hybrid mirrors on a non hybrid - Honda Accord Forum : V6 Performance Accord Forums
Old December 26th, 2012, 03:40 PM   #1
bozos_si's Avatar
Can anyone tell me if you can get all the options to work? If so what is the best way to do this? I have the mirrors and I am wondering if there is any way to get the heated mirrors to work. I am thinking buying the switch and a cut harness. would this be all i need? Or is there more wires going to the swith for the heated mirror options? If anyone has done this please let me know the best way of hooking these up.
Thanks
Old December 26th, 2012, 03:40 PM   #2
bozos_si's Avatar
Sorry. I am looking to do this on my 06 accord ex sedan.
Old December 26th, 2012, 05:25 PM   #3
mobiless2's Avatar
Send a message via Yahoo to mobiless2
Why not tie the heater mirror wire to rear defroster wire? That way it looks clean, & functions when you use rear defroster.
mobiless2 is offline   Reply With Quote Quick reply to this message
Old December 26th, 2012, 05:30 PM   #4
bozos_si's Avatar
I was thinking that but could that over load it? I dont want to blow a fuse or cause a wire fire.
Old December 30th, 2012, 09:42 AM   #5
Johan
would the hybrid mirrors work on a 7th gen coupe? because i asked around n i heard the tsx mirrors dont fit on coupes
J30owner is offline   Reply With Quote Quick reply to this message
Old December 31st, 2012, 06:47 PM   #6
Bdub95's Avatar
Send a message via AIM to Bdub95 Send a message via Yahoo to Bdub95
I have the Hybrid Mirrors on my coupe and all the functions work. What you have to do is cut the wires on the stock harness and wire in the wires from the hybrids into the wire that does that function on the stock harness. I hope that makes sense.
The way i figured it out was i took the wires on the hybrid mirrors and touched them individually onto my positive battery terminal to see if it was Heat,up and down,side to side, etc. Then i found the diagram somewhere of the stock mirror wires and just wired them into that particular wire.
Basically i cut the harness off the hybrids and swapped it with the harness from my stock lights and plugged it back in after i got the colors right.
Bdub95 is offline   Reply With Quote Quick reply to this message
Old December 31st, 2012, 06:50 PM   #7
Bdub95's Avatar
You have to swap the bases. That's what i did.
