Headlight height adjustment and straightening cutoff line - Honda Accord Forum : V6 Performance Accord Forums
Like Tree1Likes
  • 1 Post By jweezy
Old March 2nd, 2013, 08:50 PM   #1
jweezy's Avatar
Just recently acquired a set of retrofits from a local but the cutoff line for one of the sides is slightly on an angle (not a straight line) but my biggest problem is trying to adjust the height of this headlight. It seems to be approx. 2 inches lower than my other so I've searched around but I didn't find anything online that made my life any simpler in adjusting it. Many of them recommend using a flat head screwdriver to turn the unorthodox dial but I don't think I am finding the right position for it.
Hope any of you experts can help me out.
Any helpful comments are appreciated, thanks in advanced!
EDIT: Here is the uploaded picture of the retrofits from my car.
07 Accord Coupe
jweezy is offline   Reply With Quote Quick reply to this message
Old March 2nd, 2013, 09:11 PM   #2
pictures?
Old March 2nd, 2013, 10:47 PM   #3
dont deviate
htekken's Avatar
So have you tried adjusting it using the factory bolt like suggested? Assuming it's still functional. And instead of a screwdriver, it's easier to use a socket wrench/ratchet. probably a 10mm could be an 8mm.
htekken is offline   Reply With Quote Quick reply to this message
Old March 2nd, 2013, 10:55 PM   #4
dont deviate
htekken's Avatar
So if you were to go and try to adjust the beam with the bolt to be higher. you'd turn the bolt clockwise until it's where you want it. Cuz i believe the bolt is higher up on the back of the housing.
Old March 3rd, 2013, 01:27 AM   #5
jweezy's Avatar
My apologies, I don't have a picture right now but I will upload one soon.
Can you guys show me where exactly? Apparently you're suppose to go at a angle with a flat screwdriver? Is it just a rivet that you turn with a 10mm socket?
Any pics you guys can include to show how?
07 Accord Coupe
Old March 3rd, 2013, 01:44 AM   #6
jweezy's Avatar
Originally Posted by thisaznboi88 View Post
pictures?
Is it possible to change the angle of the cutoff line without disassembling the entire headlight?
07 Accord Coupe
Old March 3rd, 2013, 01:57 AM   #7
Did you retrofit the headlights yourself? or did you buy aftermarket headlights with projectors?
Accord6Speed909 is offline   Reply With Quote Quick reply to this message
Old March 3rd, 2013, 02:00 AM   #8
jweezy's Avatar
A local retrofitter did the project, and used OEM headlights with Morimoto Mini Projectors. He did the retrofit without the car present though which makes me believe he couldn't have done it properly without the vehicle???
07 Accord Coupe
Old March 3rd, 2013, 10:33 AM   #9
Just take out the headlight and adjust the projector. They are just bolt on projectors. You can fix the rotation yourself. To raise the headlight there is a 10mm bolt on the back of the headlight that you can adjust yourself if they are oem headlights. IF they have are aftermarket it is a philips head.
Old March 3rd, 2013, 12:10 PM   #10
jweezy's Avatar
To adjust the projector, do I just turn the dial of the projectors? And for the height adjustment, where is this 10mm bolt in the back of the headlight? on the far right side closest to the wheel well or close to the front/grille?
Thanks for the help thus far.
07 Accord Coupe
Old March 3rd, 2013, 01:49 PM   #11
vertical hieght you use the 10mm on the back of the headlight. For adjusting the projector itself to make it level horizontally you need some pliers and then you grip the bulb holder and turn.
Old March 3rd, 2013, 04:29 PM   #12
jweezy's Avatar
Is this where I am suppose to turn it?
thisaznboi88 likes this.
07 Accord Coupe
Old March 3rd, 2013, 04:43 PM   #13
dont deviate
htekken's Avatar
^yes. so if we are facing the back of that headlight. turn that bolt clockwise. It's obviously best to adjust while it's still on car so you can see the beam move.
Old March 3rd, 2013, 09:15 PM   #14
jweezy's Avatar
Thank you everybody for the rapid responses; I appreciate it!
I will get at it once this 18cm of snow is gone. Snow storm out of no where makes it difficult for me to adjust it outside with 25 feet from a wall
I will take new pics when it is done.
07 Accord Coupe
Old March 6th, 2013, 12:37 AM   #15
jweezy's Avatar
Hey, I just had a quick question. Are there any tips or tricks you can recommend me for adjusting the projector itself? For example, is it possible to turn the projector dial with the ballast still connected to it?
And in terms of height, what is the best way to get the proper height? I heard mixed feedback on 25 ft wall? And 3.5 feet height off the ground? Any feedback will be appreciated!
07 Accord Coupe
Old March 6th, 2013, 06:01 AM   #16
DreaminAccord's Avatar
DOT:Lower cutoff is 2.1-2.5" below mid height of mounted projector. So for instance, if you mount the headlamps on the car and, using a tape measure, measure from the flat ground to the middle height of the projector lens, and you get 25" - aim your lower driver cutoff for 23.9-23.5" above the same flat ground, only at 25 ft away
ECE: 3 inch for Europe
How-To: aim HID headlamps
Upper cutoff________________________
_________/___________/
Lower Cutoff
I would def ask for that guy to redo the aiming over as that is a HORRIBLE job...just saying...it almost looks like one is RHD and the other is LHD
Ben
(Sold 7/26/17)
(Purchased 5/18/17)
Old March 6th, 2013, 06:11 AM   #17
You could. Just make sure you are grabbing the base where the bulb sits. Just park parallel to a big ass wall and make your beam straight. Block 1 headlight and adjust the one that on and vice versa. Its not rocket science
