Sway kit question and install - Honda Accord Forum : V6 Performance Accord Forums
Old January 27th, 2011, 11:53 PM   #1
DiceX's Avatar
Ok so I've had my suspention technique sway bars laying around. I got them off a friend a while back. When installing them, do I need to oil up the mount that the bar goes in and how hard are they to install? Any pics of other sway kits?
Old January 28th, 2011, 08:32 AM   #2
work in progress
whtonblkv6's Avatar
Send a message via AIM to whtonblkv6
The only thing you'll probably need is some sort of lubricant as the bolts that hold the sway bars in place may be rusted. So get some penetrating lubricant, spray it down the day before or maybe a couple hours before and go fot it!
whtonblkv6 is offline   Reply With Quote Quick reply to this message
Old January 28th, 2011, 09:20 AM   #3
DiceX's Avatar
Ok so on the rubber part that the sway bar goes in I don't have to put any lubricant on there?
Old January 28th, 2011, 01:49 PM   #4
work in progress
whtonblkv6's Avatar
I don't think so. But, I'll let someone else confirm or deny that.
Old February 15th, 2011, 07:03 PM   #5
SSM AV6 Coupe
ReggieReGGCG2's Avatar
Send a message via AIM to ReggieReGGCG2 Send a message via Yahoo to ReggieReGGCG2
Yea your gonna need to lube up the poly brackets or they will squeek wen the sussy flexes. I helped a friend install his 04 tl rear sway and it came with lube that they recommend using because the sway bar does move
Sent from my SGH-T959 using Tapatalk
ReggieReGGCG2 is offline   Reply With Quote Quick reply to this message
Old February 15th, 2011, 07:28 PM   #6
you can use teflon tape instead of the lube. just wrap it around the bar where the mounts go
kn0x47 is offline   Reply With Quote Quick reply to this message
Old February 19th, 2011, 12:50 AM   #7
Godzilla
syclone's Avatar
here.. Maintenance: Swaybar Bushing Lube
Solo, Track, Drift, Kart... Race!! #114
-RIDES: '92 Skyline R32-GTR, '01 Honda s2000, '99 Accord EX 5-spd
syclone is offline   Reply With Quote Quick reply to this message
Old February 20th, 2011, 12:40 AM   #8
DiceX's Avatar
Thanks for the info, I need to buy the tape I installed the sway bars and the front makes noise at times so I'm going to try this I'll post up pics soon
