06 radio in and 03 accord - Honda Accord Forum : V6 Performance Accord Forums
Old October 28th, 2013, 11:47 AM   #1
Hey guys, so i was wondering would and 06 radio fit on an 03? I know the only diff is that the 06 has dual climate control but other wise is pretty much the same. So my concern is when i install the 06 radio in my 03 would i still have ac and a heater? also would the dual climate control function work?
BHom_ex is offline   Reply With Quote Quick reply to this message
Old October 28th, 2013, 11:50 AM   #2
just get a double dinn bro.
Old October 28th, 2013, 11:54 AM   #3
naw i like my cubby
Old October 28th, 2013, 12:30 PM   #4
2008 Honda Accord V6 EX-L
The dual climate won't work if you have a single...Also something to consider is if the 06 radio came from a coupe or sedan. Lets say you have a coupe and radio came from sedan none of your HVAC controls will work properly. Hope you like defrost all the time.
korrupt3dazn is offline   Reply With Quote Quick reply to this message
Old October 28th, 2013, 12:53 PM   #5
i dont really car for dual i am fine with single. and i have a 03 sedan and the radio came off an 06 coupe
Old October 28th, 2013, 01:30 PM   #6
Just plug it in and see for yourself first hand...It wont work right. I believe Martin from Ebay sells the harness. For about 50-100 to convert a dual climate radio into single. I believe there is a resistor you have to de-solder and move to the 4DR slot.
Old October 28th, 2013, 01:33 PM   #7
Just plug it in and see for yourself first hand...It wont work right. I believe Martin from Ebay sells the harness. For about 50-100 to convert a dual climate radio into single. After for a coupe radio. I believe there is a resistor you have to de-solder and move to the 4DR slot.
alright thanks for the help!
Old October 29th, 2013, 10:13 AM   #8
Any one else try it???
Old October 29th, 2013, 10:32 AM   #9
not worth it just get the metra double din or a a single din so you can keep your cubby.
Old October 29th, 2013, 08:51 PM   #10
i like my cubby cause it flips downs n cover stuff
