install 2 USB ports by stereo to charge devices - Honda Accord Forum : V6 Performance Accord Forums
Like Tree4Likes
  • 4 Post By Wolfy47
Old October 1st, 2013, 08:29 PM   #1
Bimmer_guy's Avatar
Cool install 2 USB ports by stereo to charge devices
so i got want to install 2 USB ports to charge my electronic device(power only) somewhere near stereo(i got a single piece panel mount dual USB ports with bare wires)
i need ideas where to make that cutout and how to wire it properly.
i chose the hard way, so i cant tap the 12v cigarettle socket)
it needs to be connected to a 5V source.
maybe other products that have built in transformers?
i am not a noob when it comes to electricity.
please post link of similar projects.
Bimmer_guy is offline   Reply With Quote Quick reply to this message
Old October 2nd, 2013, 08:16 PM   #2
aka swollpatrol
Wolfy47's Avatar
Seems alot easier just to pick one of these up.
Wolfy47 is offline   Reply With Quote Quick reply to this message
Old October 2nd, 2013, 09:04 PM   #3
DiceX's Avatar
^^ I got one of these from Sony. Works great and was only 20 bucks. Got it years ago.
Old October 2nd, 2013, 10:04 PM   #4
The Jester
Easier to pick up adapter, else, outline hole for size of the dual ports somewhere on dash/shifter trim/inside center box, hook some 5v regulators up to a line going to the 12v line going to the cigarette lighters, mount and get all crimped together.
Old October 2nd, 2013, 10:49 PM   #5
Bimmer_guy's Avatar
Wolfy47 i like your avatar pic.
the cig lighter outlet is not the best location on the accord,
and it disconects ocasionally(and shorts out a lot if a penny falls in there)
Old October 2nd, 2013, 11:29 PM   #6
aka swollpatrol
Wolfy47's Avatar
I can understand the location being a problem. You can consider removing the little door that covers the plug. Another idea is, I dont know if the center console secondary plug is on all accord or just the ex's, but if you do have it you can use that since I believe that is wired to the battery and constant. Although the plug hole is smaller than the main one so if that is the case just "mod" a main one and wire that one in place of the secondary center console one.
As of pennies falling in there, that sounds like an easily avoidable problem.
Old October 2nd, 2013, 11:45 PM   #7
The Jester
Never had the penny problem, as stated I usually use the one in center console, seems to have more amperage. The spring door seems to be an easy solution to the penny problem... and is issued stock.
Old October 4th, 2013, 08:52 PM   #8
Cool
lol transformers doesn't work with DC current.
If you want to buuld your own 1A USB charger you need a female USB port, LM7805, 2 diodes, pair of 1uF capacitors, a heatsink
visit this page
Simple Cellphone Battery Charger Circuit | Technical Essential
USB pin out.
File:USB.svg - Wikipedia, the free encyclopedia
NOTE, check the data sheet of LM7805 some brands pins are different.
pollo is offline   Reply With Quote Quick reply to this message
Old October 19th, 2013, 09:30 AM   #9
Wingdreamer
wingdreamer's Avatar
visit this page
USB pin out.
Or, if you really want the "look" of a built in, use one of the above plug in usb adapters, plug it in to a female power plug, and hard wire this "combo" to the wiring going to the factory power plug on the console. Mount this combo in the dash, below the radio. Take a usb cable, plug it into the adapter and wire the other end to the back end of your newly installed usb outlet on your console. This way you dont have to build a 5 volt usb "adapter".
wingdreamer is offline   Reply With Quote Quick reply to this message
