2006 Accord sedan SQ Audio build - Honda Accord Forum : V6 Performance Accord Forums
Like Tree5Likes
Old June 25th, 2013, 11:56 AM   #1
audioman79's Avatar
Hey guys I will be doing a Sound Quality car audio build for a 2006 Honda Accord sedan. The goal of the system will be a stealth build where everything in the trunk will be out of sight.
Goals of build:
-Provide Great sound quality while sticking to budget
-stealthy trunk build and leave as much space possible for daily
use
The list of products
Pioneer DEH-80prs Headunit
Mosconi 6to8 DSP
Mosconi Gladen one 120.4 amp
Mosconi Gladen one 240.2 amp
Image Dynamics IDQ10D2 V.3 10" subwoofer
Illusion Audio Carbon C6 6.5" components
Stinger electronics wires, rca and accessories
Car should be here next week so I can start the build, stay tune
audioman79 is offline   Reply With Quote Quick reply to this message
Old June 26th, 2013, 12:00 PM   #2
audioman79's Avatar
Here is pictures of some of the equipment that will be installed. still waiting on the Mosconi 6to8 digital sound processor and Bluetooth module.
carbon c6 components will be ran active to the mosconi dsp
the mosconi gladen one 240.2 and 120.4
will power the 10" IDQD2 sub woofer and the 120.4 will power the component set up front.
for sound deadening the doors, rear deck and trunk I will be using focal bam xxxl
The IDQ10D2 SUB
Old June 26th, 2013, 12:41 PM   #3
M![email protected] \_(ツ)_/
HEcreated487's Avatar
Looks promising. In for updates.
Old June 26th, 2013, 04:35 PM   #4
sirchadwick's Avatar
Nice stuff, hope you did not pay retail...
sirchadwick is offline   Reply With Quote Quick reply to this message
Old June 26th, 2013, 07:27 PM   #5
audioman79's Avatar
Im doing this build for a customers car, not my car. you pay for what you get in most cases. This is a sound quality build. I try to use the best equipment possible to meet their budget range. I always tell my customers you don't base it off of what other people say, internet or even what I say. Its your ears and sound is subjective. to many people come to me with a set amount and just want sound and are not looking down the road when they will come back wanting something else. I try to steer people from dumping money into a pit where they will never be stratified. I set down with them and go over their goals for the system short and long term. if they are off in their budget, I tell them never to settle, just wait and save instead of doing a impulse buy. my goal to provide quality builds not just sell equipment. there are many retail stores already that handle that side of things (bestbuy, walmart and online retailers). They come to me because they want and will get a top notch quality build that will last years to come. 3 years manufacture warranty on all equipment in the build. That's why people pay close to retail and don't have an issue doing so. So stay tune and enjoy the ride.
Milan and Nguyen-er like this.
Old July 4th, 2013, 12:20 PM   #6
The Jester
Plans for stealthing the 10"? Always wanted to mount a piece of 3/4" to the metal behind the rear seats, scoot the rear seat up an inch and make a double baffle, flush mounted, fiberglass box to fit it all together.
And would really only take up the rear 8-10" of the trunk. Could even add a layer of mdf as the back of the box and mount the amps to that, build an amp rack box on the back of the box, fans and wires out the sides, carpet and trim piece the back of the box and it will appear factory.
Old July 13th, 2013, 09:58 AM   #7
audioman79's Avatar
Im doing away with the spare tire, so the sub and amp rack will be in this area.
Old July 15th, 2013, 03:26 PM   #8
Looks nice.
DMack069 is offline   Reply With Quote Quick reply to this message
Old July 22nd, 2013, 04:26 AM   #9
What about sound deadening? I need to do more research on DYI sound deadening. so any info would be appreciated.
Triple6threat is offline   Reply With Quote Quick reply to this message
Old July 22nd, 2013, 07:30 AM   #10
audioman79's Avatar
I finally got a chance to start the accord build this past week. here are
some pictures.
I started with the removal of the lower pocket under the oem radio. the pocket was replace with the pioneer DEH-80prs Head unit.
aftermarket wire harness connected to the metra steering wheel controller
Head unit installed in the aftermarket head unit kit
Old July 22nd, 2013, 07:32 AM   #11
audioman79's Avatar
Head unit installed in the car
Old July 22nd, 2013, 07:41 AM   #12
audioman79's Avatar
Next moving on to the sound deadening of the doors which help keep the road noise and vibrations out of the car. also I had to make minor cuts to the sheet metal diameter to fit the new Illusion 6.5" mid bass. Also
added new holes with screw rivets in the sheet metal to mount the mdf adapter.
Old July 22nd, 2013, 07:49 AM   #13
audioman79's Avatar
Next the adapters were made out of 3/4 mdf and then weatherized with bed-liner spray to protect the wood.
Old July 22nd, 2013, 08:04 AM   #14
audioman79's Avatar
Next I added the black hole tile to the outer skin of the door from the inside and the focal bam xxl mat on the skin of the door.
Old July 22nd, 2013, 10:02 AM   #15
audioman79's Avatar
Now the focal mat is applied and adapter and illusion c6 mids are installed and wired.
the doors cards receive the same treatment and plastic area near speaker grill are trimmed.
Before mods were done
After mods
Old July 22nd, 2013, 10:13 AM   #16
audioman79's Avatar
both door cards completed
Old July 22nd, 2013, 10:22 AM   #17
audioman79's Avatar
same was done for the passenger side front door
Old July 22nd, 2013, 10:38 AM   #18
audioman79's Avatar
Now moving to the rear doors
Old July 22nd, 2013, 10:40 AM   #19
audioman79's Avatar
Old July 22nd, 2013, 10:49 AM   #20
audioman79's Avatar
Next the carbon c6 tweeter is installed in the factory location. grill on the tweeters were removed to fit in this location.
Old July 22nd, 2013, 10:54 AM   #21
audioman79's Avatar
with the oem tweeter cover off
Old July 22nd, 2013, 12:24 PM   #22
audioman79's Avatar
Now on to the trunk build, where the two amps, processor and 10" sub woofer will be installed. the spare tire was removed and a foundation board was cut and screw rivets to the car.
Old July 22nd, 2013, 12:45 PM   #23
audioman79's Avatar
Old July 22nd, 2013, 12:51 PM   #24
audioman79's Avatar
building of the amp rack
Old July 22nd, 2013, 12:53 PM   #25
audioman79's Avatar
Old July 22nd, 2013, 12:54 PM   #26
audioman79's Avatar
Old July 22nd, 2013, 12:59 PM   #27
audioman79's Avatar
So this is where I had to stop due to the customer needing his car this week for work. So i will be working on the trim panels for the trunk in the coming days. I will finish the build when he returns on Saturday. Left to do, -running the speaker wire, power wire, rca and remote wire to the trunk area. pull the rear speakers out so bass will enter through the openings. some mat on the rear deck and spare area. wiring up the amps, processor and tune the car. stay tune
Old July 22nd, 2013, 01:21 PM   #28
The Jester
Depending on what you do for timing delay and if you measure resonance frequencies, this data would be much appreciated.
Soon to be running a similar ysstem, just mounted to the back deck.
As well as screw points, I always thought the gas tank was under the trunk and didn't want to start a fire trying to mount an amp rack in the tire well.
Old July 22nd, 2013, 04:55 PM   #29
audioman79's Avatar
the gas tank is towards the front of the spare tire area. here
is where I put holes in the trunk spare tire area. you see three steel screw rivets so I can screw #8 2" screws through the mdf to the spare tire area to secure the system. I added two more rivets not shown to make it even more secure.
will you be using a dsp? if so what brand?
Old July 25th, 2013, 08:40 AM   #30
audioman79's Avatar
next I put some focal BAM X.X.XL mat on the inside of the enclosure and out lined the top trim panel.
