Cloudy headlights help so ugly !!!! - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By toinkee69
Old June 21st, 2012, 07:49 PM   #1
Hondabob8o8's Avatar
I'm looking to fix my headlights there all cloudy an foggy an suggestions ????
Hondabob8o8 is offline   Reply With Quote Quick reply to this message
Old June 21st, 2012, 08:35 PM   #2
JDM UC1
toinkee69's Avatar
$8 turtle wax headlight restoration kit.
Old June 21st, 2012, 08:40 PM   #3
VTEC PWNES ALL
2muchbass's Avatar
^this^
2muchbass is offline   Reply With Quote Quick reply to this message
Old June 21st, 2012, 09:42 PM   #4
dharding413's Avatar
Or go with the 3M kit. A bit more pricy, but I've heard many good stories about it.
dharding413 is offline   Reply With Quote Quick reply to this message
Old June 21st, 2012, 10:07 PM   #5
I used the Sylvania restoration kit with great results. It's not the cheapest or most expensive and can be done with no power tools. The kit also all inclusive.
I've also used the Turtle wax kit which is about $6 cheaper but then the results weren't as good either.
rdrage is offline   Reply With Quote Quick reply to this message
Old June 21st, 2012, 10:38 PM   #6
951cm6's Avatar
my friend had the rain-x kit in his garage and i used that on mine, it made a HUGE difference. not sure how much it is but i would suggest that one.
951cm6 is offline   Reply With Quote Quick reply to this message
Old June 21st, 2012, 10:38 PM   #7
JDM UC1
toinkee69's Avatar
3M kit just left scratches on my headlights.
Old June 21st, 2012, 10:56 PM   #8
Growth Chart Specialist
Shenaniganz08's Avatar
Sorry to say but its probably your fault for not taking your time.
Wetsanding is a bit of an art, you can't just rush it, you need to develop a consistent technique and make sure you completely get rid of all the underlying scratches before you move onto the next sanding grade.
3M kit review and tips
http://www.v6performance.net/forums/...on-system.html
and some other projects
Old June 21st, 2012, 11:02 PM   #9
JDM UC1
toinkee69's Avatar
i guess so. don't have all the time in the world to play around.
otsb708 likes this.
Old June 22nd, 2012, 01:29 AM   #10
All of those are short-term solutions; once you remove the original two part sealing layer, the surface will haze again from UV exposure.
Old June 22nd, 2012, 04:56 AM   #11
So what is the long term fix
Old June 22nd, 2012, 05:02 AM   #12
Thanks everyone I think I'm going with the 3 m
Old June 22nd, 2012, 07:11 AM   #13
k24
FRAUDULENT SELLER
k24's Avatar
Send a message via MSN to k24 Send a message via Yahoo to k24
Long term fix.. is after it had been restored you need to apply a clear film over the lenses..
k24 is offline   Reply With Quote Quick reply to this message
Old June 22nd, 2012, 08:21 AM   #14
Clear film what do you mean like a vinyl or something ????
Old June 22nd, 2012, 08:28 AM   #15
It annoys the crap out of me that someone always brings this up whenever headlight restoration is brought up
If you wax your headlights (nxt Or any other wax that protects against uv rays) your headlights will not haze
After several years my neighbors headlights still look great, and all the other headlights I've restored equally look great. I completely sanded down my TYC lenses and they are 100% clear
Old June 22nd, 2012, 09:27 AM   #16
M![email protected] \_(ツ)_/
HEcreated487's Avatar
^^ Curious on whether we would need to apply wax regularly? Or "one deal seal" adequate/acceptable?
Old June 22nd, 2012, 01:33 PM   #17
I'll elaborate a little more...
Yes, you can apply wax, but even that is not as durable as the original coating. If you apply it regularly (every 1-3mos depending on season and level of sun exposure), it will be a moderate-term solution. I would recommend a synthetic wax over carnauba.
I've used headlight film (Lamin-x) in the past; the thicker films reduce light ouput. I would only use them if I had HIDs. If running halogen bulbs, I would stick to the thinner (<10mil) films. These are a good solution, but you must apply wax to these to keep them pliable.
I'm currently working on a lens rehab project. My goal is to seal the freshly sanded lenses with 2K aerosol clear, which is a pretty new type of product. I hope that it will be just as durable as the OEM lenses.
Like mentioned above, TYC lights seem to make solid replacements if your lenses are irreparably pitted/scratched. I've never used them personally, but I have had fitment issues using DEPO headlights in the past.
Old June 25th, 2012, 07:25 AM   #18
Carpe Diem
ikethegreat's Avatar
Instead of waxing regularly, purchase some Opti-Coat 2.0 and put that on them. It lasts for years.
The 3m kit works pretty well. Here is a link to my DIY for the 3m kit.
http://www.v6performance.net/forums/...iy-review.html
Old June 25th, 2012, 03:55 PM   #19
Opti-Coat sounds interesting...
Old June 25th, 2012, 09:08 PM   #20
I've researched this to no end. There was a great thread on Autopia.org about this. If you opticoat your car (or put vinyl on it etc) yes it will stay clean longer, get less dirty and even scratch less. But you can't compare it to the gloss/shine/swirl free finish of a freshly detailed car. It's a tradeoff: perfect looking car that needs more maintenance or a car that looks good but not perfect.
Here's a good thread on opticoat and headlights
Headlight sealant: spar urethane vs. opti coat 2.0 - Page 6 - Auto Geek Online Auto Detailing Forum
Let me sum this up for you: THERE IS NO LONG TERM FIX
You can respray your headlights with factory clear coat, or even buy brand new headlights, etc they will all eventually haze
The only long term solution is PROPER MAINTENANCE
If I can wax my headlights every 3 months and keep them looking 100% brand new looking, then to me that is the best solution.
