2007 Accord v6 sedan Stealth Audio Build - Honda Accord Forum : V6 Performance Accord Forums
Like Tree14Likes
Old September 16th, 2013, 11:30 PM   #1
audioman79's Avatar
Just completed a Stealth audio build for a forum members 2007 Honda accord v6 sedan. His goal was take his current equipment and incorporate it in the new stealth build. Also maximize storage space in the trunk for daily use. His current setup took up much of the room in trunk area with a large ported enclosure which alone took up 70% of trunk space. Now he finally has most of his trunk space back.
Here are before pictures of the setup.
Time for the deconstruction process of the old system.
Imageless83 likes this.
audioman79 is offline   Reply With Quote Quick reply to this message
Old September 16th, 2013, 11:41 PM   #2
audioman79's Avatar
Next I turned my attention to building a custom 1cu.ft sealed enclosure for the Kicker L5 12" subwoofer.
Old September 16th, 2013, 11:44 PM   #3
audioman79's Avatar
Next, test fir the sub in the enclosure.
Old September 16th, 2013, 11:59 PM   #4
audioman79's Avatar
Next, the foundation base or floor for the audio system.
The 1 farad capacitor was mounted on the base floor hidden out of sight.
Old September 17th, 2013, 12:03 AM   #5
audioman79's Avatar
Next the construction of the amp rack
Old September 17th, 2013, 12:06 AM   #6
audioman79's Avatar
[IMG][/IMG]
Old September 17th, 2013, 12:10 AM   #7
audioman79's Avatar
Test fitting the system back in the car
Old September 17th, 2013, 12:24 AM   #8
audioman79's Avatar
Moving on to the main trim panel.
Old September 17th, 2013, 12:26 AM   #9
audioman79's Avatar
Next I made grills to cover the sub and amp when hauling in the trunk area.
Old September 17th, 2013, 12:35 AM   #10
audioman79's Avatar
Next the side trim panels are test fitted
Grill covers wrapped in trunk liner
Then the enclosure and amp rack cover is wrapped in black vinyl
Old September 17th, 2013, 12:38 AM   #11
audioman79's Avatar
Last the main trim panel was wrapped in trunk liner carpet.
Old September 17th, 2013, 12:40 AM   #12
audioman79's Avatar
Murders23 and DreaminAccord like this.
Old September 17th, 2013, 12:50 AM   #13
audioman79's Avatar
now shots of the system with grill cover in.
This build came out very nice, as you can see he has much more trunk space. While keeping the same amount of audio equipment. The system sounds better then before, the sub output seems higher. I added some blackhole stuff, made by orca design on the inside the enclosure Thanks for checking out the build guys.
Old September 17th, 2013, 02:14 AM   #14
M![email protected] \_(ツ)_/
HEcreated487's Avatar
Another quality build, Audioman! Again, love that stealth look. I need a setup for my current vehicle. Do you also work with custom fiberglass enclosures?
Old September 17th, 2013, 02:59 AM   #15
3.0UALLKNOW's Avatar
That's badass!!
3.0UALLKNOW is offline   Reply With Quote Quick reply to this message
Old September 17th, 2013, 07:06 AM   #16
audioman79's Avatar
Thanks, I also build fiberglass enclosure when requested. Some cars that I need
To gain more air space in the spare tire area. I do the bottom
Of the enclosure in fiberglass. It all depends on thr goal of thr build.
Old September 17th, 2013, 08:51 AM   #17
2nd Gen CTSV
Imageless83's Avatar
Awesome build, I'll pm u about building an HT version for me since ur local plus pricing.
Imageless83 is offline   Reply With Quote Quick reply to this message
Old September 17th, 2013, 09:03 AM   #18
B.R.03ex's Avatar
That looks awesome! I'd love to do something like this down the road.
B.R.03ex is offline   Reply With Quote Quick reply to this message
Old September 17th, 2013, 12:31 PM   #19
Carpe Diem
ikethegreat's Avatar
Worth every penny!
Thanks again Audioman!
Old September 17th, 2013, 05:22 PM   #20
audioman79's Avatar
no problem, glad I could help you with your goal for your system.
Old September 17th, 2013, 05:54 PM   #21
2nd Gen CTSV
Originally Posted by ikethegreat View Post
Worth every penny!
Oh shytt, i wanna see ur trunk in person Ike!!!!
Current--2nd Gen CTS-V
J33 Slush box-Sold
Old September 18th, 2013, 08:45 AM   #22
yal
Sick, nuff said!
yal is offline   Reply With Quote Quick reply to this message
Old September 19th, 2013, 11:56 AM   #23
Slammed & Stunning
MatthewYu's Avatar
Jealous..
Do you need to remove the carpet cover when subs are in use?
Old September 19th, 2013, 11:49 PM   #24
audioman79's Avatar
Originally Posted by MatthewYu View Post
Jealous..
No the sub plays the same with it on or off. the sub is recessed 1.5" so when the bass hits, it wont touch the grill. grills are to protect the sub and amp from damage when hauling things in the trunk.
Old September 20th, 2013, 05:35 AM   #25
Carpe Diem
Yeah I played around with both the cover on and off and noticed no difference in sound. I just keep them both covered, although I'll probably keep the amp uncovered during the summer months.
Old October 4th, 2013, 08:33 AM   #26
audioman79's Avatar
Here is a very short video clip of this stealth system in action. I put on Facebook page/ you tube https://www.facebook.com/pages/Hinna...02693809895087
Old October 6th, 2013, 03:03 PM   #27
damn thats awesomme. hope u dont live up north bc you definitely need the spare tire up here...
audioman79 > any suggestions on how i can get more space in my sedan w/o removing the spare? i have 2 jl w6s
2004av6 is offline   Reply With Quote Quick reply to this message
Old October 6th, 2013, 04:13 PM   #28
6 Speed
Ride's Avatar
Beyond impressed. Major props audioman! You clearly take pride into your work!
Ride is offline   Reply With Quote Quick reply to this message
Old October 6th, 2013, 09:16 PM   #29
audioman79's Avatar
you could always do side enclosures on each side. I did a install in a Subaru where I built the enclosure inside of the spare for a single 12" sub.
HEcreated487 and CrackerTeg like this.
Old October 7th, 2013, 10:53 AM   #30
Thats crazy!!! I like that idea but how would i have access to the spare if the enclosure is inside with wiring etc?
