Adhesive tape for HFP kit - Honda Accord Forum : V6 Performance Accord Forums
Old May 14th, 2013, 02:26 PM   #1
Anyone know where I'd be able to find the thick double sided tape that comes attached to the body kit? I recently installed the kit on my current car that I removed from my previous one. Since I couldn't reuse the original tape, I had to buy the thin stuff and ended up layering it. However, some parts on the rear lip are separating from the bumper. I'm thinking of redoing it, and have not been able to find the type of tape that comes with the lips.
2008 Acura TL Type-S NBP
Past:
2007 Black coupe 6-5AT
2006 Silver coupe 6-6MT
2006 Black coupe 6-5AT
2005 Graphite coupe 6-5AT
2003 Black coupe 6-6MT
mc1114 is offline   Reply With Quote Quick reply to this message
Old May 14th, 2013, 02:36 PM   #2
like this?
Amazon.com: 2Mm 3M Adhesive Sticker Tape LCD Screen/ Digitizer Sticker For HTC 4G Evo Supersonic, Incredible, HD2 T8585, Desire, Hero, Legend, Diamond 2: Cell Phones & Accessories
Old May 14th, 2013, 11:46 PM   #3
I don't think that's it. The stuff I'm talking about is pretty thick and it feels like rubber with adhesive on both sides. I have only been able to find the thin 3M automotive tape
Pretty sure I saw a post recently where someone posted a pic of it, but now I can't find it
Past:
Old May 20th, 2013, 07:25 PM   #4
Bursaliozer's Avatar
dealer?
Bursaliozer is offline   Reply With Quote Quick reply to this message
Old May 24th, 2013, 08:05 PM   #5
I'll ask next time I need to go there for something
Don't know why this stuff is so hard to find
Past:
Old May 24th, 2013, 09:54 PM   #6
Vutang1's Avatar
You can pick up the 3m adhesive tape from Home Depot around the paint section. It is 1" wide compare to the 1/4 wide which is on the hfp kit. The two tape share the same thickness, but the 1" wide provided more contact for me. I have purchase some recently 2 weeks ago for 5.00 + tax. It is called 3M 4011 outdoor mounting tape #S-17641. Here is a link from Uline website. Check it out and see if this works.
3M 4011 Outdoor Mounting Tape - 1" x 60" S-17641 - Uline
Vutang1 is offline   Reply With Quote Quick reply to this message
Old June 7th, 2013, 10:07 AM   #7
what he said^^
ramsey1166 is offline   Reply With Quote Quick reply to this message
Old June 8th, 2013, 09:23 PM   #8
Dealer didnt have it
The 3M tape in the link is the stuff readily available at every hardware store, which I have already tried. The original "tape" or strips are about 1/4" to 1/2" thick. That 3M tape is too thin, which is why I had to use layers, and thats why its coming off
I'm not talking about width, I'm talking about thickness. Here you can see the gap that I need to fix and the tape coming off
&mpt=[CACHEBUSTER]">
Old June 8th, 2013, 10:11 PM   #9
Tommy
tommastie's Avatar
The oem 3m has a layer of plastic in between the 3m to make the thickness to it for better contact.
tommastie is offline   Reply With Quote Quick reply to this message
Old June 8th, 2013, 10:20 PM   #10
That would explain why I cant find any really thick tape
I guess I should not have thrown away the old strips. Could have reused them with new tape
I guess I'll live with it
Past:
Old June 9th, 2013, 12:45 PM   #11
-Gene
phunctional's Avatar
3M 4466 Double Sided Foam Tape | StaplesĀ® ?
phunctional is offline   Reply With Quote Quick reply to this message
Old June 9th, 2013, 08:20 PM   #12
When i placed my lip on the car there were gaps on both sides. At first i was like WTF!? This is OEM, it should fit perfect?
What i had to do was pull the lip towards me from the middle which eliminated the gaps on the sides and my brother pressed it in place (both sides) then while still pulling on the lip he did the spots under the fog lights and finally the middle part where i was pulling on. It fits and looks great.
Maybe you need to try it like how i did it.
Old June 9th, 2013, 11:23 PM   #13
The front lip is fine, almost flush with the bumper. The rear lip is the problem
It doesnt bother me terribly. I wanted it to look better, but I can live with the gap. Its not noticeable from far. I dont think the gap will get bigger. The rear lip is somewhat curved on the top edge, so the thin double sided tape is ineffective
phunctional - That looks like thin tape, unfortunately.
Past:
Old June 10th, 2013, 05:13 PM   #14
ohh ok, didnt realize that was the rear lip.
If you arent going to ever take that lip off then maybe look for a more permanent solution in the form of epoxy?
Old June 10th, 2013, 05:47 PM   #15
Growth Chart Specialist
Shenaniganz08's Avatar
some terrible advice in this thread
You need to use INDUSTRIAL strength 3M double sided tape. That is what they use straight out of the factory (OEM lip kits) and what body shops use
3M Double-Sided Mounting Tape, Industrial Strength, 1 x 60, Clear/Red Liner - Office Products - Office Supplies - Tape, Adhesives & Fasteners
You can find this stuff at any Pepboys/Autozone.
Old June 10th, 2013, 10:01 PM   #16
I've seen it at the stores. Do you think it will hold if its layered like in the picture I posted? Since I dont have those plastic spacer strips from the original tape
Past:
Old June 11th, 2013, 12:02 AM   #17
The tape you are using now is not industrial strength (grey colored).
You really shouldn't even have to layer it. The industrial strength stuff is pretty strong. Yes you can layer it but you really don't have to.
Make sure to clean the area that you are going to be using the tape with Goo-be-gone to remove any old adhesive and then wipe everything down with Rubbing alcohol.
It doesn't matter how strong the tape is, if you don't prep the area correctly it will start to peel.
Old June 11th, 2013, 01:56 PM   #18
Thanks. I'll try it out
Past:
Old June 11th, 2013, 02:42 PM   #19
There's also 3M automotive tape, thats the one to use. Its available in Canadian Tire if you are in Canada
Old June 12th, 2013, 12:52 AM   #20
Tommy
tommastie's Avatar
3M VHB Heavy Duty Mounting Tape 5952 Black, 3/4 in x 15 yd 45 mil:Amazon:Industrial & Scientific
Buy these they are the heavy duty ones. I use them and I love them
Old June 20th, 2013, 10:36 AM   #21
try this
5M Black Double Sided Foam Tape 20mm Wide x 3mm Thick | eBay
akajjang9 is offline   Reply With Quote Quick reply to this message
