Tire Pressure Question - Honda Accord Forum : V6 Performance Accord Forums
Old August 10th, 2010, 03:32 PM   #1
In progress ;)
KO iNfAmOuS's Avatar
Question Tire Pressure Question
Just got new rims/tires and my originals always got filled up to 32 and were perfect..I just got Falken ZIEX and filled up to 34 and they still look somewhat flat...max psi rating on the new ones is 51 im sure it needs to be higher..right?
L.I. - 631 - 98 V6
KO iNfAmOuS is offline   Reply With Quote Quick reply to this message
Old August 20th, 2010, 03:44 PM   #2
Don't go off the max pressure rating on the tire, thats just a warning to not go higher that that pressure. 34 lbs should be enough but I would call whoever you bought them through and check the running pressure for the tires. Of course the fronts should be 2-4 ibs higher than the rear because of the weight different over the tires. Hope this helps.
Crazyace1 is offline   Reply With Quote Quick reply to this message
Old August 21st, 2010, 01:09 AM   #3
i usually do 36 all around i think ill 36 front 33 back now tho cuz of what crazy said
killa cali is offline   Reply With Quote Quick reply to this message
Old August 21st, 2010, 03:00 PM   #4
storms's Avatar
I always thought that factory settings were 32?
storms is offline   Reply With Quote Quick reply to this message
Old August 21st, 2010, 08:54 PM   #5
jsiriusvtec
Guest
Posts: n/a
30PSI for Sedans w/ 15" wheels
Old August 21st, 2010, 09:11 PM   #6
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
I run a 17 inch rim w/ Ziex 912's. profile is 215-50. I run 41 up front/39 rear.
Old August 22nd, 2010, 07:38 PM   #7
Don't warp it -Torque it
Str8racn's Avatar
I would go off of the factory recommended, but also depends on what kind of ride you want as well.
Str8racn is offline   Reply With Quote Quick reply to this message
