Ultra Racing lower 4-point brace & Cusco lower Tie bar installed on CG2(01 Accord) - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By Doctor_X
Old April 30th, 2011, 09:35 PM   #1
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
The U/R 4 point brace uses existing hardware. Just mount it up with your OEM bolts. Same for the Cusco.
!! There is only about 1/4 of an inch between the flex pipe and the U/R brace. Hard to tell in the pic but theres some room there. !!
Also, I'm 100% sure the U/R brace will fit 98-02 V6 Accords - Coupe and Sedan. It is sold as a brace for the CG2 and has a picture of the Sedan. But, we have test fitted the U/R brace on Dinzdales V6 Sedan and it fits just like mine.
I don't know if it will fit the 4 cylinder Accords. I don't know if they have the same sub-frame(K-frame).
I installed the U/R brace about 1 month ago. Then, I installed the Cusco today so I could see if it made any difference with the U/R brace.
At this time, I haven't tested out the Cusco. After I installed the Cusco, I polished and waxed my wheels. I got a late start today and didn't finish them until tonite.
I did feel a difference with the U/R 4 point brace. When you hit bumps the front end stays more planted. You can feel the suspension working more. It's more stable.
However, I do have some added vibration at idle(when in Drive) and when crusing around 1800-1900 rpm. But, I attribute this to the poly-filled OEM engine mounts. I already had alot of vibration when the J35 went in, so that same vibration is being transmitted thru the U/R brace. If your running on non-polyfilled OEM mounts, you probably won't have any if just a little vibration.
It is hard to tell from the pics, but the Cusco sits just as low as the U/R brace. I have not had any clearance issues with the U/R brace, but I am only lowered 2 inches on Eibach Sportlines. If your slammed you can forget using either brace.
I also looked at the rest of the chassis and I don't see any place to mount a mid or rear Bolt-in brace. There are no OEM mounting bolts you could use. You might be able to weld some in, but the exhaust pipe might be an issue. You would need to either have it go over the piping, if possible, or under. But if you go under the piping you will lose ALOT of clearance.
So, we could go inside the car for additional bracing. You could use a *room/floor bar, harness bar, or an Autopower steet roll bar.
* Yet to be determined.
I kinda looked at room/floor bars for addt'l bracing, and so has Brian6Speed(Acura CL owner). But, there is no specific application for the Accord or CL. There might be one we could use for another model of car. I'll check into it. I think Brian6Speed is checking into it also.
I also considered the Autopower roll bar, but I use a wheelchair and I'm not sure if that would interfere with my wheels going behind the driver seat. Besides, that is not a project I can do by myself.
- Michael
_____________________________________
5-12-11 UPDATE(review of Cusco brace):
Could not really tell any addt'l benefit from the Cusco. However, I would think it is reducing flex in that area somewhat.
Overall review :
With BOTH pieces --- Hard cornering and taking curvy roads feels more "stable"; Ultra Racing uses this term to describe the effects. Front end feels more planted. If you need to make an "adjustment" while in a curve/turn, the "feel" of the front end is alot more firm, not squishy. I like the feeling the bracing has added. Road Course and Auto-X would benefit from chassis bracing. Daily driving could see some benefit; emergency maneuvers from dummy drivers, etc.
Best bang for your buck would be the Ultra Racing 4 point. and if you wanna dib out a lil more cash for another tie bar, I would do it...won't make it any worse?
....kinda looking into this piece for now. Lower REAR 4 point, Lil bit more research and I will know.
Old April 30th, 2011, 09:37 PM   #2
Boosted!
ComptechV6's Avatar
yay im glad my bar came to use.... which bar did you buy it for? cg4 or
Old April 30th, 2011, 10:31 PM   #3
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
You bet!
Yes, CG4. That is the only 6th gen Accord application that Ultra Racing has listed.
Honda Accord CG4 (2000) Aftermarket rear sway bar,Stabilizer bars,anti roll bar,front sway bar,anti sway bar,replace sway bar
Old May 1st, 2011, 12:28 PM   #4
Super IcyAccord
changaroo's Avatar
im assuming these bars are a no-no if your car is pretty low? my header flex pipe (the smaller one you see in the pics) is already scraped to hell.
Old May 1st, 2011, 12:30 PM   #5
Brad
bdeitemeyer's Avatar
Correct, don't bother Eric.
Old May 1st, 2011, 02:35 PM   #6
Is the brace rusting? Also, where did you get the brace from?
CL SLeePeR is offline   Reply With Quote Quick reply to this message
Old May 1st, 2011, 04:39 PM   #7
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
I just went and checked it out. it's roadkill blood. I wiped it off. I hit it just 3 days ago, part of the body was sticking up and I heard it hit the bar.
Bought it from an Ebay seller who is in Malaysia. That is where Ultra Racing is located. This seller had the lowest prices. Took 3 days to receive it via UPS courier. Paid no custom fees, etc. Cost me $134 shipped.
Seller is: ready_to_discount
Now, there are some USA sellers. But, I doubt they stock any of the bars for the Accord. Don't quote me. If they have to order a brace it might take a while. Out of the 3, I would buy from Throwdown. They have been selling bracing a lot longer than the other 2 and might be able to get them shipped over faster. Also, you are going to pay more from a USA seller --- on average about $50 more for the 4 point brace.
Throwdownperformance.com Excelerateperformance.com HeeltoeAuto.com
Old May 1st, 2011, 04:42 PM   #8
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
like i mentioned in my original post:
If your flex pipe is already scraped to hell, you are too low. Raise it up foo'
Old May 1st, 2011, 11:40 PM   #9
Do you think it will be possible to test it on a 4 cyl?
Old May 1st, 2011, 11:43 PM   #10
Brad
Why? What would be different on an i4?
Old May 2nd, 2011, 04:34 AM   #11
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
^Deitemeyer, I posted this on 6GA also and the question about the U/R brace fitting a 4 cylinder came up. I don't know if the 4 cylinder sub-frame is the same as our V6.
Can you confirm if the 4 cylinder and V6 sub frame are the same?
...if they are, then it would work on ALL 98-02 Accords.
Old May 2nd, 2011, 04:47 AM   #12
Brad
The sub-frames are different part numbers, but that doesn't mean the bolt holes are in different locations. I know for a fact I can swap in a v6 subframe (hypothetically for a v6 motor swap) onto my car with no modifications as I've tested this during the time my car has been down.
I wouldn't waste my time answering questions for half the people on that forum. You've done enough work with your recent write-ups, let them figure out the rest.
Old May 2nd, 2011, 09:45 AM   #13
Derek
damage2000's Avatar
Mike, I found your old thread on AZ, UltraRacing
Looks like there are a variety of parts that can be used on the Accord/CL/TL's.
Not sure if the parts are all available still, but I will be looking in to that.
damage2000 is offline   Reply With Quote Quick reply to this message
Old May 2nd, 2011, 11:08 AM   #14
Destroyer of Tires
Doctor_X's Avatar
Those look sweet but those would get raped in a day if they were on my car.
FFFFFUUUUUU
Old May 2nd, 2011, 11:31 AM   #15
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Most of the items you see in that thread are not for the 98-02 Accord and 99-03 CL/TL.
Fender braces - none.
Although, Throwdownperformance is checking with Ultra Racing to see if there is an application that would work for our Accords based on someone else's inquiry. I'm in contact with Throwdown on this issue.
Rear chassis braces - none. That picture of the rear brace is for the 04-08 TL. possibly a TSX also
Side chassis braces - none. Again, they are for the 04-08 TL and TSX.
like i mentioned above in my original post, there are not any OEM bolts or mounting places on the chassis for any addt'l Bolt-on braces(mid or rear). I took a good long look under there when I installed the Cusco, and I just didn't see any more places to mount bracing that Bolts-in on the chassis. But, I have no idea if the coupes would really need any more on the chassis itself.
I have been told by a couple people that the Autopower street roll bar does have a definite effect on the car. I think if you added the Autopower bar, in addition to the 2 pieces I have installed, that would be all you would need. I'm no chassis expert though.
Old May 2nd, 2011, 11:35 AM   #16
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
FFFFFUUUUUU
well if your close to being low as Keychain, your driveway would take care of that in one swift motion. POW!!!
Old May 2nd, 2011, 12:44 PM   #17
Destroyer of Tires
Doctor_X's Avatar
I can get into my driveway but I still scrape little haha. The brace looks real nice though!
ESADDICTION likes this.
Old May 2nd, 2011, 02:56 PM   #18
Derek
damage2000's Avatar
Yeah, I confirmed the above when I checked the links....sad, but true. Every little bit helps. Appreciate the info you posted though, still helpful.
Old May 3rd, 2011, 02:59 AM   #19
RoadKill..
I was also looking on ebay, just a little worried about getting a replica. There are a few sellers from Malaysia. I will look into the seller you listed. Did you run the serial number to check for authenticity? I also found that seller throwdown on H-T.com
Old May 3rd, 2011, 04:26 AM   #20
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
RoadKill..
I did not run a serial number check, or register my particular brace. But yes, a person should register that serial# for warranty purposes. That is how Ultra Racing keeps track of their products and provides warranty service.
Old May 12th, 2011, 04:18 PM   #21
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
updated original post with review. read it.
Old November 5th, 2011, 12:23 PM   #22
Boosted!
ComptechV6's Avatar
Did you ever figure out for the rear 4?
Old November 22nd, 2011, 07:08 PM   #23
Nice stuff. This + fender braces would be great for track days.
What about the rear 4 point bar? Does it fit?
blur is offline   Reply With Quote Quick reply to this message
Old November 22nd, 2011, 08:55 PM   #24
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
No, not 100% sure. just compared photo's of the rear subframe and it looks to be nearly the same. So, the rear mounting points should be correct.
The front mounting points, I can't be sure on those.
There is a member on 6ga.com who may buy the rear 4 point and try it in the next few months. I'm in contact with him, so we'll see.
Old November 23rd, 2011, 02:37 AM   #25
Any chance of fender braces fitting?
Old January 28th, 2017, 04:28 PM   #26
NSWDoc's Avatar
so does the rear brace fit and if so can you give me the part numbers for the front and rear braces please. thanks!
NSWDoc is offline   Reply With Quote Quick reply to this message
