LED Flasher Relay/Unit? - Honda Accord Forum : V6 Performance Accord Forums
Old October 29th, 2012, 12:35 PM   #1
bigbird's Avatar
Hey guys, Was looking into converting my brake and turn signals to LED but really didn't want to get load resistors for each bulb. I was trying to find an LED compatible Flasher Unit/Relay but I can't find one that matches the stock unit/relay. I read here that is the best solution but no luck on a part number or something to really look for. Is there one available or should I just go with the load resistors?
04 coupe EX-L V6 6M
bigbird is offline   Reply With Quote Quick reply to this message
Old October 29th, 2012, 01:05 PM   #2
I looked into this a while ago; I remember reading something about modding the stock Omron/Orion? flasher under the dash by adding a resistor. I was having a hard time wiggling up under the dash to try and pry it off, so I gave up.
+1 for trying to figure this out
Old October 30th, 2012, 04:47 PM   #3
bigbird's Avatar
After looking around some more it looks like it has to be load resistors after all.
Old November 3rd, 2012, 07:06 PM   #4
zetaroy's Avatar
Maybe try these. At least you won't have to splice. 7440 LED Hyper Flash Fix Wiring Adapters For Turn Signal Lights
zetaroy is offline   Reply With Quote Quick reply to this message
Old November 3rd, 2012, 07:51 PM   #5
bigbird's Avatar
Damn, where were you a few days ago? Bought some load resistors but they didnt require me to really cut anything. I am having trouble doing the front turn signals. Between the red/black, brown and black wires I cant tell which is the flashing wire...any help?
04 coupe EX-L V6 6M
Old November 4th, 2012, 06:07 PM   #6
zetaroy's Avatar
I use this thread for reference. Good luck. http://www.v6performance.net/forums/...y-coupe-3.html
Old November 4th, 2012, 07:03 PM   #7
bigbird's Avatar
perfect! thanks.
04 coupe EX-L V6 6M
