tire stretch .... info? - Honda Accord Forum : V6 Performance Accord Forums
Old May 20th, 2010, 03:44 PM   #1
Euro accord wannabe
aznboi128's Avatar
so what's the advantages/disadvantages of tire stretch?
I'm thinking of getting something like 205/40/18 to fit on my 18x8 so i wont rub lol
07 accord ex-l v6 6mt coupe / HFP kit on the way / tein / yakima / TE37
07 accord ex-l v6 sedan
99 accord ex-l v6 / WW kit / tsx retro / Tein SS coils / 08 accord coupe 18"s
aznboi128 is offline   Reply With Quote Quick reply to this message
Old May 20th, 2010, 04:05 PM   #2
xXxCLS bOoStEdXxX
slowaccord's Avatar
205/40/18 will look stupid. get a 215/35/18
Old May 20th, 2010, 04:08 PM   #3
Euro accord wannabe
aznboi128's Avatar
wont a smaller sidewall be even worse?
Old May 20th, 2010, 04:09 PM   #4
xXxCLS bOoStEdXxX
slowaccord's Avatar
or actually 215/40/18 in ur case might be better.
Old May 20th, 2010, 04:11 PM   #5
Brad
bdeitemeyer's Avatar
215/40s should be fine...205s would work but are unnecessary for your situation.
Old May 20th, 2010, 04:14 PM   #6
whats the specs on those wheels? a 225/40 is rubbing? WOw..
swollen_cu is offline   Reply With Quote Quick reply to this message
Old May 20th, 2010, 04:24 PM   #7
Euro accord wannabe
aznboi128's Avatar
18x8 +55 with a 20 mm spacer
tires are 225/40 18
it's the bumper thingy i need to grind that down but would like to still have streched
Old May 22nd, 2010, 08:41 AM   #8
tires are 225/40 18
18x8 with a 225/40 is definitely not stretched... lol
Old May 22nd, 2010, 09:22 AM   #9
inspire1318's Avatar
215/40 would be a good stretch and still good for every day driving
inspire1318 is offline   Reply With Quote Quick reply to this message
Old May 22nd, 2010, 03:58 PM   #10
Euro accord wannabe
aznboi128's Avatar
haha I know it's not stretched I need stretch to clear my fender... and I wanna go wider
Old May 22nd, 2010, 04:29 PM   #11
DV8
Hella Functional
DV8's Avatar
tire stretch is purely aesthetics. There is Zero performance gain for it.
Tire stretch is for people who want wide wheels for either the huge concave look, or the deep dish, but did not have the clearance to run correct size tires.
Old May 22nd, 2010, 04:49 PM   #12
Euro accord wannabe
aznboi128's Avatar
^ thank you! that's all i needed
Old May 22nd, 2010, 05:36 PM   #13
awww cute stickers
AngusTEx's Avatar
No advantages.
just to get "the look"
The only gain is a higher potential for the tire to come off the rim at a fairly high speed turn. It's rare but has happened.
&mpt=[CACHEBUSTER]">CBR600 F4i|CG3MT Solo2 ST #96
AngusTEx is offline   Reply With Quote Quick reply to this message
Old May 22nd, 2010, 05:41 PM   #14
Super IcyAccord
changaroo's Avatar
Originally Posted by AngusTEx View Post
No advantages.
incorrect. find me a case where that has happened and it wasnt user neglect. trust me, i had my doubts at first. but after driving around for a few months, ive had no issues.
stretched tires take a substantial more amount of pressure to bead (most of a time a cheeta has to be used). once the bead is sealed, and you arent retarded and let the tire pressure drop, the tire is harder to lose bead.
performance wise... not to mention, stretched tires stiffen the sidewalls, makes the car more predictable. look at all the drift cars that have been using it for years. no issues.
btw i wouldnt stretch a tire on a 8in wide wheel, it would look really goofy
Old May 22nd, 2010, 05:47 PM   #15
Euro accord wannabe
aznboi128's Avatar
I was just going to do a little stretch to make sure I dont rub
but I will get 9" wheels later
Old May 23rd, 2010, 05:38 AM   #16
DV8
Hella Functional
DV8's Avatar
It's true that some drift cars have stretched tires because it gives a linear breakaway. But if we're going to use an unapproved practice to stiffen up sidewalls, we're also putting excess force and stress onto the belts inside the tires.
We also need to keep in mind that drifters change their tires out after every event, and we're talking about a DD with stretched tires.
Just because you are still alive after a few months driving on stretched tires, does not make this practice safe or recommended.
This is the big point I want to make across for everyone that has or are deciding to go with stretched tires.
Tire Stretching is NOT SAFE! If you want to make a mod that compromise your safety, then that's your choice. Please don't be fooled for 1 second into believing that Stretched tires are safe, or it will increase your performance tremendously. You can get tires with stiffer sidewalls, you can get better tires for your spec of driving/race.
Function > Form "A show car may not be a race car, but a race car is always a show car."
Old May 23rd, 2010, 06:58 PM   #17
Growth Chart Specialist
Shenaniganz08's Avatar
stretched tires on a stock rim... yeah I don't know about that
Old May 23rd, 2010, 10:47 PM   #18
90 percent of the people with stretched tires aren't going to go autox anytime soon...
Fundillo is offline   Reply With Quote Quick reply to this message
Old May 23rd, 2010, 11:02 PM   #19
Super IcyAccord
changaroo's Avatar
you have to account for the fact that the stress dd'ers put on their stretched tires will never come close to the forces tires are exposed to on a drift car. juss sayin.
plus you cant really knock it until youve run a stretched tire setup, trust me. i thought exactly the same way you did
Old May 23rd, 2010, 11:20 PM   #20
awww cute stickers
AngusTEx's Avatar
chang, how bout do some e-brake drifts around the neighborhood and do an autocross and let us know how it turns out
Old May 24th, 2010, 12:16 PM   #21
Super IcyAccord
changaroo's Avatar
funny you ask lol. I was actually in the mountains this weekend doing a mountain run. As you can see, im still alive
Old May 24th, 2010, 01:57 PM   #22
trim your bumper and hammer in your bumper tab... You'll be set.
Old May 24th, 2010, 05:34 PM   #23
I went e-brake pulling with my rwd buddys lol
Old May 24th, 2010, 06:17 PM   #24
SSM A-SPEC TL
accordcoupe_ex's Avatar
OP, 215/40/18 should be good. Slightly stretched but not overly done to the point where the lip of the rim pops out the tire itself. I'm actually running that set-up with Nitto Neo-gen tires on my 18x8 +42 offset rims. Will be lower this Friday with the Koni yellows on full stiff & on the lower perch, hopefully no rubs .
accordcoupe_ex is offline   Reply With Quote Quick reply to this message
Old May 25th, 2010, 11:30 AM   #25
You can run a 225/40 and you wont rub. Y our offset is weak.
Old May 25th, 2010, 03:49 PM   #26
┌∩┐(◣_◢)┌∩┐
skatingclaybird's Avatar
I Auto X with my Z with slightly stretched tires and have no prob. Quit whining about safety.We compromise our safety everyday.
Old May 26th, 2010, 10:46 AM   #27
98JDMCL's Avatar
205 will be way to small! 215! I love those wheels!
98JDMCL is offline   Reply With Quote Quick reply to this message
Old May 27th, 2010, 08:40 PM   #28
SSM A-SPEC TL
Thumbs down
It's funny how you say that cause I'm hellaflush with my offset already without going too crazy. Also my 215's are flush with my fenders while my rims sticks out a tab more because my 215's are slightly stretched & still won't clear the fenders with tender mods & negative chamber. Weak offset? lol...
Old May 27th, 2010, 08:44 PM   #29
Brad
And...what setup of yours is hellaflush? I see in one of your posts above you mention an 18x8 +42 setup, is that the one? Got any pics? I'm new to the whole flush wheels and stretched tires idea...
Old May 27th, 2010, 09:20 PM   #30
SSM A-SPEC TL
Here--->http://www.v6performance.net/forums/...d.php?t=203361
Rolling fenders tomorrow cause I'm going a tab lower to 1 finger gap. I don't mean to start up a huge flame but for someone to actually call me out of the crowd & say my offset is weak, C'mon grow up I was just trying to help out the OP.
