Replacing a single alloy wheel - Honda Accord Forum : V6 Performance Accord Forums
Old November 17th, 2010, 01:01 AM   #1
One of my alloys has started leaking through the metal at a spoke and needs to be replaced. I need to find a silver Fox RS-5 alloy wheel with the right fit for a 99 V6 Coupe.
As far as I know these are the numbers:
Size 17x7.5 JJ
Offset/ET +35
PCD 5x114.3
Bore 70.3
I got the size and offset from the back of the wheel. Can anyone confirm the PCD and Bore as correct? I picked them up from this website: http://www.alloyguide.com/Honda.php
Also, if anyone has a silver Fox RS5 wheel with the right fit going spare in the UK I'll buy it off you.
RobinGBrown is offline   Reply With Quote Quick reply to this message
Old November 17th, 2010, 03:21 PM   #2
That looks right to me... Bore isn't important. Im not sure what diameter the hub is, but almost all non-OEM wheels are larger than that. If you put all 5 lugs on semi-tight before the wheel has the cars weight on it, it should be centered and the fact that the wheel is lug-centric isn't a issue.
7.5" wide is very standard, +35 would make the wheels look almost like they're sticking out, and the 5x114.3 is right.
Old November 18th, 2010, 12:10 AM   #3
Thanks, the wheels do almost stick out, but mine's not lowered so it looks alright to me.
