SS coils / 08 accord coupe 18"s
aznboi128 is offline   Reply With Quote Quick reply to this message
Old May 20th, 2010, 01:24 AM   #2
DrOwZee's Avatar
gotta shave that off. the plastic piece where its the bumper tab is right? shave that off and relocate your tab and you should be good
DrOwZee is offline   Reply With Quote Quick reply to this message
Old May 20th, 2010, 02:02 AM   #3
Euro accord wannabe
aznboi128's Avatar
^ cool, how and where to relocate it?
Old May 20th, 2010, 12:41 PM   #4
DrOwZee's Avatar
mmm. people, usually just relocate the tab acouple inches back and shave the part that is rubbing
Old May 20th, 2010, 12:55 PM   #5
Vimal (vee-mall)
KnightRyder's Avatar
like this.... this is a coupe but im sure the sedan is very similar. these pics are AFTER i shaved everything off. its very easy really.
pull the wheel off.
drill a small hole as far back as you can (the bit HAS to be just barely smaller than the screw so that teh screw has something to grab otherwise its not going to hold securely.
then once the screw is relocated further back, take a grinder or good dremel and cut away everything infront of the screw like in my pics.
you probably wont need to get as aggressive as i did with the cutting but just play it by ear, literally... cut what you think is enough then test it out for a day or two, if it needs more work, keep cutting.
my wheels and tires stick out much more than yours so i had to cut a good chunk of my bumper material off too as you can see, the bumpers edge is supposed to about 1inch wide, as you can see from my pics, its now less than 1/4 inch. there is also metal behind the bumpers edge that ended up being an issue for me as well so i took a cut off wheel and cut the metal off too.
Old May 20th, 2010, 12:58 PM   #6
DrOwZee's Avatar
^^there you go, i should stop being lazy and shave mines too
Old May 20th, 2010, 01:14 PM   #7
Vimal (vee-mall)
another tip, which i know sounds stupid but trust me it helps.
get some lipstick your GF/wife/mom has laying around and doesnt use, or go buy a red wax pen and apply it all over the bumper tab and bumper edge, then go drive around hard on bumpy roads, pretty much the worst conditions your car will see so you can see how much rubbing COULD be possible. and make sure your gas tank is full. and weight down the trunk with random stuff or have 3 people sit in the back seats. then check again and see which areas rubbed away and cut about 1/8 in more than that and you should be good.
Old May 20th, 2010, 02:05 PM   #8
Euro accord wannabe
aznboi128's Avatar
thanks guys I got to give that a try
Old June 5th, 2010, 07:01 PM   #9
if i take 2 ppl at the back...my rear tires hit the fender even if i turn or go over a simple bump....any solution?
buddhizibi is offline   Reply With Quote Quick reply to this message
Old June 7th, 2010, 08:51 PM   #10
Vimal (vee-mall)
same thing goes for you. roll the fenders then relocate the bumper screw and grind away the useless stuff.
Old June 30th, 2010, 04:20 AM   #11
Boosted
WHITE_ACCORD's Avatar
you have pound all that to make it fit damn..
WHITE_ACCORD is offline   Reply With Quote Quick reply to this message
Old July 25th, 2010, 12:34 PM   #12
what are you guys doing to protect that area from rust once its cut?
jaron001 is offline   Reply With Quote Quick reply to this message
Old July 25th, 2010, 11:17 PM   #13
DrOwZee's Avatar
i just used primer
Old August 21st, 2010, 01:25 AM   #14
so what do guys do for rubbing in the front, mine rubs the tire on the inside were its all metal and kinda sticks out with the rubber coating stuff sprayed on it. is that what spacers are for?
killa cali is offline   Reply With Quote Quick reply to this message
