06-07 radio on 03-05??? - Honda Accord Forum : V6 Performance Accord Forums
Old May 22nd, 2012, 11:27 PM   #1
Ace111's Avatar
I was wondering if there is a difference in radio connector between the 06-07 and 03-05? I know there's dual climate and single climate but my main concern is the years. Im planning on doing a retro fit of a double din into the stock radio spot and i have a chance to pick up an 06-07 radio. Any help would be appreciated. Thanks!
Ace111 is offline   Reply With Quote Quick reply to this message
Old May 23rd, 2012, 11:52 AM   #2
Slammed & Stunning
MatthewYu's Avatar
I highly doubt it.
I have an '04 and a '07 and I removed the OEM radio for both to install the USA-Spec. Everything looked the same.
Old May 23rd, 2012, 12:21 PM   #3
Duck617's Avatar
I sold my 06 radio to someone with an 05 and it worked with no problem.
Duck617 is offline   Reply With Quote Quick reply to this message
Old May 23rd, 2012, 05:14 PM   #4
Ace111's Avatar
Thanks a lot Matthew and Duck! Hope the double din project goes through. Don't really like replacing my cubby spot, love that little pocket.
Old May 24th, 2012, 10:30 AM   #5
204
can a 05 navi unit work on a 07
204 is offline   Reply With Quote Quick reply to this message
Old May 24th, 2012, 11:36 AM   #6
Duck617's Avatar
I install a navi from an 05 into my 06. If that helps.
Old May 24th, 2012, 02:58 PM   #7
Ace111's Avatar
^ Did you have single or dual climate control? If single, was rewiring complicated?
Old May 24th, 2012, 03:17 PM   #8
Duck617's Avatar
I had dual so the swap was simple for me. But I am sure if you have single and talk to Marvin who makes the harness for the swap it should be a simple plug and play. The hard part is running it to the trunk.
Old May 24th, 2012, 03:32 PM   #9
Ace111's Avatar
How do you like the OEM navigation? Reliable? As in direction wise and reroute time?
Old May 24th, 2012, 03:55 PM   #10
Duck617's Avatar
It's good I just need the updated disk. But other then that I am a fan
Old June 5th, 2012, 04:48 PM   #11
Czechopino
vasekvi's Avatar
should be swappable as long as the trim level matches - dual zone with dual zone climate control, single with single - but there may be a variation on the premium setups that came on 6mt models, as i have seen test fitting the lame autosoul aftermarket head unit that worked fine in my 03 sedan with dual zone climate but did not work in a friends 06 6mt coupe with dual zone.
My SSM Sedan Mod Thread
Old June 23rd, 2012, 11:56 AM   #12
jweezy's Avatar
Where can I get a OEM navigation system? -- It's pretty hard to get one here in Canada.
jweezy is offline   Reply With Quote Quick reply to this message
Old June 23rd, 2012, 09:24 PM   #13
Duck617's Avatar
eBay. There is the whole pnp for 1500
Old June 24th, 2012, 05:18 AM   #14
Duck617's Avatar
Acurahondatech1 I think is his user name.
Old June 24th, 2012, 01:58 PM   #15
V6 M6
Glepage22's Avatar
I have my oem 06 Radio out of my V6 Coupe. Perfectly in shape.
If someone is interested, make me an offer!
The radio come with the upper dash part. Mint too.
Guillaume
Glepage22 is offline   Reply With Quote Quick reply to this message
Old June 24th, 2012, 10:55 PM   #16
757Accord's Avatar
i put a 03-05 radio in my 07. the only thing that i didn't like about it was that when you turned the fan on, it wouldn't matter what selection was in green, it blew out regardless. LOL
757Accord is offline   Reply With Quote Quick reply to this message
