ESP.NET Traction bar set up - Honda Accord Forum : V6 Performance Accord Forums
FAQ Members List Calendar Mark Forums Read Insurance
LinkBack Thread Tools
Old October 21st, 2013, 04:16 PM
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
ESP.net 98-02 Accord Traction Bar System with Front Torque Mount Kit F/H 4 cyl Models - 6th Gen Accord DIY and Performance Forums
Posted this link over here in case anyone is not aware of it over on 6thgenAccord.com
He's got the 4 cylinder model done. He is working on a V6 model now.
Some of you guys over here got some real power going down. Maybe this will help you with traction for your dragstrip runs.
WHEEELMAN is offline   Quick reply to this message
Old October 22nd, 2013, 10:43 PM
I'm deff buy one if they make for v6, let us know if the item ready, thanks wheelman for share this.
6thaccord98 is offline   Quick reply to this message
Old October 23rd, 2013, 08:39 AM
Derek
damage2000's Avatar
Michael, not sure if you have talked with them, how does their setup compare with the UR bar you got?
damage2000 is offline   Quick reply to this message
Old October 23rd, 2013, 02:33 PM
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
Have not talked with John @ ESP.net.
The U/R 4 point does nothing for wheelhop/traction. It only reduces flex in the chassis.
The ESP.net traction bar set up is using heim joints (a solid connection) in place of the radius rod bushings(rubber). My guess would be, that is part of the effect of reducing wheelhop. In addition, he has a torque mount that mounts to the engine block that reduces or prevents the engine from moving --- similar to using solid engine mounts and/or a Ingalls "stiffy" engine damper.
Old October 23rd, 2013, 10:14 PM
DiceX's Avatar
So where does this exactly connect on our cars
DiceX is offline   Quick reply to this message
Old October 23rd, 2013, 10:32 PM
On Our K frame.
Old October 25th, 2013, 08:05 AM
Derek
damage2000's Avatar
So, potentially, to be used in conjunction with the UR brace?
I already have the Innovative Mounts in, but whatever else can be used to keep the front end planted and as much power to the wheels as possible, is always a good thing.
Old October 29th, 2013, 08:45 PM
DiceX's Avatar
So how much are these going for?
Old October 30th, 2013, 02:10 PM
J35 _ 5-Speed A/T
WHEEELMAN's Avatar
$350 w/o the front torque mount kit -- for the engine.
And, John says less than $100 for the front torque mount kit add-on. So maybe $450 total.
But, that is for the 4 cylinder version, V6 version might be a lil more?
Old October 30th, 2013, 04:52 PM
✠ 2nd Amendment'r ✠
99cfENVYv6's Avatar
This would definitely be added to the "wanted list", even with just a basic 3.2 swap I had bad wheel spin.
99cfENVYv6 is offline   Quick reply to this message
