2006 sedan oem front bumper on a 2003 sedan - Honda Accord Forum : V6 Performance Accord Forums
Like Tree8Likes
  • 1 Post By CrackerTeg
  • 1 Post By funkbro2
  • 1 Post By HEcreated487
  • 1 Post By chizzle187
  • 1 Post By crkdslider
  • 1 Post By 03accord_Ex
  • 1 Post By Paul509
Old September 19th, 2013, 10:14 PM   #1
GUYS I HAVE DONE MY RESEARCH HOME WORK BUT WANT TO BE SURE.
Ok so I'm planing to do this conversion to my 2003 sedan just because my car was hit and I'm planing to repaint the complete car. Since my front bumper is kind of crack I though it would be a good idea to swap to a better looking front bumper but just wanna make sure I'm going the right route. So far I have come up with that the 2006 sedan front bumper will bolt right up with my 2003 sedan frame with out replacing the side bumper brackets. So what I need to buy to make this conversion happen is the 2006 oem front bumper, 2006 oem grille,not worried about the bottom grille. Some questions I have are do I also have to buy the foam impact absorber for the 2006 or my 2003 absorber will fit?do i have to buy the grille under hood cover or mines will fit?Also for the foglights is the wiring of the fogs different from the 2003 to the 2006 wiring process? Will I need to use the 2006 wiring diagram from honda to do the correct wiring to my 2003? Any input will help pls mostly on the fogs since I'm planning to do it myself. Thanks V6P...
03accord_Ex is offline   Reply With Quote Quick reply to this message
Old September 23rd, 2013, 08:16 AM   #2
No comments guys?
Old September 23rd, 2013, 09:15 AM   #3
The name is Z
CrackerTeg's Avatar
Nobody has commented because the dead horse has been beaten to a pulp on this subject. Search a little bit harder and you will find your answers.
Arielit0oo likes this.
Old September 23rd, 2013, 01:44 PM   #4
Lol your right bro. Just wanted too be sure what I'm doing before I start buying parts. I'll keeping searching on the web for answers....
Old September 23rd, 2013, 06:38 PM   #5
bumper and grill is what you need and the lower grille
cant comment on fog wiring
03accord_Ex likes this.
Old September 23rd, 2013, 06:45 PM   #6
M![email protected] \_(ツ)_/
HEcreated487's Avatar
For the conversion, you need the 2006 bumper and upper grille. Lower grille is optional, but would still need to be the '06-'07 version. Same for the license plate holder. To be conservative, I would purchase the 2006 foam bumper support. It shouldn't be expensive.
For the fog lights, get OEM wiring harness and switch for the 2003-2005 models. The wiring harness for the 2006-2007 is different and will not work. Ask me how I know.
Old September 23rd, 2013, 07:10 PM   #7
Thanks guys much appreciated for the comments and your time. Michael any idea where I can get my hands on that oem wiring and switch? Also michael planning to roll all my fenders to add spacers for my tsx wheels which I know u ran before. Which spacer size will look better for front and rear 20mm 25mm? I think I remember u ran 25mmF 20mmR. Thanks sorry for all this dame questions...
Old September 23rd, 2013, 07:29 PM   #8
Unsure on where you can get the OEM wiring harness (I bought a complete Inspire replica fog light kit with OEM wiring harness and switch off of the DA forums), but there are multiple sites (hondapartscheap.com, bernardiparts.com) that are likely to carry those parts in stock.
As for the spacers, I used Ichiba Version 2, 20mm front and 25mm rear. Hope that helps.
Old September 23rd, 2013, 07:39 PM   #9
Thanks michael
Old October 22nd, 2013, 12:47 AM   #10
i think it is do able
vaynardx is offline   Reply With Quote Quick reply to this message
Old October 31st, 2013, 09:07 PM   #11
UPDATE...
2006 sedan oem bumper fits like a glove.Parts only needed for the conversion was the bumper and top and lower(optional) grille. everything else clips right on. Now working on the replica lip and it has being a ***** since its fiberglass. Hope i can make it fit. My sedan is going for a fresh full paint job excited!!!
Old November 1st, 2013, 01:14 AM   #12
Chaz
chizzle187's Avatar
Looking good homie, We need to roll out to AFM2013!
chizzle187 is offline   Reply With Quote Quick reply to this message
Old November 3rd, 2013, 09:24 PM   #13
Lets see if i can make it bro...
Old November 7th, 2013, 02:06 PM   #14
angelstatiz's Avatar
03 accord ex thats good that people ended up helping u with answers once in a while u get a dumb fuk in here lol that says stuff like do your research thats what we get on here for to get help but your car looks good keep up the good work
angelstatiz is offline   Reply With Quote Quick reply to this message
Old December 31st, 2013, 11:40 AM   #15
Wingdreamer
wingdreamer's Avatar
Originally Posted by 03accord_Ex View Post
UPDATE...
Sounds good! I read that you need to replace 2 side brackets, lic plate bracket etc to make the 06 bumper fit the 03. You didnt have to do that? My son just took out the bumper on his 03 sedan in a snow bank this morning. need to order a replacement. wanted to go with the 06 but cash is tight for him. cant afford any extras but the bumper for now. fit on no problem?
2006 Accord EX V6 3.0 with Navi. My 4th Accord, die hard Honda fan! My other Honda is a GL1800 Goldwing!
wingdreamer is offline   Reply With Quote Quick reply to this message
Old January 1st, 2014, 02:08 PM   #16
crkdslider's Avatar
Looking good! I like the front of your car!
crkdslider is offline   Reply With Quote Quick reply to this message
Old January 1st, 2014, 10:19 PM   #17
All you need is the 06 front bumper and 06 upper grille, the lower grille is optional but in my opinion i will purchase both grilles,also you can reuse your foam impact absorber. If your not installing fogs you will need fog covers. To get you and idea how much i spend was $100 on a 06 sedan OEM used front bumper from ebay,$40 for OEM used upper grille from chaz here in v6p,$25 aftermarket new lower grille from ebay,$70 for replica inspired fogs from ebay this fogs are optional. Hope this helps.
wingdreamer likes this.
Old January 1st, 2014, 10:40 PM   #18
My 03 sedan freshly painted with a 06 oem front bumper conversion with a 03-05 modify replica oem lip. Lower grille is not installed in the pic.
Old January 2nd, 2014, 03:10 PM   #19
Which seller did you buy your lip from?
BuhRanDuhn is offline   Reply With Quote Quick reply to this message
Old January 2nd, 2014, 08:10 PM   #20
03-05 replica sedan oem front lip
Honda Accord Sedan 03 04 05 OE Style Front Lip Body Kit HFP 2003 2005 | eBay
06-07 replica sedan oem front lip
2006 2007 Honda Accord Sedan Front Lip HFP OE Style Body Kit | eBay
Make sure you pick the right lip that fits your bumper. I had to modify my 03-05 lip since i already owned it to fit my new 06 bumper.
Old January 5th, 2014, 09:33 AM   #21
Wingdreamer
Ordered in an aftermarket 2006-07 front bumper ($100.00) left inner fender liner ($38.00) and a used air box resonator ($75.00). Put it all together yesterday, reused the foam bumper absorber. Going to install a set of driving lights in the spring. Even got the '03 lic plate bracket to work for now, (till I order in and install the upper and lower grills and have it painted in the late spring). Overall, the '06 clip fit perfect, no diff than the '03 to '05 clip. Thanks for the info!!
Old May 29th, 2014, 01:05 AM   #22
I have a 2004 Accord EX also, will the conversions work also? I've looked and everyone messed with the 2003 more then the 2004, so does the 2003 and 2004 have any difference with each other ?
04ExAccord is offline   Reply With Quote Quick reply to this message
Old May 29th, 2014, 01:20 AM   #23
Wingdreamer
I cant see that there would any diff between the 03 and 04 models, as long as they are sedans (the coupes are different).
Old October 19th, 2014, 06:13 AM   #24
Guys I've been having a hard time finding a bumper online to do the same conversion on my 03 sedan. Any suggestions where I can order the bumper and upper grille.
flyaccord is offline   Reply With Quote Quick reply to this message
Old December 5th, 2014, 05:01 PM   #25
Sosi baklazhani bydlo
LiquidXplosion's Avatar
Send a message via AIM to LiquidXplosion
I used to want to do this but then i abandoned the whole idea years ago. Simple swap.
LiquidXplosion is offline   Reply With Quote Quick reply to this message
Old December 24th, 2014, 10:09 AM   #26
looks nice
Carbonbronzecm5 is offline   Reply With Quote Quick reply to this message
Old January 8th, 2015, 10:00 PM   #27
Hey 03 accord I've done the conversation from 04 to 06 sedan bumper, I had no problems I had to swap out the grille but that was a given now I'm stuck on the fogs, I have the same one you have but I was wondering if the installation is the Same as the oem ones
Project is offline   Reply With Quote Quick reply to this message
Old January 9th, 2015, 06:00 AM   #28
Carpe Diem
ikethegreat's Avatar
No it is not. Do a search on the forums here for inspire fog lights. You'll need to hack up the fog light housing on the inside of the bumper to make them fit.
Old April 3rd, 2016, 07:03 AM   #29
If a 2006 front bumper fit an 03 wouldn't the 07 front bumper fit also
Princess likes this.
Paul509 is offline   Reply With Quote Quick reply to this message
